2000 Mustang GT No Fuel Pressure - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 08-13-2014, 05:49 PM   #1
MMVEC's Avatar
So, I've had the car in storage and went to pull it out and start it. Car started after a couple cranks but ran at very low idle--about 300 to 400 RPM. Hit the throttle and it stalls out--now it won't start. Inertia switch is fine...checked the pressure at the fuel rail and there's nothing. Fresh gas was put in before I started it. Anyone have any tips? I'm hoping it's just a fuse or relay and not the pump.
MMVEC is offline   Reply With Quote
Old 09-04-2014, 03:59 PM   #2
Speaking from experience I've had to replace the fuel pump and while you're at it replace the filter too. Or you can see about the fuel pressure regulator. If and when your car has one of course.
Sent from my LGMS323 using Mustang Evolution mobile app
Cardmont is offline   Reply With Quote
2000 mustang
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
I have a 1992 mustang GT Can any one install a fuel pressure regulator or is a mechanic needed? ayawamat General Mustang Discussion 2 03-13-2010 05:21 PM
Fuel pressure guage questions eagle05 1979-1995 Mustang GT 4 10-25-2006 04:47 AM
No schrader valve on 05s for wet N2O or Fuel Pressure guage justin00stang 1996-2004 Mustang GT 1 11-17-2005 08:08 AM
10:24 AM
