Currently at the track!! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 05-06-2016, 05:18 PM   #1
Joaquin_ii's Avatar
So first time here. Playing the waiting game now. Nervous 😬😬
Joaquin_ii is offline   Reply With Quote
Old 05-06-2016, 05:35 PM   #2
medwards's Avatar
So how'd it go?
_________________________________________
Shelby Super Snake
Base Car - 2015 50th Anniversary Edition
"All the options baby!"
medwards is offline   Reply With Quote
Old 05-06-2016, 05:39 PM   #3
Joaquin_ii's Avatar
Still waiting. And I'm lined up next to a c7 😒
Old 05-06-2016, 06:05 PM   #4
Billymccrary3's Avatar
Just have fun! I was a little shackles before my first run but right after I was hook! Been every week since!
Hopefully that C7 spins the tires and you take him! 👍🏽👍🏽👍🏽
Instagram: @Alpha3.7
Billymccrary3 is offline   Reply With Quote
Old 05-06-2016, 06:17 PM   #5
Joaquin_ii's Avatar
Name:	ImageUploadedByMustang Evolution1462580143.368648.jpg
So I did horrible!! 13.6! Wtf? Any insights?
Mods-
Air aid cai
Boss iM
Bbk headers & pipe . Gt500 mufflers
Michelin super sport 255-40-19
Barton Short throw.
Bama 93 tune.
Old 05-06-2016, 06:21 PM   #6
Joaquin_ii's Avatar
Oh yea suspension
Bmr; uca, Lca, panhand bar, springs, relocation brackets
Koni adjustable shocks and struts w/ gt500 mounts
Old 05-06-2016, 06:32 PM   #7
Practice. Practice. Practice.
Respect the classics.
Recon is online now   Reply With Quote
Old 05-06-2016, 06:59 PM   #8
Joaquin_ii's Avatar
Didn't know I had to have a helmet if I ran a certain time. So I could only run that one time.
Old 05-06-2016, 07:04 PM   #9
Looks like you had trouble off the line! You get that 60ft down next time you'll run some good times!
Car manual or automatic?
Old 05-06-2016, 07:07 PM   #10
One mod is a Barton short throw so...
What gears are in the rear?
Car has a healthy build.
Old 05-06-2016, 07:17 PM   #11
Joaquin_ii's Avatar
Car is manual. and I'll upload the videos tomorrow but yes I did, it hesitated taking off.
Old 05-06-2016, 07:18 PM   #12
Yeah that 60 foot is horrible. Work on your launch.
Old 05-06-2016, 07:19 PM   #13
Joaquin_ii's Avatar
As for the rear gear I do not know. (I know 😞) but it is a 2011 gtcs if that lets you know anything
Old 05-06-2016, 07:21 PM   #14
Joaquin_ii's Avatar
So I launched at 3000 rpm.. Should I go higher?
Old 05-06-2016, 07:39 PM   #15
medwards's Avatar
I'm certainly no expert, but this is what I see in that slip.
1. First off you were up against an opponent with a lot of experience. His reaction time is awesome. But, don't worry about your reaction time if you're just getting started. It doesn't affect you racing against yourself. It only matters when you start trying to beat the guy in the other lane.
2. Secondly, that C7 was hardly stock to put up an11.4 sec at 130mph.....but that doesn't matter....let's get to you.
3. Your 60 foot time shows a problem. Either you had no traction and were spinning, or you stumbled off the line, or you have a high gear ratio and had no power off the line (did you fudge letting off the clutch and bog the car, or did you spin?)
4. You're 1/8 mile improved vs the beginning of your run, so it looks like you had traction at that point and were building speed ok.
5. Something appeared to have happened between 1/8 and 1000ft. Your acceleration wasn't great...or it's probably just lack of HP
6. Ending at 113MPH shows that you've got a car that has giddyup.
I think you somehow blew it at the line and struggled when shifting to 2nd, then got your composure after that and were just limited by HP at that point....but it was already too late because of the problems getting off the line in 1st and then the trouble you had going into 2nd.
You should tell us what you experienced during each gear. You want to think that through before you forget.
Regarding the helmet...you can usually buy one at the track. They usually have a race shop.
