fuse 47 pull - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 05-12-2014, 05:52 PM   #1
mikeygaga's Avatar
fuse 47 pull
Ok guys I needed to get on here and share this piece of information for the people who don't know or are experiencing similar frustrations. I have been having throttle and shift problems in my automatic for a while now and it was reallyyy starting to take the fun out of my car. Let me explain.. I would tune my car, it would run amazing (immediate throttle response, fast shifts) for a couple days then it would start losing performance as time went on. (Somebody else even made a thread a couple weeks ago with the same peoblem). This was to the point where the car felt like it was running like ****. Then I would re tune and all was well again. It was a vicious cycle.
I came across a thread on another forum where people had the same problem. When the car started to feel sluggish they were pulling the #47 fuse in the engine fuse box for about 10 minutes then plugging it in and the car would run great, so I decided to give it a try. Let me tell you, the car was an absolute beast after I did this. I was so happy. Now I know it's just replacing re tuning with pulling a fuse but it's so much more convenient and seems to work better. Anybody have any experience with this? I've read of people who swear by it.
2016 GT- Lund tune, jlt intake, mbrp catback.
2014 3.7 - SOLD
mikeygaga is offline   Reply With Quote
Old 05-12-2014, 06:45 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Yeah fuse 47 is one of your PCM power fuses. I'm willing to bet it's the one that provides a trickle charge to your PCM so that it doesn't lose the data it uses to adapt to your driving. Pulling that interrupts the power, thus resetting the car's adaptive driving. I thought that tunes disabled this, but that may not be true.
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 05-12-2014, 06:52 PM   #3
mikeygaga's Avatar
Yea its my dd so I usually sit in traffic every morning which is probably screwing with the adaptive shifting. I've read that tunes do not disable it. Im going to give mpt a call in the am to verify this. It's extremely annoying.
2014 3.7 - SOLD
Old 05-12-2014, 09:52 PM   #4
ironsurvivor's Avatar
If your car is tuned and you pull that fuse, do you have to reload the tune after putting the fuse back?
Stark 30 huper optik tint, jlt oil separator, mmd window louvers, airaid cold air intake.
ironsurvivor is offline   Reply With Quote
Old 05-12-2014, 10:02 PM   #5
mikeygaga's Avatar
Nope the tune stays loaded. It only resets the adaptive shifting.
2014 3.7 - SOLD
Old 05-12-2014, 10:03 PM   #6
Ok cool!
Old 05-12-2014, 11:00 PM   #7
I believe if you have an Sct tuner you can go about resetting it with that instead of unplugging it each time. Don't quote me on that though.
Colby2013 is offline   Reply With Quote
Old 05-13-2014, 06:43 AM   #8
08Mustang's Avatar
Is this the same for the 4.0 computer?
08Mustang is offline   Reply With Quote
Old 05-13-2014, 07:00 AM   #9
mikeygaga's Avatar
Not sure. I don't know if the 4 liters have the adaptive shifting.
2014 3.7 - SOLD
Old 05-13-2014, 07:04 AM   #10
08Mustang's Avatar
Neither do I. It just feels like my car doesn't have quite the throttle response and shift firmness that it did when I first tuned it. However that could just be me being used to it now
Old 05-13-2014, 05:43 PM   #11
smurf stang's Avatar
I would call your tuner and see if they could disable that.
2016 VW GTI 2.0 Turbo
Old 05-13-2014, 07:15 PM   #12
bazinga11's Avatar
Fuse 47/big glassy fuse on far left handside corner is your answer to that lost throttle response. Heck my stock tune feels like a custom tune once I reset this relearning thing.
Oh and mine is a manual tranny!
|| BlackOnBlack ||
Old 05-13-2014, 10:15 PM   #13
Gdocumet's Avatar
Would one have to repeat this reset between time intervals or is it a one time thing?
Gdocumet is offline   Reply With Quote
Old 05-13-2014, 10:17 PM   #14
Time intervals. When the car starts to feel like crap you just do it again. Usually every 2 or 3 weeks
Old 05-14-2014, 08:10 AM   #15
somedopebeats's Avatar
Bucko explained this in another thread, theres a way to make it reset itself when you start the car up i believe.
somedopebeats is offline   Reply With Quote
Old 05-14-2014, 08:35 AM   #16
Sterlingbeast5.0's Avatar
I have never noticed the drop but it sounds like this is only a thing for automatics correct?
Old 05-14-2014, 08:58 AM   #17
There's a wiring mod you can do that everytime you start the car it will reset
Old 05-14-2014, 09:11 AM   #18
Yup.
Help!!!! Bogging issue!
