DIY Raxiom GPS Hacks/Improvements - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 09-22-2014, 06:53 PM   #1
Hey all, my major upcoming project is going to be getting custom software/splash screens going on the Raxiom unit, and getting dual cameras (front and backup) working with the unit. Requirements are below, and I'll be updating this thread with links and progress for those of you that want to undertake something similar. Please note that DIY-level computer/electrical engineering skills are required, but I'll try to make a step-by-step at some point. For now, I'm just waiting for parts to come in, but I figured I'd share my research thus far.
Requirements:
1) Backup and Front cameras both working (ideally with backup camera overridng the front one upon switch to reverse)
2) Custom splash screen for Raxiom unit
3) Alternate maps/software loaded
Camera Progress:
1) Ordered an additional Rosen backup camera for the front of the car (part # DP-1068)
2) Ordered the ICs in this blog post to switch the 4-pin mini-dins on the cameras
How-To: Make a solid-state A/V switcher
3) Really need to decide where to put a rocker switch to switch between the front and back cameras. It's going to require a cutout in the GPS/dash/console bezel to look nice and be efficient/easy to use.
Logo Progress
1) Looks super easy, but instructions are for a different Rosen unit. However, there should be software overlap.
Rosen Piranha Splashscreen Creation Tool
Custom SW/Maps
1) I've looked into this so far, it seems that the Rosen units run Windows CE, so there should be some significant hacking opportunities. Will report more when I've had a chance to mess with the unit. Admittedly, this will be the last thing I work on (cameras are a priority).
2011 Fully-loaded V6 Premium
PythonV6 is offline   Reply With Quote
Old 09-25-2014, 01:36 PM   #2
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Requirements:
Camera Progress:
Logo Progress
Custom SW/Maps
Sounds like you're doing a lot of customizing to your Nav! That's really cool. How are you enjoying everything so far?
I look forward to following along with your thread.
-Dan
Old 09-25-2014, 03:33 PM   #3
-Dan
The Digikey parts are supposed to come today, with the GPS unit arriving tomorrow. We'll see. I'm planning on doing an AM-style guide for the dual backup cameras (as well as a guide for the install, since it looks like no one has done that yet!), so hopefully it will be easy to do. It's really all theory at this point, but we'll see once the solder hits the pins It'll be nice to be in my element (software / electrical), instead of something new for once (mechanical/bodywork)
Old 09-26-2014, 09:36 AM   #4
AmericanMuscle.com
Sponsor
I haven't seen anyone run dual cameras so that should be very cool. I look forward to checking out the progress. Should be cool!
Definitely submit your installation guide on the actual unit when it's completed!
-Dan
Old 09-26-2014, 06:14 PM   #5
WordySanchez's Avatar
My nav unit is sitting in the box still waiting for my car to arrive from Germany, so I guess I could check but I thought I read where there was an second video input on the unit?
WordySanchez is offline   Reply With Quote
Old 10-03-2014, 07:35 PM   #6
If you go into the SD card and unzip the data folder (really take a look around everywhere), you'll see a lot of config files. Here's a couple I've found so far with some promise. Will update by the end of tomorrow after I've had a chance to play around with it.