Shelby Super Snake
Old 05-06-2016, 07:42 PM   #16
Joaquin_ii's Avatar
https://youtu.be/vvCaSWaEaiQ
Old 05-06-2016, 07:49 PM   #17
medwards's Avatar
Sorry didn't see this one before I posted. You want that launch RPM as high as you can without spinning. That's going to be a practice/test thing. If it keeps hesitating you need lower gears, more power, or be willing to slip the clutch (not good for your clutch, but will stop the hesitation).
Shelby Super Snake
Old 05-06-2016, 07:51 PM   #18
Joaquin_ii's Avatar
Medwards thanks for all that! I will come back and explain as for now I have to go into work!
Old 05-06-2016, 07:56 PM   #19
medwards's Avatar
Oh yah, you completely blew the launch (sorry for being so honest). Strange that the car choked at first then it sounds like you spun the tires when it started going. I'd stay out of the water pit for your next few runs during your next trip to the strip. You may have gotten some water in the treads which could have caused spinning after the tires made a few rotations.
If you watch the vid closely, it looks like you launched at about 2600rpm....way too low. Then you were shifting too early. It's hard to tell but it looks like you could have gotten another 500+RPM before shifting. That would have given you more speed, power and reduced time. When you went to the next gear it looks like you were in the 4000ish RPM range starting in the next higher gear, which is likely below the optimal power band.
Other than that the rest looked/sounded pretty good especially for your first time. Damn, you didn't miss a gear and your shifting was nice and crisp and you held it to the floor through the end. Nothing to be ashamed of in that run for your first time!
With that gopro, you should mount it fixed and have it clearly showing your tach and speedo. That will help a lot in seeing what you're doing wrong. Love gopros.
Ok....I'm going to shut up and let others chime in
Shelby Super Snake
Old 05-06-2016, 08:19 PM   #20
Joaquin_ii's Avatar
https://youtu.be/p4yR6uaYXoE spedometer
Old 05-06-2016, 08:48 PM   #21
Joaquin_ii's Avatar
Medwards thank you again!! I will definitely do as you say on my next run and as stated about practice practice practice. I need the honesty I won't take offense!
And the go pro was borrowed and he only had the head straps so I couldn't have it fixed.
Old 05-07-2016, 12:53 PM   #22
medwards's Avatar
Are you able to zoom in on the tach the same as you did for the speedo. The tach will tell you more.
You may want to try a launch from idle. The car won't stumble if you do that. Slip the clutch ever so slightly while "rolling" into the gas in first (just barely slip the clutch....doing so creates heat and heat is really bad for the clutch...if you smell clutch burning you slipped the clutch too much...you need to let it out faster). That alone will knock off a fair amount of time since the car won't be stumbling off the line. If that works for you, great. You have a nice way to come off the line. Then try another run by dumping the clutch with the RPM's around 3500 and then keep increasing 500 RPM until one launch you will spin....that's the limit for your car's current setup. However, be forewarned...High RPM launches put more strain on the drivetrain than idle starts so you may want to do idle starts until you get good at shifting in the higher gears and learn to pay attention to the tach while shifting to stay in the power band. That way you're putting less stress on the car overall while practicing the finer art of drag racing from the seat.
Then you can start doing high RPM launches....but remember you will find the weak parts of the car with higher and higher RPM launches (ie/ you may start breaking things).
Do all of this incrementally. Cars do strange things sometimes. I've seen well behaved cars launch great at one RPM and then go sideways 1000RPM higher. Your car's setup doesn't appear to be generating enough torque for this to be a concern, but it's better to be safe than sorry. It's at the start that most crazy things happen. This is complete conjecture because I haven't seen your car first hand, but for example if you were to go to something like 4.10 or 4.55 gears then things could get squirrelly with higher RPM launches even if everything else on the car is the same.
At the start it's all about torque and traction. After that it's about RPM and shifting. Then your final ET is a matter of time in the seat, natural ability....oh ya...and money
Shelby Super Snake
Old 05-07-2016, 11:27 PM   #23
Joaquin_ii's Avatar
Medwards. First off thank you for your input. It's greatly appreciated! I went back today and it definitely was a different experience. Got a few more runs in. Stayed consistent around 13.000 best is attached. 60ft is still bad but I improved greatly on my reaction time. Click image for larger version
Name:	ImageUploadedByMustang Evolution1462685181.845367.jpg
Old 05-07-2016, 11:27 PM   #24
Joaquin_ii's Avatar
Btw I was on the rigjt
Old 05-08-2016, 09:50 AM   #25
medwards's Avatar
When I was younger I worked on a lot of early '70's and late '60's cars. I was the pit guy and the car set-up person. I never actually ran the car down the strip. However, I did plenty of runs on the street (kindof embarassed to admit that as I probably did a lot of stupid runs that were dangerous....but I was a kid).