OP, pm bucko. Hes great, he'll help ya out
Old 05-14-2014, 01:23 PM   #19
Jaylg86's Avatar
Can anyone clarify if you really have to pull fuse 47 even if you have a custom tune? I though the tune would suffice to take care of all these issues
Jaylg86 is offline   Reply With Quote
Old 05-14-2014, 01:40 PM   #20
bazinga11's Avatar
If you're car is not as responsive as it was before when you loaded your custom tune, then yes you gotta pull your fuse 47.
- both auto and manual transmission.
|| BlackOnBlack ||
Old 05-14-2014, 01:42 PM   #21
Best way to know for sure is to call or write your tuner and ask him if he has disabled your adaptive shifting in the autos.
Old 05-14-2014, 04:24 PM   #22
mikeygaga's Avatar
I'm not sure if they can disable it. I have tunes from both bama and mpt and this happens using both. I haven't had time to call either to ask as I've been really sick the last couple days.
2014 3.7 - SOLD
Old 05-14-2014, 05:32 PM   #23
Jaylg86's Avatar
I'm going to call bama so I'll keep you guys posted if I find out..
Old 05-14-2014, 08:20 PM   #24
Just send them an email.
Old 05-14-2014, 10:36 PM   #25
2011 Kona Blue's Avatar
Just curious! Do all the year models have this adaptive shifting crap? I ask because I have been running performance tunes in my 2011 3.7 for approximately 3 1/2 years and never have I had a lack of power. Not once have I lost my awesome throttle response. So it makes me wonder, do the 2011-12 models have adaptive shifting or is that something new for 2013-14 models?
Sent from my little Johnson.
Old 05-14-2014, 10:41 PM   #26
Midnight2012's Avatar
Yes we all have adaptive learning in the automatics.
Midnight2012 is offline   Reply With Quote
Old 05-15-2014, 06:05 AM   #27
Hummmmm. I wonder why I'm not experiences this issue as well. Also what is the solution to this fuse 47 business for a permanent fix? The tunning companies can't turn off the adaptive shifting feature
Old 05-15-2014, 07:02 AM   #28
Just kind of a shout out. Has anyone asked Dan or anyone from AM to chime in about this?
Old 05-15-2014, 08:46 AM   #29
Yes we need to hear from the tuners AM, MPT, Lund, Steeda if the adaptive shifting can be turned off.
Old 05-15-2014, 10:20 AM   #30
bucko's Avatar
At least with an MPT tune, I have no issues with my automatic and it's shift points. What happens is that your Mustang "learns" your shift points...so if you do drive stop and go in the city for a week, then go out to the highway, your automatic transmission shift points will seem somewhat sluggish. Pulling fuse 47 will clear these, and all is well....for awhile, until the learned shift points are once again stored.
i believe my MPT tune killed this, as my shift points seem to be the same, be it with city driving or highway driving.
If you do not have a tune, there is a wiring mod that can be done that kills power on fuse 47 everytime you shut off/start the car, so it's like removing it to clear the memory.
Old 05-15-2014, 10:33 AM   #31
MustangDawg's Avatar
There's another thread that's discussing this:
Car relearn and bama tuner question.
But it appears to be more related to the 2013-14 V6 than the 2011-12 V6 models. I agree that it would be nice if AM & Bama got involved on this issue on this forum. I can't figure out why they won't step up
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 05-15-2014, 01:25 PM   #32
David Young's Avatar
|| BlackOnBlack ||
My fuse 47 on my 2011 automatic is a small 15 amp fuse in the middle of 5 other small fuses. On the left side but almost in the middle of the box.
David Young is online now   Reply With Quote
Old 05-15-2014, 02:01 PM   #33
Yeah, it's the same on my '13 V6 auto. It's the one I've been pulling for 10 minutes every other weekend. No big deal, just curious if it could be overridden when I get a tune. Other than that, I don't have a problem pulling it. I check the fluids and tire pressure every other weekend anyway.
Old 05-15-2014, 02:26 PM   #34
Read this.....
Permanent removal of adaptive shifting in your auto V6. - Ford Mustang Forums
Old 05-15-2014, 03:12 PM   #35
Originally Posted by smurf stang View Post
Yeah, read that about 9 month ago. I'm more interested in finding out if this can possibly be handled by a tune primarily for the 13-14 V6. Thanks anyway
Fuse/fuse box Iamiguel 2005-2010 V6 Mustang 1 06-15-2012 05:16 PM
Pull up your pants...NOW!!!! PureVenom The Bar 8 06-14-2007 04:07 PM
Whats this tard trying to pull?? SpectorV The Bar 1 11-01-2005 06:38 PM
autozone won't pull my cel code!? candmforever Pre-2005 V6 Mustang 8 12-10-2003 09:19 PM
99 FR350 DYNO pull 99FR350 Pre-2005 V6 Mustang 4 10-11-2003 03:09 PM
04:38 AM
