DIY 2003-2004 Mach 1 , 1999-2001 Cobra Intake Manifold Spacer - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 05-10-2014, 10:56 PM   #1
Slow4V's Avatar
Tools used
3/8 impact
3/8 extensions
1/4 Ratchet
Mini die grinder
Buffing pads
10mm
8mm
12mm
1. Remove shaker ( 2 ) 10mm Bolts on the sides , and remove the 2 hoses on the front right side. For Mach 1
Name:	ImageUploadedByMustang Evolution1399783337.303895.jpg
Name:	ImageUploadedByMustang Evolution1399783370.931398.jpg
2. Remove shaker bracket ( 4 ) 10mm bolts
Name:	ImageUploadedByMustang Evolution1399783395.168007.jpg
3. Remove Throttle cable by moving it to WOT position and routing the cable out , remove the plastic cable, and spring too.
Name:	ImageUploadedByMustang Evolution1399783454.194102.jpg
Name:	ImageUploadedByMustang Evolution1399783480.189655.jpg
Name:	ImageUploadedByMustang Evolution1399783546.196810.jpg
4. Unbolt the throttle bracket (2) 10mm bolts, and start unhooking all the obvious sensors , and hoses. Including removing the EGR (2) 10mm bolts
In the back of the manifold towards the firewall there are 2 hoses as well.
Name:	ImageUploadedByMustang Evolution1399783574.199172.jpg
Name:	ImageUploadedByMustang Evolution1399783633.203577.jpg
Name:	ImageUploadedByMustang Evolution1399783674.463520.jpg
Name:	ImageUploadedByMustang Evolution1399783696.294733.jpg
5. Start unbolting the intake manifold
8mm , I used a 1/4 ratchet.
Name:	ImageUploadedByMustang Evolution1399783783.221255.jpg
Name:	ImageUploadedByMustang Evolution1399783833.267337.jpg
6. I cleaned up the top with my die grinder and Buffing pad , along with intake cleaner , and blowing it dry with my blow gun. Making sure to NOT get any sensors wet ( TPMS, IAC ) and NOT go damage EGR gasket.
Name:	ImageUploadedByMustang Evolution1399783856.524634.jpg
Name:	ImageUploadedByMustang Evolution1399783935.837804.jpg
7. Install the spacer REUSING your old gasket as well as the new one. Gasket - spacer - Gasket
USE the new bolts .. They are longer , only reuse the longest bolts. Which is the middle bolt, and bolt to the front right, and torque them down to 90-100 Inch LBs , I didn't use a torque wench I just tightened them by hand.
Name:	ImageUploadedByMustang Evolution1399784005.878311.jpg
Name:	ImageUploadedByMustang Evolution1399784122.761779.jpg
8. Install everything you took off , double check your work, and test drive.
Name:	ImageUploadedByMustang Evolution1399784155.583785.jpg
Hope this helped anyone!
I got my spacer from Pauls High Performance , and very happy with their product. I felt a noticeable low end TQ
intake manifold spacer lancer070187 1979-1995 Mustang GT 2 07-15-2013 08:04 PM
2004 mach 1 vs. 2004 svt cobra Michaelgranlund 1996-2004 Mustang GT 32 03-08-2013 07:19 PM
2003 Cobra Vs. 2004 Mach 03whitey SVT Mustang 19 02-02-2013 12:31 PM
intake manifold spacer. Java Pre-2005 V6 Mustang 3 12-14-2012 05:36 PM
trick flow plenium with spacer , CAI, pi stock intake manifold. southernstang00 Mustang Parts for Sale and Wanted 8 09-12-2012 11:14 AM
11:05 AM
