Lost horsepower - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 06-27-2014, 02:59 PM   #1
phillip433's Avatar
Lost horsepower
So I put about 10000 miles on it since I last bought it from previous dealer. Few mods, stage 2 cams, 3.73 gears, long tubes headers. Stage 3 spec 2 clutch,tune, exhaust, yatta yatta yatta, anyway. I raced a few STOCK GTs and they either beat Me or keep up with me... I just bought nitrous and I plan on putting it on but Obviously my 2003 gt isn't running at its full potential so I'm holding that off for awhile. Also my gas mileage could improve. I already replaced the spark plugs, just bought accel coil packs, going to get a fuel filter today after work, anything else I should look into? Is a compression test necessary for this kind of thing, bad tune? Any possibilities why I'm not making the amount of hp I should be making. Thanks
phillip433 is offline   Reply With Quote
Old 06-27-2014, 03:05 PM   #2
Rapinator126's Avatar
What year gt 's? bc if it's the 11+ 5.0 your still down at least 70-90 hp from a bone stock 5.0.
Rapinator126 is online now   Reply With Quote
Old 06-27-2014, 03:06 PM   #3
phillip433's Avatar
Lost horsepower
I have a 2003 and all the others ones I lost to was 99-04 GTs ... I know better nt to race a 5.0
Old 06-27-2014, 03:25 PM   #4
Well then something is definitely wrong. Who are you tuned by?
Old 06-27-2014, 03:59 PM   #5
phillip433's Avatar
Dv8 performance put my car on a dyno and gave me a 87 and a 93 octane tune on my sct tuner. Currently running 87 now with 93 octane. At the time. I was running 93 octane tune with 93 octane.
Old 06-27-2014, 04:26 PM   #6
What kind of power did it put down?
Old 06-28-2014, 02:47 AM   #7
clark_kent91's Avatar
I'd look into a new throttle body around an 85mm and get it pro tuned.
clark_kent91 is offline   Reply With Quote
Old 06-29-2014, 03:11 PM   #8
phillip433's Avatar
I don't know the dyno specs because it was dynoed by the previous owner.
---------- Post added at 09:11 PM ---------- Previous post was at 09:11 PM ----------
And will the tb make that much if a difference?
Old 06-29-2014, 03:34 PM   #9
2 Stangz's Avatar
Region: Nevada
How much weight have you gained since you bought the car?
Old 06-29-2014, 03:40 PM   #10
Throttle body will not fix your problem lol
No a compression test and a leak down.
If all I'd good bring it to a good shop and put it on the dyno and work on the tune
---------- Post added at 04:40 PM ---------- Previous post was at 04:40 PM ----------
* do a
Old 06-29-2014, 05:25 PM   #11
phillip433's Avatar
That's what I was thinking. I think it's all on the tune.
Old 06-30-2014, 01:02 AM   #12
Throttle body would be my next upgrade it won't fix ur issue or add that much power but it will improve throttle response .
Old 06-30-2014, 02:05 AM   #13
Hellish Horse's Avatar
Are you running cats ? Are you sure one of them aren't going out if you are? You will lose a lot of power when they start to go...or at least I did. After changing them...it was All Good again.
Maybe one of them is clogged.
Hellish Horse is offline   Reply With Quote
Old 06-30-2014, 02:49 AM   #14
phillip433's Avatar
Bbk long tunes > o/r xpipe to flowmaster 40 series. No cats.
Old 06-30-2014, 02:15 PM   #15
Well that eliminates the Cats for sure. I take it the car was running fine after you did your mods ? Sounds like you drove it for a while & even had a few races ? I'm kind of wondering if you might have a leaky Head Gasket, Warped Head or something like that.
I'd do a compression check just to eliminate that. $29.95 at Harbor Freight. Not top quality...but how many times do you think you'll use it? I'm only saying this because if your car was running fine with the Tune you had & then started losing H.P. later ...I just can't see it being your Tune unless you added more mods.
Old 06-30-2014, 02:17 PM   #16
Scotty will eventually jump in on this. I'm sure he'll point you in the right direction.
Old 06-30-2014, 02:25 PM   #17
Wait a minute...Am I reading this right? You're running 87 Octane Gas on a 93 Octane Tune? If you are I'm guessing that's your problem.
Old 07-04-2014, 12:53 PM   #18
phillip433's Avatar
Lost horsepower
No no no no. 89 tune with 93 octane fuel on my tank.
Old 07-04-2014, 01:00 PM   #19
phillip433's Avatar
The previous owner bought brand new heads. That might be a problem there. They took the oil pan off and put it back on. And it's leaking around there. The whole engine is covered in oil but its not where it effects the oil level in the engine. I recently had to take the valve covers off to replace a broken valve spring and that's when I noticed they had brand new heads.
Old 07-08-2014, 03:12 PM   #20
phillip433's Avatar
So I got a 75mm throttle body and also 24lb fuel injectors. Seems to have quite more power. I think i still can get more out of her. I'm goig to put it on the dyno next week to see what the numbers are.
My horsepower is faster than your horsepower Lalayla The Bar 24 03-17-2011 09:12 PM
Lost horsepower. Need help! DarkShadows 1996-2004 Mustang GT 10 11-22-2010 07:13 AM
Kobe Bryant has lost some weight. MusclesFromBrussels The Bar 11 11-08-2003 12:30 PM
America Has Lost one of Its Greatest Rellik The Bar 1 07-28-2003 12:08 PM
WOOHOO!! I barely lost to a CIVIC HATCHBACK! BlackStang232 Pre-2005 V6 Mustang 19 07-25-2003 03:28 PM
04:24 AM