With the super snake and now building the clone, I'm both the set-up guy and the driver so I'm learning personally how hard it is to work on that 60' and the 330' times. One of my buddies I used to pit for is giving me hints on his driving style and I'm still convinced it's about torque and traction. I think all the changes I helped make to his car was 90% of the improvements in his 60' and 330' times. However, he's claiming it was his driving skills. It's been too long for me to remember the details and I never kept records back then.
As I mess with the clone I'm going to be posting different slips to show the incremental improvements with a S550 GT. Being both the setup guy and the driver I will be impartial on what is more important. I figure after the first 10 or so runs I'll see the limit of the stock setup. Then I'll try different tires. Then I'll go back to stock tires with 3.73 gears. Then I'll put the bigger tires on with the 3.73's. Then change suspension components. Etc etc. I think new gears and tires will have more to do with improving your 60' time than driving skill. Suspension and HP will eventually be needed.
I don't yet know enough about tuning (that's my learning curve since I've been out of it so long), so maybe others can give you ideas about tunes that could improve your time before you get to turning bolts.
I'd love to hear the opinions of others on my opinion.
Shelby Super Snake
Old 05-08-2016, 12:08 PM   #26
medwards's Avatar
Oh, forget to say great job as well.
And look at the slip closely. Dude, you knocked 1/2 second off your 60' time! And almost 7/10 off your 330' time! That's awesome. That's also where you made virtually all the gains on the run. Although yuu did pick up another 1/10 along the rest of the run. Probably by having hight RPM's when you shifted.
Watching the video again from that bad run, you need to speed up the shifting between gears and get the RPM's higher when you shift.
Shelby Super Snake
Old 05-08-2016, 12:28 PM   #27
medwards's Avatar
Figured I would share this.
Watch this video for a bunch of things (and then watch the other vids that cycle after it. You'll see some real fast shifting....and you'll see things break with high RPM launches (I'm pretty sure he blew up the driver's side half shaft...you will see a part fly out the back of the car during the 4th try). These guys do a great job. You will find the weak parts of your car with high RPM launches...and that can be a painful lesson. In my mind the trick is to get the fastest time possible WITHOUT breaking your car!
Shelby Super Snake
Old 05-08-2016, 12:33 PM   #28
Joaquin_ii's Avatar
Thanks! Yea I felt a bit more comfortable out there last night. I recorded 2 more but I still haven't been able to lock on to speedo and tach but you can see it more clearly..
https://youtu.be/UYjLsG6WHj0
https://youtu.be/9zwF-HK-AlE
Old 05-12-2016, 08:59 PM   #29
retiredvet's Avatar
Work on getting your 60 foot times down to 1.8 ignore the fella on ur left or right, ignore the tree. Leave anytime after ur light turns green when ur ready focus on ur driving. Get comfortable and good then worry about racing
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 05-13-2016, 09:19 PM   #30
Joaquin_ii's Avatar
Ignore tree? Doesn't the 60ft time start when it turns green? I'll be going back tomorrow so I'll keep trying to bring it down to under 2 secs
Old 12-28-2016, 10:24 AM   #31
PatinMich's Avatar
I know, a little late to the party but I don't get on here too much.
Surprised no one responded to the last post. 60 ft time does not start until YOU move, just like the ET timer. You could sit there for 5 seconds after the light turns green and the only thing running will be the reaction time timer.
PatinMich is offline   Reply With Quote
Old 12-28-2016, 03:14 PM   #32
Joaquin_ii's Avatar
Thanks! I'm not at the track anymore (lol) but thanks brother I appreciate it. I might head back when spring comes and I'll definitely work on that 60 ft
What are you currently listening to? Brent The Bar 11215 09-07-2016 06:12 PM
New guy from Tennessee, currently deployed to Iraq TWNSCRD New Member Introductions & Greetings 10 06-23-2009 05:00 PM
polling - what tires are currently on your car? briansol The Bar 33 10-12-2007 07:17 AM
Yea so I am currently trying to win 2,000 dollars Brent The Bar 10 10-13-2005 05:36 PM
12:21 PM
