13 GT Procharger 1/4 mile results so far - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 11-07-2015, 10:54 AM   #1
RJ13GT's Avatar
Went to the track again last night with my P1SC stg 2 Procharger on my 13 GT. My only power mods are the stg 2 kit with the 4.13 pulley with an off road x pipe and a Circle D 3c converter. It makes 8 psi max. I'm whittling my time down every time I go. My 60's are not consistent but my best result so far was loading up the converter as high as it will go without spinning the tires and it pulled a 1.589 60' doing that. The car is hitting the limiter a little on the 1-2 shift so I have to get my tune revised. I got one clean run out of 3 before I was told I need a fire jacket but still ran my PB last night. The DA was 1680' and ran 11.1@ 124.6 with a 1.58 60'. Had 3/4 tank of gas and nothing removed from the car, I actually added some weight with my tool bag and portable compressor. I'm hoping for a high 10 sec run in some good early spring air and maybe take the spare tire out.
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 12-20-2015, 11:21 PM   #2
avgt500's Avatar
What kind of tires you running? I pulled my front sway bar for drag racing, it's a +2 deal, you remove weight off the front and the front lifts faster transferring weight to the rear.
By the way there's hardly any difference on street manners.
2008 VMP gen2, 3.73s lots of other stuff.
avgt500 is offline   Reply With Quote
Old 12-20-2015, 11:28 PM   #3
RJ13GT's Avatar
285 Nitto 555r drag radials. Havent thought about disconnecting anything. I went back to the track to take advantage of some better air and ran a 10.9@127.5 but the track was slick and could only manage a 1.74 60'. Could have run a 10.7 easily with traction but maybe next spring.
Sent from my SCH-I545 using Tapatalk
Old 12-21-2015, 07:28 PM   #4
that thing is moving out! what size stall? do you still have the stock gear in the rear?
bigmamaluke is offline   Reply With Quote
Old 12-21-2015, 07:42 PM   #5
RJ13GT's Avatar
Stock rear end gear. And the 3c converter i think its like a 3500ish stall.
Old 12-21-2015, 07:57 PM   #6
RJ13GT's Avatar
Yeah im happy with how it runs. Minimal effort 8psi with a stall and drag radials pretty much. I have a awesome tuner too by the way.
Old 12-22-2015, 04:53 AM   #7
cat1dsm's Avatar
Great times. How different does it drive on the street with the high stall converter? Does it shift closer to 3500 all the time?
cat1dsm is offline   Reply With Quote
Old 12-22-2015, 05:15 AM   #8
RJ13GT's Avatar
Thanks! The car drives near like stock. There is a little more slip from the converter on takeoff but you get used to it after a few minutes of driving and dont even notice after a short time and there is nothing weird with how it shifts. It shifts as any stock/tuned car would. Not much of a downside to running a higer stall converter now days.
Old 12-22-2015, 05:16 AM   #9
RJ13GT's Avatar
Old 12-29-2015, 09:55 PM   #10
What kind of fuel? 93 or e85?
stormtrooper5.0 is offline   Reply With Quote
Old 12-29-2015, 10:03 PM   #11
RJ13GT's Avatar
93... i wish we had some e85 around here.
1/8 mile and 1/4 mile times Jvibe92 2011-2014 Mustang GT 4 05-04-2015 10:12 PM
Procharger install results Blacks197 2005-2010 Mustang GT 5 04-09-2011 09:25 AM
0-60 and 1/4 mile results stangaroo Pre-2005 V6 Mustang 27 12-10-2009 03:26 PM
nitrous 0-60 and 1/4 mile results stangaroo Pre-2005 V6 Mustang 5 04-15-2009 04:04 PM
So close..but so far!! (Car Pics) 98VroomVroom The Bar 16 10-01-2003 08:49 PM
04:23 AM
