Exhaust not centered - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 07-14-2014, 09:56 AM   #1
Hi all I installed pypes pype bomb axle back on my 2012 gt only issue I have is the exhaust out the back is not centered anyone know a way to fix this...pic will be posted shortly
Sent from my LG-E980 using Mustang Evolution mobile app
GWIflash is offline   Reply With Quote
Old 07-14-2014, 01:32 PM   #2
My Flow master kit gave me the same issue. Had to wiggle, bend stuff and fight with it for about an hour and a half to get it right. A real pain!.
bodon is offline   Reply With Quote
Old 07-16-2014, 11:12 AM   #3
kingstrider's Avatar
I have noticed this as well, I had to get under there and show it who the boss really is. Looks good now though.
kingstrider is offline   Reply With Quote
Old 07-16-2014, 11:15 AM   #4
This is what it looks like right now
Old 07-21-2014, 06:41 PM   #5
Bennyhill's Avatar
Haha that looks horrible! You have to physically adjust/ centre and then even get someone to hold them steady while you torque the bolts..
Bennyhill is offline   Reply With Quote
Old 07-21-2014, 07:53 PM   #6
GrabberMeBlue's Avatar
You could also wedge something in there to try and get it centered and then tighten it back up. Pieces of styrofoam, rags, etc.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 07-22-2014, 12:00 AM   #7
Mustang Coyote's Avatar
Loosening the clamps on the mid pipe can help you move the axle back around even more by enabling you to move the part of the mid pipe that connects to the axle back. If it is still that bad and you know for sure that the mid pipe or any other section of your exhaust system that comes before the axle back hasn't hit bottom and been bent or something similar, then it's on the company. I've seen several threads over Pypes and their fitment issues. Best of luck to you!
Mustang Coyote is offline   Reply With Quote
Old 07-22-2014, 06:34 PM   #8
WJBertrand's Avatar
Wow, that's not even close! With my Borla Tourings, I just partially tightened the clamps enough hold the pipes in place but loose enough to let me move them about a little until they were centered. From there I just fully tightened the clamp and they did not move. Having said that they were pretty close to start with.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 08-01-2014, 01:55 AM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I found that mine did this due to the rear-most exhaust hanger rod being too long. I cut 1.5-2 inches off and then welded the ball tip back onto the end. They stay centered now. Before going through with it, I wrapped a bit of duct tape around the hanger rod to build it up. I worked my way outward until the hanger would stay centered after a few miles of driving. That way I knew how much to cut off.
2012 Kona Blue 3.7L V6:
exhaust
Axelback not centered Blackgtcs2012 2011-2014 Mustang GT 5 08-26-2012 01:34 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
not sure if yall have seen this or not SrATEX The Bar 5 07-28-2005 10:36 AM
Not really new and not totally a newbie... wendyc New Member Introductions & Greetings 23 01-10-2005 05:10 AM
08:28 PM
