2016 Shelby GT350 - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang Rumors | 2017 and 2018 Mustang
Old 11-17-2014, 11:12 AM   #1
2016 Shelby GT350
Badass car. For anyone who hasn't seen it here is the run down (not my words, taken from Road & Track):
"It's finally here. Say hello to the all-new 2016 Ford Mustang Shelby GT350, which picks up where the the 2013 Boss 302 left off, and positions itself to be best-ever example of the ponycar, period.
The outgoing Shelby GT500 was all about violent, face-flattening velocity, teaming 662 upercharged horses with a solid rear axle. Ford’s newest Shelby takes an entirely different approach. Based on the latest “S550” Mustang chassis, it wears a fully independent rear suspension and builds on that with magnetorheological dampers, unique, aero-uber-alles bodywork, and a naturally aspirated 5.2-liter V8 with the long-rumored flat-plane crankshaft. It’s a thoroughly modern pony built for racetracks with apexes instead of those with burnout boxes. For the latter, the Dodge Boys have options if you're interested.
A 5.2-liter all-motor monster
The V8 engine skips forced induction entirely in favor of a sky-high redline—there’s no official number yet, but since this should outdo the Boss 302, we figure 8000+ rpm—and that fancy flat-plane crank, like you might find in a Ferrari. For those unfamiliar, a flat crankshaft design involves attaching the crank pins at 180-degree intervals rather than the usual 90; this allows for a firing order that bounces back and forth between the two cylinder banks with little to no overlap in exhaust pulses.
The engine breathes better as a result, and Ford says that this 5.2 is the most powerful naturally aspirated engine the company has ever produced. Final output is still under wraps, but Ford says we should expect more than 500 horsepower and 400 lb-ft of torque. For comparison, the Boss 302 made 444 horses and 380 lb-ft from a naturally aspirated 5.0-liter V8, and the new Mustang GT gets 435 and 400 from its updated 5.0.
If there’s anything flat-crank engines are known for beyond big revs and a bunch of power, it’s their unique sound. On this point, Ford promises we won’t be disappointed: “Make no mistake, this is an American interpretation of a flat-plane crankshaft V8, and the 5.2-liter produces a distinctive, throaty howl.” The only transmission this engine can be paired with is a six-speed manual. Output is then routed to a standard-equipment Torsen limited-slip differential; a diff cooler can be ordered, and it feeds on airflow directed from the rear diffuser.
Magnetic ride control and big, beefy brakes
As mentioned, the new Shelby features MagneRide, Ford’s first-ever application of the continuously controlled magnetorheological damping system. This setup alters shock stiffness at each corner independently every 10 milliseconds based on the car’s yaw angle and suspension load. The GT350 joins various General Motors vehicles—including the Corvette and the Camaro ZL1—the Audi TT and R8, and multiple Ferraris in offering the technology. In the Shelby, the suspension can be cycled through five modes, which also control steering effort, throttle sensitivity, the exhaust, and programming of the ABS and traction- and stability-control systems.
Compared with the regular Mustang GT, the Shelby has tweaked springs and bushings, a wider front track, and a ride height lowered by an as-yet-unspecified amount. The new Mustang is already a stiff piece, but Ford says rigidity is bolstered here by an injection-molded carbon-fiber-composite grille surround—yes, really, although we’re a bit dubious of its effectiveness—and an optional lightweight strut-tower brace.
Unlike the carbon-ceramic-brake-equipped Camaro Z/28, Ford opted for two-piece iron rotors with aluminum hats for the GT350. They ought to deliver stupefying deceleration all the same, as they measure 15.5 inches up front and 15.0 inches at the rear. Six-piston Brembo calipers squeeze the front discs, while four-piston units are installed at the rear. The new Shelby rolls on 19-inch aluminum wheels—10.5 inches wide up front and 11 inches wide out back; ultra-sticky Michelin Pilot Super Sport rubber with a GT350-specific tread face, sidewall construction, and compound is standard.
