Cutting a good light with an automatic - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 07-07-2014, 07:04 AM   #1
I have a new GT with automatic. Have the Autotrack/traction control off. Have tried deep staging and traditional staging.Cant seem to find the sweet spot. Just curious if someone has found a good procedure. Which amber are you using, are you building RPM or simply matting it etc. Imm generally late but my consistency is good. Had 4 runs for example. They were .141,.137,.140 and.130. That's leaving when the second amber goes off. The electronic throttle lag is a problem.If I leave when the second comes on I'm red. Just looking for ideas.
bodon is offline   Reply With Quote
Old 07-07-2014, 05:50 PM   #2
Region: Alaska
Do you have a problem spinning? Leaving off the second yellow is pretty ballsy.... But if it works for you. Try building rpms to about 15-1800 and leaving when the third yellow comes on. Also are you counting exp. 1..2..3 in your head before you leave? One of the ways I cut a good light is by focusing on the third yellow and reacting to it coming on instead of anticipating it. You can pm anytime if I wasn't clear on anything good luck!
CFYA2818 is offline   Reply With Quote
non automatic headlights/automatic turn off silverskoundrel General Mustang Discussion 11 09-07-2013 10:13 AM
Cutting Your Springs megax29 Pre-2005 V6 Mustang 45 10-13-2004 05:36 PM
Cutting GT Hood megax29 Pre-2005 V6 Mustang 12 09-09-2004 12:15 PM
cutting C springs ???? Zim Pre-2005 V6 Mustang 8 06-24-2004 01:59 PM
need feedbacks due to inconsistent answers..C spring cutting tire Pre-2005 V6 Mustang 12 03-08-2004 02:57 PM
08:50 AM