=== /data/config/devices/rosen_db_mustang.ini ===
[device]
sdcard_name="StorageCard"
[interface]
exit_on_sd_remove_fast_always=1
show_minimize=1
automotive=1
backlight_slider=0
maxzoom2d=6000000
show_exit=0
safety_lock=0
default_safety_mode=0
ignore_sd_remove=1
show_exit=0
drive_carefully=1
vfont_enabled=1
[debug]
max_memory = 134217728
reserve_memory = 16777216
render_without_focus=1
[gps]
port=6
baud=38400
send_init=0
set_messages=0
background_navigation=1
[loading]
background_startup=1
show_window_on_ui_ready=0
disable_bg_startup_on_lang_change=1
dont_force_focus=1
[regional.timezone]
sync_time=0
reset_os_timezone=0
sync_os_timezone=1
sync_os_timezone_only=1
patch_dst=1
keep_auto_on_error=1
[timezone]
sync_time=0
[modules]
IEXT_DIRECTION_NOTIFIER="ZENEC_DIRECTION_NOTIFIER"
[other.rosen]
skypine_app_window_name="NavigRecive"
skypine_turninfo_update_interval=3000
skypine_turninfo_window_name="DB_TurnInfoBar"
[rawdisplay]
screen_x=800
screen_y=480
driver="gdi"
[sound]
std_muting_device_needed=1
app_wnd_handle="NavigRecive"
app_message_start="1150"
app_wparam_start=3
app_lparam_start=1
app_message_stop="1150"
app_wparam_stop=4
app_lparam_stop=0
use_os_volume=0
use_method=99
=== /data/project_config/igo9.ini ===
!version:0
[2d]
render_during_animation=1
adaptive_2d=1
use_r1_roadnames_for_r2_if_missing=1
[3d]
guidancearrow_first_size=1.1
guidancearrow_first_alpha=24
guidancearrow_second_size=0.8
guidancearrow_second_alpha=12
show_guidance_arrows=0
show_guidance_strip=1
guidancestrip_stretch=20
planned_route_contour_width=2
planned_route_track_contour_width=2
planned_route_track_width=5
building_camera_distance_medium=6000
building_camera_distance_medium_back=5000
fade_overlap_tolerance=32
[3d_config]
disable_roadsign_navigation_mode=0
[activation_manager]
modules=google_naviextras,online_speedcam,community_speedcam,http_traffic
google_naviextras_module_id=808
activate_google_naviextras=1
show_google_naviextras=1
online_speedcam_module_id=1081
activate_online_speedcam=1
show_online_speedcam=1
community_speedcam_module_id=1083
activate_community_speedcam=1
show_community_speedcam=1
http_traffic_module_id=1084
activate_http_traffic=1
show_http_traffic=1
[config]
use_sys_wrap=0
[feature]
tmc_event_coloring=1
signpost_coloring=1
signpost_nightshading=1
tuner_alg_search_force_on=1
concat_first_two_words_in_indexer=1
[fleetmanagement]
port=COM4
baud=115200
[folders]
defaults=ui_igo9/defaults
[globe]
use_lighting=0
[gps]
delay_after_pos_valid=1000
delay_after_pos_invalid=1
[interface]
skin=ui_igo9
newalignment=1
bilang_city=0
enable_stateanim=1
builtin_themes="SKIN~Default - night|skin_night"
resultsinqueryorder=1
use_autohint=0
font_quality=light
show_tutorial=1
use_dual_names=1
theme_night=skin_night
;for offroad pedestrian distance formatting
distance_no_zeros_2=0
distance_unit_limit_meters_2=1000
distance_limit_meters_2_0=0
distance_rounding_meters_2_0=10
distance_limit_meters_2_1=10000
distance_rounding_meters_2_1=1000
distance_unit_limit_yards_2=1000
distance_limit_yards_2_0=0
distance_rounding_yards_2_0=10
distance_limit_yards_2_1=10000
distance_rounding_yards_2_1=1000
distance_unit_limit_feet_2=1000
distance_limit_feet_2_0=0
distance_rounding_feet_2_0=10
distance_limit_feet_2_1=10000
distance_rounding_feet_2_1=1000
[itiner]
displayed_warnings=1,2,3,8,9,10,11,12,13,14,15,16,17,19,21,22
hidden_warnings=10,11,22
pass_destination_distance=50
pass_destination_time=15
pass_destination_radius=100
remove_reached_destination=0
pass_via_distance=5 ; remove via point when approached within 5m
[keyboard]
panel_alpha="US English (ABCD)"
panels=ui_igo9/common/keyboard.ini
[loading]
show_statustext=0
show_progressbar=1
[map]
3d_min_zoomlevel=30
