Install led light in trunk - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 08-19-2014, 02:17 PM   #1
Adriangozal's Avatar
As the title says I would like to know if its possible to replace the trunk light in my 2001 v6 with an led.
Adriangozal is offline   Reply With Quote
Old 09-03-2014, 09:59 AM   #2
This interests me. Having uber light in the trunk can only be a good thing.
2014 3.7L Coupe - Manual - Performance Pack - Recaro's - Black on Black
badka2ma is offline   Reply With Quote
Old 09-03-2014, 12:47 PM   #3
Joaquin_ii's Avatar
yes you can I added a red one on mine, I also added 3 led strips which made it look even better everyone who sees it loves it!
Joaquin_ii is offline   Reply With Quote
Old 09-03-2014, 07:29 PM   #4
Ahh, I need to add some strips.. where did you buy yours? Do you have it hooked up to the trunk light where it turns on when the trunk opens and off when it closes?
I want some white ones, Just to be able to see inside my trunk at night.
RushGotti is offline   Reply With Quote
Old 09-03-2014, 07:43 PM   #5
Joaquin_ii's Avatar
I bought them on amazon I forgot from who but I can send you a link if you want.
And yes I spliced unto the trunk light so it can come one at the same time.
Old 09-03-2014, 09:39 PM   #6
Since you posted this, I ended up looking for some for mine... I found some and I got them for $20 shipped. (200 Lumens!!!!)
Here's the link for the one that would work in your car.
1994-2004 Ford Mustang Trunk Light LED
You can select the brightness (The brighter, the pricier though, but well worth it).
Yes please, But do they have them in white? I just need a strip to place behind my subs so I can see the amp and epicenter in the dark.
With the upgraded LED bulb I just ordered, I shouldn't have a problem seeing the rest of the trunk, LOL.
Old 09-04-2014, 09:00 AM   #7
Joaquin_ii's Avatar
here are some strips of white ive had them on for about 8 months and they still stick and work perfectly. they come in packs of 4. you will want to add more aound if you like the way it looks. and yes the white led bulb lights up the trunk like no other.
http://www.amazon.com/Cutequeen-Flex...xgy_auto_img_z
Old 09-04-2014, 09:22 AM   #8
Thank you, Just bought them!
Super glad it was Amazon Prime eligible!! =D
Old 09-05-2014, 11:47 AM   #9
Thanks, hopefully you can post a pic of that 200 lumens led once you get it installed.
Old 09-06-2014, 10:50 AM   #10
Devil Strider's Avatar
What kind of bulb does a 2014 mustang GT use for the glove box as well as trunk?
Sent from my Galaxy Note 3 using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 09-06-2014, 05:43 PM   #11
Joaquin_ii's Avatar
you should be able to google it that what i did
Old 09-06-2014, 06:19 PM   #12
I did but it didn't gibe me an exact type of bulb.
Old 09-06-2014, 07:45 PM   #13
Will do! I also bought the 4 -strips of LED pack to install on the backside of the trunk to illuminate behind the subs.
I'll take 3 pictures, 1 with the regular bulb, 1 with the 200 lumen bulb, then 1 with the 200 lumen bulb and the LED strips.
Old 09-08-2014, 08:07 PM   #14
Joaquin_ii's Avatar
i believe it says 5050 size bulb on here. you can order them here or just type bulb size and color on amazon
2010-2014 Ford Mustang Trunk Light LED - Ford - Bulbs By Vehicle - Lighting
Old 09-08-2014, 10:08 PM   #15
So I opened my trunk for the first time in a while, I saw no light come out at all (Not something I remembered, I'm normally at work during the night so while I get there or if I'm leaving, There's usually daylight) then I notice there's no light output at ALL..
I removed the cover and the plug was disconnected... Where's the connector? Somewhere under the dynamat, LOL.
Old 09-10-2014, 10:18 AM   #16
Joaquin_ii's Avatar
They installed it over the connector? 😂
Led trunk light bars. Greg3 Mustang Audio & Video 19 06-17-2013 10:52 AM
12v led light hook up 99 gt 99redgt 1996-2004 Mustang GT 16 02-01-2012 07:15 PM
LED Tail Light (NEED HELP)!!!! Pola25 2005-2010 Mustang GT 0 12-09-2011 04:02 PM
12:35 PM
