HID problem! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 06-27-2014, 04:50 PM   #1
Joe_Roma5's Avatar
HID problem!
I had an hid bulb go out so i ordered new ones, put them in and they started flickering consistently. So i ordered a relay harness, and they're STILL flickering. Ballasts are connected through capacitors as well. Grounds are good, now i am stumped. Any suggestions would be greatly appreciated.
Sent from my LG-LS970 using Mustang Evolution mobile app
'06 4.0 V6 custom x pipes, cai, screamin demon coil pack, 10mm live wires spark plug wires, NGK iridium plugs, 93 octane bama tune
Joe_Roma5 is offline   Reply With Quote
Old 06-27-2014, 04:51 PM   #2
Put in normal headlight bulbs... Everyone wins.
Old 06-27-2014, 04:54 PM   #3
Joe_Roma5's Avatar
My headlights have projectors, i never get flashed unless my fog lights are on, and the fogs have regular bulbs
Old 06-27-2014, 05:14 PM   #4
That was happening to a friend of mine and it turned out to be a bad bulb
Old 06-27-2014, 05:20 PM   #5
Joe_Roma5's Avatar
First they sent me two different colored bulbs, (they flickered as well) so i called them and they sent me a new pair and they still flicker. I've had no problems with just the capacitors installed until 1 bulb blew up and went out. Bad capacitors maybe?
Old 06-27-2014, 08:35 PM   #6
Honestly idk what a cap for an hid kit is. Maybe take them out and just use the ballast
Old 06-27-2014, 08:45 PM   #7
Joe_Roma5's Avatar
Capacitor will allow a continuous amount of electricity to flow to the ballast. They're required for vehicles that have a low voltage sensor for the headlights because they use less energy than standard halogen bulbs
Old 06-27-2014, 10:49 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It's possible it could a bad capacitor. I'd start with the one that supplied power to the bulb that blew.
Sent from your mom's house.
2012 Kona Blue 3.7L V6:
Old 06-27-2014, 10:58 PM   #9
2 Stangz's Avatar
Region: Nevada
Either bad connection from the start or bad Chinese kit. Morimoto is the only way to go.
Old 06-28-2014, 12:45 AM   #10
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Yep. That's what I'm running in the retrofit I'm working on. Plugged them in to test them and not only do they warm up in seconds, it's a bright, steady light.
Old 06-29-2014, 12:01 PM   #11
2 Stangz's Avatar
Region: Nevada
Bright, steady light, that will last for years WITH a 2yr/5yr warranty and never waste time "figuring out" dumb flickering.
HID problem Horseplay Mustang Paint, Appearance & Detailing 4 01-07-2013 05:41 PM
HID Foglight Problem EthanGT03 General Mustang Discussion 9 11-27-2012 10:07 PM
HID problem GoldenPonyBoy 2005-2010 V6 Mustang 8 08-21-2012 09:43 PM
Does anyone have problem after replace the head to HID? jmpark527 2005-2010 Mustang GT 2 12-27-2011 01:06 PM
HID problem ProjectPunisher 1979-1995 Mustang GT 0 06-28-2008 10:33 AM
10:11 AM