3d_max_zoomlevel=14000
3d_max_tiltlevel=8500
3d_scale_carmodel=1
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=20000
building_render_distance_far_front=6.0
building_render_distance_far_back=3.0
building_render_distance_medium_front=3.0
building_render_distance_medium_back=2.0
building_render_distance_near_front=2.0
building_render_distance_near_back=2.0
popup_info=0
minimum_zoom_amount=70
minimum_tilt_amount=70
tiltfactor=30
minimum_rotate_amount=15
; Backlight level depends on time of day
nightmode_dependent_backlight=0
[map.car_display]
categories=car,pedestrian,other
[map_update_checker]
enabled=0
out_of_date_days=365
popup_repeat_hours=168
popup_repeat_seconds=0
popup_repeat_count=-1
map_check_seconds=86400
trigger_on_at_least_one_old=0
first_gps_with_travelling=1
[modules]
IITINER_LIST_MANAGER=IGO_SPEC_ITINER_LIST_MANAGER
ITMC_STATION_SELECTOR=TMC_STATION_SELECTOR_IGO
IFM_STATION_CACHE ="FM_TMC_STATION_CACHE"
[mydata.truck]
selected_profile=0
[naviextras]
request_gzip=0
send_gzip=0
[navigation]
crossborder_warning=real
slowspeed_limit=5
slowspeed_time=5
use_duration_for_tunnel=0
stop_at_tunnel_end=1
show_current_city=1
show_city_in_next_street=1
show_city_in_next_street_distance=10000
; distance travelled from last maneuver (in meters) when last guidance arrow is removed (turn off with -1)
passed_guidance_arrow_hide_distance=150
junction_view_at_maneuver=1
junction_view_type="mixed" ; used by UI to determine which JV type to use, options are NNG, NNG_NQ, NQ or mixed
[navigation.extrapolate]
stop_at_sharp_turns=0
step_itiner_entry=1
[navigation.sudden_detour]
results_timeout_s=180
poi_search_category0=LeisureTravelTourist_Attractions
poi_search_category1=Petrol_Station
poi_search_category2=Restaurant
poi_search_category3=Parking
[navigation.parking_ad]
search_category=Parking
search_category_fallback=AutomotiveParking
[network.quota]
services_over_dailylimit=minimal_speedcam
[oasis]
gamecodes_licensed=1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20
clock0_tz_index=29
clock1_tz_index=12
exclude_directories="%root%/Application Data,%root%/Program Files,%root%/Windows,PICTURE::%app%"
include_directories=GAME::%app%/content/games,PICTURE::%sdcard%,PICTURE::%myflashdisk%/pictures,PICTURE::%myflashdisk%/dcim
game_root=%app%/content/games
[other]
;distance_to_disable_demo=5000
ui_main_commonpath=1
[other.driver_profile]
enabled=1
[other.highway_drive]
calculate_simulation=1
enabled=1
filter_by_pois=0
max_list_size=3
list_nameless_exits=1
planned_route_only=0
poi_precise_distance=1
poi_search=1
poi_search_area=1500
poi_search_category0=Petrol_Station
poi_search_category1=Restaurant
poi_search_category2=ParkingRest_Area
poi_search_category3=AutomotiveCar_Service
use_signposts=1
[poi]
use_lastknowngps=1
search_poi_history=1
forced_icon_grab_on_map=0x5000000
userpoi_default_icon=@Favourites
; Name of featured POI provider search
featured_provider=netlocalsearch.naviextras.google
[poi.ads]
conversion_table_file=nq_ad_categories.txt
[power]
; Shutdown iGO (suspend device) automatically at given level (default: -1 - no automatic shutdown)
battery_shutdown_at=1
; Delay of automatic shutdown before suspending device
battery_shutdown_delay=5
; Default backlight levels
backlight_day_default=100
backlight_day_battery_default=80
backlight_night_default=50
backlight_night_battery_default=30
backlight_tunnel_default=50
tunnel_backlight_enabled=1
; Default: Smart Powersave (1)
powermgm_state=1
[quickdetour]
enabled=1
[regional]
timeformat=2
eta_uses_timezone_of_destination=1
geocoord_precision_ddd=5
geocoord_precision_dmm=3
geocoord_precision_dms=1
[route]
straight_start_on_recalc=1
zip_resolve_max_length=40
order_resolve_max_length=40
