digital cluster into coyote fox? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 11-28-2014, 04:23 PM   #1
Id like to install a ford digital cluster into my coyote swapped fox.
My transmission has occ to PCM so I can get digital speedo and engine data from the PCM...
Not a fan of the florida 5.0 style setup...
What model year gauges can I use?
My color would be cool, I also like the 2011+ which I believe use the same PCM....
What would I need to do to get the gauges to work
Not worried about fit as much as technical...
Thanks!
redvert is offline   Reply With Quote
Old 12-05-2014, 08:25 AM   #2
Seen it done, you are going to have to get a pinout and go wire by wire and just match them and wire it up and go. Also have to see if the sending units in the fox work with the newer cluster. You're probably going to spend way more money than if you just did a Florida 5.0 Autometer pre-wired cluster. Also the autometers are way more accurate than the stock gauges.
2014 V6 Base Cluster to Premium Cluster sid719e 2011-2014 V6 Mustang 11 08-17-2014 12:23 AM
Digital gauge cluster? abbigrace_ Mustang DIY and Technical 2 07-27-2014 01:15 PM
Ford Mustang Coyote 5.0L 4-Valve engine into a 1990LX? Jedimindtricks General Mustang Discussion 12 02-07-2013 11:05 PM
04:35 AM
