Quick question about replacing front wheel bearing and hub - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 07-09-2014, 07:50 PM   #1
Mfore33's Avatar
My 2000 gt auto has 200,000 miles on it and I wanted to replace the front wheel bearings and hub. Is this a difficult job? Does it require any special tools? I change my own oil and brakes so I think I can tackle this job I just wanted to know from someone with first hand experience. Also do you have any suggestions about things I should replace on this car. I have had it new from the dealer. Thanks
Old 08-11-2014, 01:02 PM   #2
d_1212's Avatar
I did this on my 02 gt last weekend. It's a fairly simple job. There's a write up on american muscle under the wheel bearing heading on how to do it. All u need is basic hand tools. I needed to pick up a 36 mm socket I think to get to the retaining nut. Had to use lots of penetrating fluid to get caliper bolts off. But honestly man if u know how to change a tire, ur half decent w a ratchet, and can get ur calipers off this is a no brainer. Most difficult part was trying to get the dust cap off mine. Used a flat head screw driver n pried it from all angles till I could get behind it and then just tapped it off w a hammer. It's a cheap thing to do and u will feel the difference...atleast I did. Good luck
d_1212 is offline   Reply With Quote
Old 08-11-2014, 01:38 PM   #3
Mfore33's Avatar
Thanks man
Old 08-13-2014, 06:30 PM   #4
MMVEC's Avatar
Easy job to do but if the bearing isn't balanced onto hub, you'll see premature wear and have to replace again. First time I had a shop do it and was in and out in less than an hour. Second time I did it myself and it's been years and no issues. Just take your time; clean the mating surfaces properly and torque it to spec--shop just used an impact and I think that was a big part of the problem. Good luck!
MMVEC is offline   Reply With Quote
Old 09-26-2014, 03:54 PM   #5
Mfore33's Avatar
Any one know the torque spec for the front wheel hub nut? And do I have to get a new nut or can I reuse the old one?
Wheel bearing hub MasonStacks 2005-2010 Mustang GT 5 06-08-2014 05:09 AM
Wheel Hub Replacement Slow4V 1996-2004 Mustang GT 13 03-20-2014 07:51 PM
Replace wheel bearing/hub? FORDuhl6 2011-2014 Mustang GT 10 02-17-2013 01:02 PM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
Hub/wheel bearing 02PONY 2005-2010 Mustang GT 6 04-09-2012 12:51 PM
04:03 AM