min_suspend_time=1800000
trip_offset=1000
auto_enable_crossborder=1
auto_enable_permit_needed=1
warn_for_permit_needed_even_if_enabled=1
green_fastness=60
keep_settings_on_load_from_buffer=1
max_endpoint_distance_km_bicycle=500
[services]
channel=winmo
device_type="iGO Primo"
brand="Nav N Go"
product_brand="Nav N Go"
product_model="iGO Primo"
naviextras_silent=1
[smartzoom]
recalc_timeout=5000
[sound]
button_sound=button
reminder_sound=oasis_alarm1
incall_sound=oasis_alarm1
sms_sound=oasis_alarm1
incallknown_sound=oasis_alarm1
incallunknown_sound=oasis_alarm1
nocontrol_sound=""
disabled_sound=invalid
mapclick_sound=mapclick
maneuver_chimes=1
click_sound_on_tooltip=0
dynamic_volume_type=0
effect_volume=128
[sound.speech]
delay_msec_between_speeches=600
[sound.announcer]
overspeedlimit_source=ui
[speech_sources]
sources=traffic::restart,warning::restart,recalculate::drop,guidance::drop,test::restart,vr::drop,dialogout::restart,ui::drop
[subscriptions]
0x42000328=google_naviextras
0x42000439=online_speedcam
0x4200043B=community_speedcam
0x4200043C=http_traffic
[subscriptions.google_naviextras]
timelimit_warnings=7,1
[subscriptions.online_speedcam]
[subscriptions.community_speedcam]
[subscriptions.http_traffic]
[timezone]
[tmc-http]
start=0
servers.size=1
servers[0].url=http://tmchttp0.naviextras.com/nng-igo-tmc-primo/0/
[traffic.events]
use_historical_speed_color=0
[tracklog]
autotracklog_file=stats/autolog.trk
autotracklog_length=100000
autotracklog_add_count=2
second_autotracklog_fitted=1
second_autotracklog_file=stats/autolog_fitted.trk
autotracklog_recycling=0
contentids_for_autotracklog=1
contentids_file=stats/content.ids
min_free_disk=1048576
[truck]
max_restriction_level=0
[tts]
use_tts_lang=1
; S P E E D C A M - C A T : 0
[speedcam_category:0]
activated_spoken_type=speech
activated_speech="Speed camera ahead."
approach_beep_distances=150
approach_beep_spoken_type=speech
approach_beep_speech="Speed camera."
overspeed_spoken_type=speech
overspeed_speech="Reduce your speed."
overspeed_min_speech_repeat_delay=10
min_frc=-1
use_road_speedlimit=1
; S P E E D C A M - C A T : 1
[speedcam_category:1]
activated_speech="Mobile speed camera ahead."
approach_beep_speech="Mobile speed camera."
min_frc=-1
; S P E E D C A M - C A T : 2
[speedcam_category:2]
min_frc=5
; S P E E D C A M - C A T : 3
[speedcam_category:3]
activated_speech="Average speed camera ahead."
approach_beep_speech="Average speed camera."
section_beep_distance=150
section_beep_spoken_type=speech
section_beep_speech="Average speed camera."
min_frc=-1
; S P E E D C A M - C A T : 4
[speedcam_category:4]
activated_speech="Red light camera ahead."
approach_beep_speech="Red light camera."
min_frc=5
; S P E E D C A M - C A T : 6
[speedcam_category:6]
activated_speech="Railway crossing ahead."
approach_beep_speech="Railway crossing."
min_frc=5
use_road_speedlimit=0
; S P E E D C A M - C A T : 7
[speedcam_category:7]
activated_speech="Bus lane camera ahead."
approach_beep_speech="Bus lane camera."
min_frc=-1
; S P E E D C A M - C A T : 8
[speedcam_category:8]
activated_speech="High accident zone ahead."
approach_beep_speech="High accident zone."
min_frc=-1
; S P E E D C A M - C A T : 9
[speedcam_category:9]
speedcam_snap_distance=50
activated_speech="School zone ahead."
approach_beep_speech="School zone."
overspeed_spoken_type=none
min_frc=5
; S P E E D C A M - C A T : 10
[speedcam_category:10]
activated_speech="Town entry point ahead."
approach_beep_speech="Town entry point."
overspeed_speech="Prepare to reduce your speed."
overspeed_min_speech_repeat_delay=25
min_frc=-1
; S P E E D C A M - C A T : 11
[speedcam_category:11]
activated_speech="Red light and speed camera ahead."
