How to : Caster Camber Plates - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 05-05-2014, 07:14 AM   #1
Slow4V's Avatar
A little write up on how to install some CC plates on your mustang.
Tools needed :
1/2 impact
3/8 impact
Drill
Drill bits ( 1/8 , 13/32 )
Hammer
Jack
Jack stands
Tire blocks
Scribe
19 , 21, 15mm sockets
3/8 ratchet
Grease
Dikes
1. jack up car, place the jack stands properly , block the rear tires with blocks. And begin to remove your front wheels with your 19mm or 21mm.
2. Once you have the mustang on the stands, place your jack underneath the front control arm on the side you want to start on first. Raise the jack up so it puts tension on the spring
Name:	ImageUploadedByMustang Evolution1399294264.196225.jpg
3. Remove the sway bar endlink, so that the control arm can fully drop down fat enough to move the strut out of the fender well. I used a 3/8 impact and 15mm deep socket.
Name:	ImageUploadedByMustang Evolution1399294320.500275.jpg
I had to loosen up my speed sensor and caliper because I didn't want to damage any lines
Name:	ImageUploadedByMustang Evolution1399295626.665206.jpg
Name:	ImageUploadedByMustang Evolution1399295640.527589.jpg
4. Remove the top nut on the strut , and discard the big washer and rubber mount. Keep the nut
Name:	ImageUploadedByMustang Evolution1399294376.864723.jpg
Go ahead and remove the 2 nuts and 1 bolt that hold the bracket down, and drill out the rivets that may hold it down as well. Click image for larger version
Name:	ImageUploadedByMustang Evolution1399294449.919088.jpg
5. Go ahead and remove the dust boot on the strut , and remove the clamp and bump stop. And with the new bump stop install it with the cone facing up, and ziptie it to the dust boot.
Name:	ImageUploadedByMustang Evolution1399294550.026835.jpg
Name:	ImageUploadedByMustang Evolution1399294571.597811.jpg
I greased the inside
7. Now you have to drill a 4th hole for the new bolt on the bracket kit. Use the Ford top plate removed earlier as a template. Rotate it 180° from the stock position. Align the Ford top plate with the inside edge of the factory cut holes in the strut tower. Scribe the position of the fourth hole into the paint of the strut tower.
Name:	ImageUploadedByMustang Evolution1399294639.921692.jpg
Name:	ImageUploadedByMustang Evolution1399294684.722564.jpg
Now align the Ford top plate with the outside edge of the factory cut holes in the strut tower. Once again, scribe the position of the fourth hole into the paint of the strut tower.
After scribing with the Ford top plate in both positions, find the intersection created by the 2 markings.
Name:	ImageUploadedByMustang Evolution1399294740.134177.jpg
Center punch the middle of the intersections , and start by drilling a 1/8 hole , and work your way up to a 13/32 hole.
8. Now place the bracket from underneath the strut tower to see if it fits Click image for larger version
Name:	ImageUploadedByMustang Evolution1399294854.850825.jpg
Very important you put the the right side on the right side..
Name:	ImageUploadedByMustang Evolution1399294931.635775.jpg
9. Install the MM main plate over the 4 studs and the ¼”thick washers. Place a provided 3/8” washer, followed by a provided hex nut (14 mm) over each of the four studs. Turn the 4 hex nuts down, but do not fully tighten yet to allow for later adjustment. Use the below image provided by Maximum Motorsports to correctly orient your two provided main plates.
Name:	ImageUploadedByMustang Evolution1399294979.113136.jpg
Name:	ImageUploadedByMustang Evolution1399294997.146327.jpg
Note: It is important that you correctly choose the orientation of your MM bearing plates. They may be oriented in either a positive or negative fashion. Most street cars will be oriented positively while most race cars will be oriented negatively.
Use the below images provided by Maximum Motorsports to choose the orientation of your bearing plates.
Name:	ImageUploadedByMustang Evolution1399295176.235965.jpg
Name:	ImageUploadedByMustang Evolution1399295189.136509.jpg
10. Go Ahead and install the bearing on top, leave the nuts on the plate and bearing somewhat lose so you can move it around
Name:	ImageUploadedByMustang Evolution1399295211.839221.jpg
Since my car is lowered MM required for me to put 1 short spacer on bottom, 1 short spacer on top and 2 big spacers on top of that.
Name:	ImageUploadedByMustang Evolution1399295315.410387.jpg
Name:	ImageUploadedByMustang Evolution1399295336.745458.jpg
Guide the strut shaft back through the center hole of the bearing plate, after selecting the proper type and number of spacers to be applied below and above the bearing plate, along the strut shaft.
The manufacturer suggests that for vehicles at stock ride height, 2 long spacers and 1 short be placed below the bearing plate, while 1 short spacer is placed above the plate.
Before reinstalling the strut top nut, be sure to very carefully check hood clearance with the new components. It is wise to use a small amount of "Play-Doh" or silly putty placed on top of the strut shaft while closing the hood. The amount of smashed in putty will clearly show how much hood clearance you have. If there is too little clearance you can relocate one spacer from above the bearing plate to below the bearing plate, thus lowering the strut shaft relative to the spherical bearing plate.
NOTE: Hood clearance may change after an alignment. Be sure to recheck clearance after an alignment has taken place.
Name:	ImageUploadedByMustang Evolution1399295413.598983.jpg
For vehicles at a lowered ride height, it is suggested that your place 1 short spacer below the bearing plate and 2 long spacers, as well as 1 short spacer above the bearing plate.
Name:	ImageUploadedByMustang Evolution1399295424.537659.jpg
Guide the strut through the bearing hole, becarful to align the sway bar end link through the sway bar as well.
Name:	ImageUploadedByMustang Evolution1399295466.603080.jpg
Name:	ImageUploadedByMustang Evolution1399295496.167753.jpg
Make sure everything's tight, and tighten down the top nuts with your 3/8 ratchet, and install everything back to your mustang.
I know this might be a little confusing but I hope it helped.
Name:	ImageUploadedByMustang Evolution1399294461.659438.jpg
Old 05-05-2014, 10:40 AM   #2
H.Doofenshmirtz's Avatar
Region: Australia
Dig it man, thx for the write-up.
About how long did it take per side/total?
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 05-05-2014, 11:05 AM   #3
mystang50's Avatar
nice wright up!!
Old 05-05-2014, 02:40 PM   #4
Slow4V's Avatar
2 hours on the first one because the directions were so difficult to understand lol!
Other side took like 45 min
Old 05-14-2014, 07:15 PM   #5
Nice, now hopefully your hood has a little more clearance than mine. I have rub marks over where the struts are but its not bad and it has not got worse in 2 years.
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Caster/Camber Plates...will they be a problem with this? Joel5.0 1979-1995 Mustang GT 4 10-22-2005 04:36 PM
Steeda Springs - Do I need caster camber plates? audioqueso Pre-2005 V6 Mustang 8 12-05-2003 05:34 PM
10:55 PM
