Ghetto Intake Ver. 2 - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 08-02-2012, 05:38 PM   #1
Sanguin's Avatar
Version 1 and it's respective thread can be found here: Ghetto Intake I would have continued there but I couldn't edit the main post or add more attachements, so onward!
I told you guys the PCV line could be improved and I was sitting around thinking it had the same style attachment on either side... Bingo. Buy a PCV valve, gut it, and use it in the intake tube for a fitting. A call to my bud at the parts department at Ford and $6 later I had one.
First, remove the check valve. The bottom has a retainer you can remove to gut it. I just stuck a 1/4" ratchet extension in the opening and twisted. I was surprised how easy it came out. Of course, before this I tried beating the crap out of it from each end because I was unsure how the valve was installed. Anyway, that was simple enough.
Next, I took a section of pipe, marked the position I needed, drilled it out, then cut a hole with a dremel to match the pcv valve. I actually got such a tight fight I think the o-ring will seal it for me. I had to push rather hard to get it in. Later, I might put a bead of silicone around it or epoxy it, but it seems fine as is for now.
Fit like a dream. However, I noticed another issue. My air filter had come to rest on the ABS unit corner and it was eating into the air filter. To remedy this, I shortened the intake tube a bit and put zip ties around it and tethered it to the fender pulling it down and away from the ABS unit. I didn't want the filter vibrating against the fender eating paint off either, so I made a small cushion by folding a piece of the old PCV hose into a U shape and placing it under the filter nose. There are two perfect holes for this tubing to loop through to hold itself there. Hopefully, you can see it in the pics. Next, is figuring out an airbox. Enjoy!
ID:	61924   Click image for larger version
ID:	61926   Click image for larger version
ID:	61928   Click image for larger version
ID:	61930   Click image for larger version
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 08-02-2012, 06:00 PM   #2
The Kraken's Avatar
Just got done reading version 1 great project not what I expected at all now just have to get that red to green and that's going to look killer
The Kraken is offline   Reply With Quote
Old 08-02-2012, 06:23 PM   #3
NicholasP's Avatar
I want this!
NicholasP is offline   Reply With Quote
Old 08-02-2012, 06:29 PM   #4
BlackedStang's Avatar
+1 thats awesome man
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 08-03-2012, 01:36 AM   #5
alrefire's Avatar
Re: Ghetto Intake Ver. 2
iit's really not a ghetto intake, it's better than half the freakin intakes out there!
I give you props man! good job!
Old 08-03-2012, 08:10 AM   #6
pwrby4d's Avatar
Great Job. Maybe make kits and sell them.
---------- Post added at 09:10 AM ---------- Previous post was at 08:56 AM ----------
Cant wait to see what you do for a heat shield. Looks awesome.
pwrby4d is offline   Reply With Quote
Old 08-03-2012, 08:29 AM   #7
Sanguin's Avatar
You won't believe my idea I came up with for a faux gas cap replacement. I'm codenaming it Shadowbox. I just hope I can make it work as well as this.
Old 08-03-2012, 09:11 AM   #8
CYCLON37's Avatar
Is it a ghetto gas cap
CYCLON37 is offline   Reply With Quote
Old 08-03-2012, 03:17 PM   #9
Sanguin's Avatar
It is now. Welcome to the Sanguin line of Ghetto Mustang parts! Ill have to wait until.I have a few days off to remove the stock assembly. I don't want to get a naked rear while it's down. Its also going to have a wiring harness with two relays for a special lighting configuration that I've already planned out.
Old 08-04-2012, 07:12 AM   #10
Gtzzoom's Avatar
link to a company that sells green air filters.
the 2037 is too long to fit in my airaid box
Part #2037 Green Performance Cone Filter 4" Mounting 5"w x 9"L
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
Gtzzoom is offline   Reply With Quote
Old 08-04-2012, 08:48 PM   #11
Blogger
99ford's Avatar
That is an awesome find Gtzzom! thanks again sanguin! It sounds great!
Old 04-03-2013, 04:50 PM   #12
Charlie_santos's Avatar
Seems legit bro
Old 06-05-2014, 04:37 AM   #13
audioAl's Avatar
You should try marketing the CAI, I believe many would pay $100.00 if shipping is included.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-05-2014, 07:21 AM   #14
pwrby4d's Avatar
I ended up eventually scoring an airaid and a tuner and still have the maf sensor housing and the metal heat shield if anyone is interested. They would need to get the tube and some couplers and a filter.
Old 06-05-2014, 08:02 AM   #15
NicholasP's Avatar
We'll this is quite an old thread revived haha
Old 06-05-2014, 08:07 AM   #16
pwrby4d's Avatar
Ya lol
Old 06-05-2014, 08:12 AM   #17
Strange Mud's Avatar
Remember to post on your sale sight:
Gains up to 20 HP and 2-3 mpg.
sweet looking and priced right...I love what I call Yankee Farmer mods.
Old 09-13-2014, 11:50 AM   #18
Littleeerik's Avatar
Would this work for an 03 V6 Mustang?
Littleeerik is offline   Reply With Quote
» Members Mustangs
virgina
emerson
GIXX
Gixx
Add your Mustang
06:42 AM