approach_beep_speech="Red light and speed camera."
min_frc=5
; S P E E D C A M - C A T : 12
[speedcam_category:12]
activated_speech="Toll booth ahead."
approach_beep_speech="Toll booth."
overspeed_speech="Prepare to stop."
min_frc=-1
; S P E E D C A M - C A T : 13
[speedcam_category:13]
approach_beep_sound=!proxi
min_frc=-1
; S P E E D C A M - C A T : 14
[speedcam_category:14]
min_frc=-1
; S P E E D C A M - C A T : 15
[speedcam_category:15]
activated_speech="Congestion charge zone ahead."
approach_beep_speech="Congestion charge zone."
min_frc=5
; S P E E D C A M - C A T : 16
[speedcam_category:16]
min_frc=-1
; S P E E D C A M - C A T : 17
[speedcam_category:17]
min_frc=-1
; S P E E D C A M - C A T : 18
[speedcam_category:18]
min_frc=-1
; S P E E D C A M - C A T : 19
[speedcam_category:19]
min_frc=-1
; S P E E D C A M - C A T : 20
[speedcam_category:20]
min_frc=-1
; S P E E D C A M - C A T : 21
[speedcam_category:21]
min_frc=-1
; S P E E D C A M - C A T : 22
[speedcam_category:22]
min_frc=-1
; S P E E D C A M - C A T : 23
[speedcam_category:23]
min_frc=-1
; S P E E D C A M - C A T : 24
[speedcam_category:24]
min_frc=-1
; S P E E D C A M - C A T : 25
[speedcam_category:25]
min_frc=-1
; S P E E D C A M - C A T : 26
[speedcam_category:26]
min_frc=-1
; S P E E D C A M - C A T : 27
[speedcam_category:27]
min_frc=-1
; S P E E D C A M - C A T : 28
[speedcam_category:28]
min_frc=-1
; S P E E D C A M - C A T : 29
[speedcam_category:29]
min_frc=-1
; S P E E D C A M - C A T : 30
[speedcam_category:30]
min_frc=-1
; S P E E D C A M - C A T : 31
[speedcam_category:31]
activated_speech="Dangerous area ahead."
approach_beep_speech="Dangerous area."
min_frc=-1
[tmc]
tuner_model= "TMC_GPSTMC_TUNER"
auto_detour_calc=0
announce_total_route=1
tmcprovider_simple_model_use=1
skip_loading_built_in_provider_list=1
tmcprovider_ignore_altfreq=1
tmcprovider_rssi_stability=4
tmcprovider_rssi_average=3
tmcprovider_tuner_scanlevel=1
tuneralg_8a_packet_timeout=6500
tuneralg_last_8a_packet_timeout=30000
tuneralg_3a_packet_timeout=20000
[traffic.settings]
load_default_traffic_settings=0
use_extra_setting_for_flow_events=1
use_speed_color_codes=1
calculate_colors_by_weight=1
announce_recalc_on_auto_only=1
flow_speed_coloring=4,10,3,30,2,60,1,90,0
historical_flow_speed_coloring=14,10,13,20,12,30,11,40,10,50,9,60,8,70,7,80,6,90,5
save_traffic_events=1
load_traffic_events=0
max_queue_processing_time=100
clear_routing_options_on_dest_change=0
detour_recalc_timeout=300
deletion_timeout_multiplier=1
;INFOTEXT SETTINGS
infotext_names=location,extra_location,location_from,location_to,road_name
infotext_location_regions=usa,aus
infotext_location_usa_countries=u**,c**
infotext_location_aus_countries=a**
;format definitions for location text by regions
;USA remains original
infotext_location_usa_dir0_bidi0_ext0_format=%orig_loc_usa_dir0_bidi0_ext0%
infotext_location_usa_dir0_bidi0_ext1_format=%orig_loc_usa_dir0_bidi0_ext1%
infotext_location_usa_dir0_bidi1_ext0_format=%orig_loc_usa_dir0_bidi1_ext0%
infotext_location_usa_dir0_bidi1_ext1_format=%orig_loc_usa_dir0_bidi1_ext1%
