Clogged Windshield Washer Nozzles? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 10-27-2014, 01:30 PM   #1
rkaralash's Avatar
I have a 2010 v6 and the windshield washer nozzles won't spray fluid. Almost like the lines are clogged? Anyone have similar issues or suggestions on how to fix?
Sent from my HTCONE using Mustang Evolution mobile app
rkaralash is offline   Reply With Quote
Old 12-08-2014, 12:58 PM   #2
pete2013's Avatar
If you can safely remove the nozzles, soak them in CLR to break up whatever is clogging them.
pete2013 is offline   Reply With Quote
Old 12-28-2014, 08:21 PM   #3
hctr154's Avatar
Try the sharp end of a safety pin or needle to dig out the crud in the holes.
2013 GT A6
hctr154 is offline   Reply With Quote
Old 01-08-2015, 09:17 PM   #4
Slater2111's Avatar
If you weld or do any oxy acetylene welding you can use your smallest tip cleaner to not only clean them out but most people don't know you can aim them. This is on most cars. Obviously don't force them if they aren't designed to move.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 01-14-2015, 02:01 PM   #5
rkaralash's Avatar
Thanks for all the replies, I ended up just ordering two new squirters. I Broke one while trying to take them off to clean... All is well and for the first time since I've owned the car (6 months) I finally have windshield washer squirters!!! Thanks again everyone
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
04:50 PM
