Pre 2005 V6: How to: 4.2L V6 Mustang Engine Swap - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Closed Thread
Old 10-12-2004, 06:25 AM   #1
I have seen many questions...but few facts. This is what you need. I converted my 99 4 years ago.
Early 97-98 4.2s had a 2-pc main girdle that connected the 1st to the 2nd main cap and the 3rd to the 4th main cap and had larger main bolts. Mid-1998 and up 4.2s used a 1-pc girdle that only connected the rear 3 main caps and had smaller main bolts.
To use the early 4.2 in any Mustang will require replacing the girdle with a newer 3 main style from a 4.2, a 99-up 3.8 girdle or just delete it. You will also have to cut the girdle studs sticking out of the head of the main bolts on the 1st main bearing. The 99-00 3.8s used a factory windage tray/girdle that is better than nothing but certainly not ideal. The 01-up 3.8s use the same windage tray/girdle as the 4.2.
Late 00 3.8s are actually early 01 spec engines that are internally balanced. If you have one of these.....just use the notes for an 01-up.
Edit by 97Stallion: here's some extra info. 97-98 4.2L engine are directly compatible with 94-98 3.8 crank pulleys. So if you have a 97-98 4.2 crank and balancer, you can use your 3.8 crank pulley/underdrive pulley.
94-98 Single port heads
- 4.2 shortblock
- Single port heads/fuel rail/intake
- Mustang 3.8 water pump
- Auto trans = 4.2 or 01-up flexplate
- 5spd = 01-up or rebalanced 3.8 (0 or neutral) flywheel and a pilot bearing
- V6 Mustang bellhousing
- Re-use your stock cam position sensor
- 01-up 3.8 oil pan
- 01-up 3.8 oil pick-up tube and screen
- 4.2 damper or 01-up 3.8 damper (use the 01 pulley for blower cars)
- Re-use the stock 3.8 oil pressure sender and tube
- Re-use the Mustang headers
- You can use the 4.2 or 3.8 dipstick. Just keep track of where 5 qts puts the mark when refilling with oil.
94-98 Split port heads
*** You will need to perform all the mods required for a split port conversion plus these steps for the 4.2 (see pbmilan or V6sprout for the video) ***
- 4.2 shortblock or longblock
- You can use the 4.2 heads
- Mustang upper and lower intake
- Custom return style fuel rail (VMP has them)
- 01-up 3.8 oil pan
99-00 split port heads
- Mustang upper and lower intake and fuel rail
- 01-up 3.8 oil pan
01-up split port heads
- Auto trans = your stock flexplate
- 5spd = your stock flywheel and a pilot bearing
- Your 01-up 3.8 oil pan
- Your 01-up 3.8 oil pick-up tube and screen
- Your stock 01-up 3.8 damper
http://www.fordchip.com
Featuring Superchips Custom Tuning products
'99 4.2L 5-spd, Powerdyne, CNC'd heads, 211/.523 cam, 70mm TB, 1.8 RRs, JBA headers, custom X off-road, 90mm SCT, 60#s, Mach I duals, Ripper, PHP 8.8, Steeda UCAs, LCAs, 3.73s, Alum driveshaft, 245/45R17s on Silver Bullitts
11.3 @ 122 (ET Streets)
465 rwhp/460 ft/lbs (25hp dry shot)
12/00 MM & FFs, 7/01 5.0 & Super Ford, 2/02 Hot Rod
pete is offline
Closed Thread
Christmas - What did get for your Pre - 2005 V6? 03Sixtang The Bar 4 12-28-2012 03:00 AM
Painted Pre 2005 interior Crowned1 Pre-2005 V6 Mustang 2 10-12-2012 06:41 PM
What can you do to a pre-2005 V6? Bsheiry Pre-2005 V6 Mustang 27 02-17-2012 12:26 AM
Engine swap in a 2005 v6 mustang? lachlan General Mustang Discussion 4 03-25-2010 06:52 PM
11:13 AM