infotext_location_usa_dir1_bidi0_ext0_format=%orig_loc_usa_dir1_bidi0_ext0%
infotext_location_usa_dir1_bidi0_ext1_format=%orig_loc_usa_dir1_bidi0_ext1%
infotext_location_usa_dir1_bidi1_ext0_format=%orig_loc_usa_dir1_bidi1_ext0%
infotext_location_usa_dir1_bidi1_ext1_format=%orig_loc_usa_dir1_bidi1_ext1%
;AUS
infotext_location_aus_dir0_bidi0_ext0_format=%adv_loc_aus_dir0_bidi0_ext0%
infotext_location_aus_dir0_bidi0_ext1_format=%adv_loc_aus_dir0_bidi0_ext1%
infotext_location_aus_dir0_bidi1_ext0_format=%adv_loc_aus_dir0_bidi1_ext0%
infotext_location_aus_dir0_bidi1_ext1_format=%adv_loc_aus_dir0_bidi1_ext1%
infotext_location_aus_dir1_bidi0_ext0_format=%adv_loc_aus_dir1_bidi0_ext0%
infotext_location_aus_dir1_bidi0_ext1_format=%adv_loc_aus_dir1_bidi0_ext1%
infotext_location_aus_dir1_bidi1_ext0_format=%adv_loc_aus_dir1_bidi1_ext0%
infotext_location_aus_dir1_bidi1_ext1_format=%adv_loc_aus_dir1_bidi1_ext1%
;OTHER
infotext_location_other_dir0_bidi0_ext0_format=%adv_loc_other_dir0_bidi0_ext0%
infotext_location_other_dir0_bidi0_ext1_format=%adv_loc_other_dir0_bidi0_ext1%
infotext_location_other_dir0_bidi1_ext0_format=%adv_loc_other_dir0_bidi1_ext0%
infotext_location_other_dir0_bidi1_ext1_format=%adv_loc_other_dir0_bidi1_ext1%
infotext_location_other_dir1_bidi0_ext0_format=%adv_loc_other_dir1_bidi0_ext0%
infotext_location_other_dir1_bidi0_ext1_format=%adv_loc_other_dir1_bidi0_ext1%
infotext_location_other_dir1_bidi1_ext0_format=%adv_loc_other_dir1_bidi1_ext0%
infotext_location_other_dir1_bidi1_ext1_format=%adv_loc_other_dir1_bidi1_ext1%
[tripcomputer]
num_of_trips=2
[vmc_phone]
enter_script=sc_volmanager_phone
vmc_phoneeffect=20
vmc_alarmeffect=20
vmc_voice=0
vmc_effect=100
vmc_media=-1
[vmc_phoneeffect]
enter_script=sc_volmanager_phoneeffect
vmc_alarmeffect=20
vmc_voice=0
vmc_effect=100
vmc_media=0
[vmc_vr]
vmc_voice=100
vmc_media=-1
vmc_alarmeffect=100
vmc_effect=0
[vmc_alarmeffect]
enter_script=sc_volmanager_alarmeffect
vmc_voice=50
vmc_effect=100
vmc_media=20
[vmc_voice]
enter_script=sc_volmanager_voice
vmc_effect=100
vmc_media=20
[vmc_effect]
enter_script=sc_volmanager_effect
vmc_media=100
[vmc_media]
enter_script=sc_volmanager_media
[voice]
first_guidance_area_radius_in_m=0
;volume channels priority order
[volume_channels]
channels=vmc_phone,vmc_phoneeffect,vmc_vr,vmc_alarmeffect,vmc_voice,vmc_effect,vmc_media,vmc_ding
volumefade=1000
[warning]
is_spoken=1
speedwarn_alt_builtup_based=1
pedestrian_warning_threshold=25
pedestrian_warning_activtime=10
speedcam_soundtype_3=1
[warning.driveralert.settings]
max_display_count=2
show_timeout=10
use_timeout_for_duration=1
[globe]
use_lighting=0
[vr]
vde_accuracy=2000
Old 10-08-2014, 02:04 PM   #7
I got the file system access working (via explorer.exe and a launcher). I can run other WinCE apps as well . I still haven't been able to change the boot logo, but I do have a soldered board that I'll test with a multmeter Saturday to scope out the pins. Once I know those (they claim its proprietary), I should be able to continue testing the board.