As for aesthetics, every body panel forward of the A-pillar is unique to the GT350, with a lower, steeper aluminum hood designed to more tightly hug the engine below. A large central heat extractor maximizes underhood airflow and is said to reduce front-end lift.
The rest of the story, for now...
Aluminum front fenders with larger flares cover the Shelby’s wider rolling stock, while inner and outer fender venting extracts air from the wheel wells and sends it down the car’s flanks. Inlets in the front fascia send air to the front brakes and—with the available Track Pack—to optional coolers for the transmission and engine oil. An aggressive Shelby-labeled front splitter will help downforce and make parking-lot curbing a headache. There’s a low-profile decklid spoiler, an underbelly aero tray, and the aforementioned rear diffuser, too.
Inside, Recaro sport seats and a flat-bottom steering wheel remove all doubt as to the car's mission, and the instrument panel sports reduced brightwork to cut down on glare. An optional Tech Pack brings power seat adjustment and leather upholstery, dual-zone automatic climate control, upgraded Shaker audio, and the eight-inch MyFord Touch infotainment screen.
The 2016 Mustang GT benchmarked the old Boss 302 during its development, and the all-new pony delivered on that promise, jousting with Porsche and Ferrari as a finalist in our 2015 Performance Car of the Year testing. The Shelby GT350 is set to redefine everything we ever knew about not just the Mustang, but pony cars in general—Z/28 be damned. We don't normally advocate the sale of internal organs, but hey, if still you have both kidneys..."
2016 Ford Mustang Shelby GT350 unveiled, ready to hunt Z/28s - Road & Track
Looks like Ford finally took my advice and put in a magnetic ride control lol. Super excited to see how this stacks up against the Z/28 and other higher end exotics.
ID:	169821   Click image for larger version
ID:	169823   Click image for larger version
Old 11-17-2014, 11:19 AM   #2
WJBertrand's Avatar
Wonder what transmission they are using?
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 11-17-2014, 11:21 AM   #3
All we know so far is a speed manual. I want to hear how the engine sounds with a flat plane crank
Old 11-17-2014, 11:21 AM   #4
Rapinator126's Avatar
Hopefully it's not over 60k. I will take 65. But not anymore.
Old 11-17-2014, 11:23 AM   #5
Originally Posted by Rapinator126 View Post
Hopefully it's not over 60k. I can deal with 65. But not anymore.
Old 11-17-2014, 11:24 AM   #6
There is plenty of videos of it on YouTube
Old 11-17-2014, 11:25 AM   #7
With aftermarket exhaust I should have said. Since it won't stay stock in almost any car
Old 11-17-2014, 11:26 AM   #8
Watch "2016 Ford Mustang gt350" on YouTube
2016 Ford Mustang gt350: http://youtu.be/6ktup2kXLwk
Old 11-17-2014, 12:40 PM   #9
It's going to be $60k+ no doubt. Simply cannot justify that price for a Mustang, I don't care how cray cray that is... Wonder if a de-tuned 5.2L is going to be going into the 2017 refresh of the regular Mustang GT tho. Would make sense to introduce a hopped up version for the GT350 and then make it available a year later on the regular unit sort of like Chevy does with the Vette/Camaro.
Old 11-17-2014, 12:44 PM   #10
If it is up to par with the Z28 and costs less then I'd say it's still worth it. $60k is brand new GT500 territory and this is so much more car than a GT500. Especially since it may be battling with the C7 and exotics.
They used more aluminum and even some Carbon fiber in this car, and the magnetic suspension. This is one of the first few Fords where I think a $60k price tag would be justified.
Old 11-17-2014, 12:44 PM   #11
I will buy it, cams, heads, e85, full exhaust. Looking at over 600 at the ground NA. Then a little gas on top of that
Old 11-17-2014, 01:46 PM   #12
Not going to buy a C6 Grand Sport? I mean what just a cam swap for a million HP right? :O
Old 11-17-2014, 01:52 PM   #13
I would rather have this over a vette. Plus my dad is buying a c7 so 1 vette is enough lol.
