Shifting tips for '05 GT - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 07-30-2014, 01:12 AM   #1
NFloris_05's Avatar
So recently I went to a drag strip for my very first time, and I had a blast, but there was some things I was having issues with and was wondering if I could get some advice. First, I was wondering what RPM to shift at while going down the strip for a bone stock 05 Mustang GT. Also shifting itself, on the road I can shift fine, but while I'm going down the strip, my car resists shifting, it gets like stuck, is there a technique I can do to avoid that resistance? Thanks!
NFloris_05 is offline   Reply With Quote
Old 07-30-2014, 07:01 AM   #2
It should not get stuck and should shift smoother the higher you spin it. Shift at around 5800. Having a stock shifter or running a bad fluid or too much fluid can also cause issues. Correct fill should be 3.2 quarts and you should be running Syncrhomesh. If you've never done the manual trans fluid, now would be a good time.
Old 07-30-2014, 03:13 PM   #3
NFloris_05's Avatar
I have a Hurst Competition Plus shifter, but I have never done trans fluids before, I will definitely look into that this up coming weekend. My car shifts perfectly fine while doing pulls on the street, but the track it's hard, people said it's cause all the traction on the strip is what's causing it. But I'll look into tranny fluids. Thanks!!
Old 07-30-2014, 05:10 PM   #4
Those ppl sound like they are internet racers who have never been to a track. You shift when you shift. If you are having problems at the track, sit back a minute and think if you are trying to shift faster than you normally do on the street or if there are any other factors. I have a 3650 and I can nail a 6k shift no problem.
Old 08-08-2014, 10:55 AM   #5
Ish416's Avatar
If you can shift fine on the street but can't at the track, the likely culprit is the driver.
Old 12-02-2014, 04:30 AM   #6
Speed_Mister's Avatar
Region: Arkansas
If you are good you never let off the gas, tap the clutch as fast as you can, and hit it in gear as fast as you can while not letting it over rev 200rpms is a good shifter.
Practice and learn to rebuild your tranny and keep teaching yourself till you never miss a shift like I did. I always have people tell me to teach them how to drive a car. I always tell them the best way is to sit in the car and figure it out yourself it is the best learning experience.
Also I might recommend practice launching the car, it will help your times more than shifting depending how slow you shift.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-02-2014, 05:42 AM   #7
Whoa back from the dead! All depends on the setup too and how new/well built his transmission is. A lot of ppl get a WOT box to keep from over-revving. However if you are serious about your 1/4 times you'll just go auto and be done with it.
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
Shifting tips? NFloris_05 2005-2010 Mustang GT 7 07-11-2014 01:08 PM
Shifting feel KyleUSAF Pre-2005 V6 Mustang 6 02-15-2005 10:28 AM
SLP Tips and stock tips from 98 Cobra SVT_Rob Mustang Parts for Sale and Wanted 7 08-10-2004 09:08 PM
Shifting on Automatic megax29 Pre-2005 V6 Mustang 52 07-15-2004 11:14 AM
06:41 AM