Sent from my XT875 using Mustang Evolution mobile app
Old 10-10-2014, 09:14 PM   #8
Looks like the boot logo is 99% not replaceable. Most of the Windows system files are stored in ROM and the boot logo is supposedly in flash (though I can access NAND Flash from Windows). Currently trying to develop a nice launcher screen using "iPhoneToday" (which autoloads from SD). All I need to do is get the default application (AppDriver.exe/StartUP.exe -- the music / phone app) working via the launcher and I'll release what I have here.
Old 12-13-2014, 12:39 AM   #9
So a summary for this project for now since people have been asking:
So first the bad news. The system does a hard reset when it reloads (you power off the car, etc.). It uncompresses the full CE filesystem from ROM. The version of Windows CE appears to be CE6 and is the Chinese language version. All Rom Dumpers, etc. that I've attempted to use have not been able to get the exes from the ROM. If I could get the EXE that actually runs the main app (sync/music/camera,etc.), then I could just add that to my iPhone esque launcher (which is the best solution I've found; iPhone Today), but it doesn't let you go back to the launcher after you use the default UI app. You can edit the layout and icons, etc. by editing the XML layout files; simple stuff. You can use MioPocket to effectively hack your device and get windowing working for everything (you can minimize the default SW app). Of course, that "hack" you did reverts when you turn off the car, so unless you can roll it into something permanent (you can access the NAND from the file explorer and save files there), it's pretty worthless, although cool. So what does that leave you with? Well you can change the Navigation application to any windows CE program you want (maybe get a garmin one and copy over all the maps, etc.) since all of that is stored on the SD card, but outside of soldering the board or doing something outside of Windows CE (which I've never tried since it would be very risky), you're pretty much stuck with the Raxiom boot logo and the default navigation app. I'll start a new thread that's DIY for the two backup cameras when I get that working. It has taken a back seat to painting my interior and doing some sound dampening (plus a known solution already exists; RCA cable switchers!).
Links:
https://code.google.com/p/iphonetoda...%2Ftrunk%2Fsrc
GpsPasSion Forums - MioPocket 4.0 (Unlock for GPS devices)
GPS CE Rescue Disk.zip
root.rar (the root of my SD card including CE file explorer, apps, etc. mostly working ones filtered from ones above)
Old 12-06-2015, 05:28 PM   #10
AdrianK9's Avatar
Hello there,
Is this possible to load European map in Raxiom sat nav?
I am lockated in Western Europe and need a proper map.
I found this site https://www.naviextras.com
related with iGo but wondering if you have already done it.
OniGo Navigation web site they say:
How it works
Connect your device or the SD card to your computer
Go to www.naviextras.com
Create a free user account
Download Naviextras Toolbox, a free PC-tool, that connects your device to the PC and automatically scans for installed software and maps
Pick your map or content package and proceed to payment
Follow the prompts to install your latest maps... and you’re ready to hit the road!
Thanks,
Adrian
AdrianK9 is offline   Reply With Quote
Old 03-04-2016, 08:50 AM   #11
I would love to see Apple Car Play and Android Auto integrated into the system. It would be great to use Google maps for navigation.
Sent from my SM-G920V using Mustang Evolution mobile app
david715 is offline   Reply With Quote
Old 07-07-2016, 01:15 AM   #12
Hi Adrian, did you ever get your EU maps sorted out? I too am in this situation. Recently bought a Raxiom GPS head unit and am worried I'll be stuck with US maps. Looking forward to your response. Cheers.
TeealB is offline   Reply With Quote
Raxiom OE-Style GPS Navigation installation problems! JonathanMustang 2011-2014 Mustang GT 17 04-08-2018 12:49 PM
Raxiom OE-Style GPS Navigation w/ Bluetooth & Back-up Camera (10-14) DWC_SmOziLLa AmericanMuscle 112 04-17-2016 07:42 PM
Raxiom GPS Installed the5 2011-2014 Mustang GT 5 12-11-2013 03:40 AM
Raxiom GPS Bluetooth Navigation Installation Help JonathanMustang 2011-2014 Mustang GT 3 11-12-2013 09:54 PM
06:20 PM