Old 11-17-2014, 01:52 PM   #14
It's a built road racing car though. You gotta at least do a little bit of what it's built for lol
Old 11-17-2014, 01:53 PM   #15
Just to bad the gt350 does not have the aluminum frame
Old 11-17-2014, 01:57 PM   #16
I will hit the u - turn under the highway at 60 lol,
Honestly I would have to go hit a road course or 2 with it.
Old 11-17-2014, 02:01 PM   #17
It would just be bad *** to see 600+ at the ground NA on this motor. Thats over 2 hp per cubic inch to the flywheel. And verry possibly to get 2 hp per cubic inch at the tires hopefully.
Old 11-17-2014, 02:35 PM   #18
Supposed to be 8-9k rpm stock. Do some more valvetrain work and get it to 10k lol
Old 11-17-2014, 02:39 PM   #19
That would be nasty. Especially with a long gear. 70 mph in first, depending on what transmission they go with. It will probably be the TR- 6060.
Old 11-17-2014, 02:40 PM   #20
Spy shots show the Getrag shift pattern tho...
Old 11-17-2014, 02:41 PM   #21
Dam didn't catch that one, only seen the outside.
Old 11-17-2014, 02:47 PM   #22
Hopefully its something besides the MT82
Old 11-17-2014, 02:50 PM   #23
I doubt it will be, it's going to be a tremec I'm sure.
Old 11-17-2014, 03:05 PM   #24
Is there a Tremec currently or in the works that has reverse in the top left?
Old 11-17-2014, 03:08 PM   #25
^ not that I'm aware of, hopefully they just put that shifter knob, on purpose lol.
Old 11-17-2014, 03:09 PM   #26
Lol that would be an ******* bait and switch move by Ford and one that I would totally do if I was them.
Old 11-17-2014, 03:52 PM   #27
All it needs is a HUD and TR6060 and I'm sold. I will start saving up lol
Old 11-17-2014, 03:53 PM   #28
I wonder if they got rid of the MacPherson front set up for an SLA. Hopefully but probably not
Old 11-18-2014, 06:54 AM   #29
If they are truly 100% serious they will have done it. If not its a failure on the front suspension no matter how much crazy **** they stuff into it.
Old 11-18-2014, 09:09 AM   #30
It's a tremec, 3160
Old 11-18-2014, 09:19 AM   #31
Laquisha's Avatar
Looks cool. I would rather have a h/c/i vette 😄
Soccerluvr4 wuz here
Old 11-18-2014, 10:43 AM   #32
Lorraine's driver
ab_mach1's Avatar
Lol, Vette's are for old people.
Instagram: @ab_mach1
Old 11-18-2014, 11:08 AM   #33
Or men in the middle of a mid life crisis...
Old 11-18-2014, 11:15 AM   #34
Same thing...
Old 11-18-2014, 11:30 AM   #35
Just looked up the 3160. Seems like a solid trans and only 100lbs or so too. Ratios are:
5.00 3.74 3.35 4.10
3.09 2.38 1.99 2.20
1.83 1.76 1.33 1.50
1.29 1.34 1.00 1.21
1.00 1.00 0.80 1.00
0.74 0.66 0.60 0.74
My guess is they will roll with the 2nd ratio with the 1.00 5th and .66 OD for a purpose built road racer. Although they could always pair the 1st gearset with a lower overall rear drive gear with that 5.00 1st...
Spec Sheet
2016 Ford Mustang Shelby GT350 - Official mark0006 Mustang Rumors | 2017 and 2018 Mustang 102 06-29-2016 07:22 AM
2016 Shelby GT 350 samuelsmith General Mustang Discussion 1 07-19-2014 10:55 AM
Shelby Gt 350 :: 2012 Ford Shelby GT350 SKSaleen Member Garages 2 09-17-2013 07:39 PM
11:54 AM
