Annoying seat belt alarm! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 09-11-2014, 04:24 PM   #1
AngelR's Avatar
I have an 02 V6. Could someone please tell me how to disable that horrible seat belt alarm?
AngelR is offline   Reply With Quote
Old 09-11-2014, 04:31 PM   #2
Mile high JDF's Avatar
Buckle your seat belt...
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-11-2014, 04:33 PM   #3
Rapinator126's Avatar
^ there you go, close thread.
Old 09-11-2014, 05:05 PM   #4
I don't use my seat belt..........
I use these instead lol
Name:	ImageUploadedByMustang Evolution1410476729.324406.jpg
Old 09-11-2014, 05:39 PM   #5
AngelR's Avatar
The problem isn't that I'm too dumb to wear a seat belt, it's that I don't have a break room at my job, so my breaks are spent in my car. I live in the south, it's hot without the air running. But then I have the hideous alarm.
Old 09-11-2014, 05:51 PM   #6
natestang07's Avatar
Just buckle the belt behind you? Sit in passenger seat
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 09-11-2014, 06:42 PM   #7
You should wear a seat belt while you sleep... Stay safe.
RushGotti is offline   Reply With Quote
Old 09-13-2014, 08:06 AM   #8
jasondanger's Avatar
Im pretty sure its in the owners manual how to do it, i dont have mine on me right now but if you google it you can find the procedure. I turned mine off simply because when im working on the car and sitting in the drivers seat it wont stop chiming, just remember to buckle up when you hit the road!
jasondanger is offline   Reply With Quote
Old 09-13-2014, 01:07 PM   #9
WordySanchez's Avatar
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding
with the deactivation/activation programming
procedure.
The BeltMinder feature can be deactivated/activated
by performing the following procedure:
Before following the procedure, make sure that:
² The parking brake is set.
² The gearshift is in P (Park) (automatic
transmission) or the neutral position (manual
transmission).
² The ignition switch is in the OFF position.
² All vehicle doors are closed.
The driver’s safety belt is unbuckled.
² The parklamps/headlamps are in OFF position (If
vehicle is equipped with Autolamps, this will not
affect the procedure).
To reduce the risk of injury, do not
deactivate/activate the Belt Minder feature
while driving the vehicle.
BeltMinder activation and deactivation
procedure
1. Turn the ignition switch to the RUN (or ON)
position. (DO NOT START THE ENGINE.)
2. Wait until the safety belt warning light turns off.
(Approximately 1–2 minutes.)
² Steps 3–5 must be completed within 60 seconds
or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times,
ending with the safety belt unbuckled. This can be
done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the
parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times,
² After step 5 the safety belt warning light will be
turned on for three seconds.
6. Within seven seconds of the safety belt warning
light turning off, buckle then unbuckle the safety
belt.
² This will disable BeltMinder if it is currently
enabled, or enable BeltMinder if it is currently
disabled.
7. Confirmation of disabling BeltMinder is provided
by the safety belt warning light flashing four times
per second for three seconds.
8. Confirmation of enabling BeltMinder is provided
by:
² The safety belt warning light flashing four times
Followed by three seconds with the safety belt
warning light off.
² Once again, the safety belt warning light will flash
four times per second for three seconds.
9. After receiving confirmation, the
deactivation/activation procedure is complete.
WordySanchez is offline   Reply With Quote
Old 09-13-2014, 01:09 PM   #10
That from p. 111 of the manual (3rd printing).
I know this was useful to me for my truck, which I will use in hauling stuff around the house and the dinging was making life pretty miserable.
Old 09-13-2014, 02:12 PM   #11
Originally Posted by WordySanchez View Post
Hey MileHigh,
Thanks for catching that, for the life of me when I read the OPs post I saw '12 V6. I edited my original post to reflect the procedure for his specific year and referenced the appropriate page number in the manual as reference in case he wants to look it up in his manual.
Could you delete the block quote from your post so that the bogus info isn't out there misleading folks? I feel bad I didn't read his original post closely enough.
I'm not sure what your reference to the Edge is? Did I miss that? I was certain he was asking for an '02 Mustang V6? I can probably find the procedure for the Edge if you need it though.
Thanks.
-ws
Yeah man I can do that. The 99-04 cars are technically a SN95 so to differentiate from the 94-98 body style the 99-04 gets called the New Edge body style
Old 09-13-2014, 02:27 PM   #12
Ahh. Dang I learn something new every day, I thought you meant "Ford Edge" . I'm kind of new to the Mustang world. This V6 power plant intrigued me and now I'm hooked on the HP/Cubic Inch displacement. A far cry from my rotary engine days.
Thanks!!.
Old 09-13-2014, 02:39 PM   #13
Getn off's Avatar
U get a chime while idling and not in gear? Now I have learned something too.
Troy
Getn off is offline   Reply With Quote
Old 09-13-2014, 03:22 PM   #14
Thanks!!.
Haha yeah I can see where it'd get confusing, I tend to just assume everybody knows what the various bodies are called
Old 09-13-2014, 07:56 PM   #15
AngelR's Avatar
Thanks WordySanchez. Was beginning to think getting a serious answer was a lost cause. Us ladies get the run around on these type forums more than we get actual responses. Much appreciated!
Old 09-13-2014, 08:07 PM   #16
Well most of us don't actually know how to disable the beeping as either
Old 09-13-2014, 08:20 PM   #17
AngelR's Avatar
I've only had this car about three weeks, and I've searched high & low for a way to get rid of the alarm. Now that it's gone, it's time to get down to the fun stuff!
Old 09-14-2014, 07:55 AM   #18
No worries, glad to help. I always get a little irked too when you ask a question and the first 20 replies are, "Why would you want to do THAT?!" or "Just don't do that then." I get not replying at all, but that.... bleh.
Anyway, hope the procedure works. If you still have your manual it should be under the "Seats and Restraints" section, albeit buried in there. Good luck.
Old 09-14-2014, 07:58 AM   #19
Re-reading my reply, I don't intend that to be a 'dis to anyone, no disrespect intended. I could just relate to the non-answer thing. If folks like MileHigh hadn't pointed out my mistake I'd never have found the right info. Thanks again.
5.0, belt route and belt length question. Hatenot SVT Mustang 3 04-04-2014 09:12 AM
Factory alarm?? Alarm sounding every 30mins joedelpen 2005-2010 V6 Mustang 6 06-28-2013 02:00 PM
sounds like a belt but... not a belt!! vwdavid Pre-2005 V6 Mustang 4 09-03-2010 10:29 PM
Head Rest Removal/ Seat belt relocator cagedthought Mustang Audio & Video 14 12-04-2004 01:08 PM
Seat Belt Retraction tek55 Mustang Audio & Video 6 12-18-2003 08:44 PM
06:28 PM
