MIA Coolant - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 12-29-2014, 04:54 PM   #1
MIA Coolant
Hey Everyone, my 2012 has begun losing coolant levels. Ive searched high and low and have found no leaks anywhere. Anyone else run into this problem?
Sent from my SCH-I605 using Mustang Evolution mobile app
tthompson79 is offline   Reply With Quote
Old 01-07-2015, 04:27 AM   #2
I too have a missing coolant mystery.
Sent from my Nexus 7 using Mustang Evolution mobile app
spidermann59 is offline   Reply With Quote
Old 01-07-2015, 05:10 AM   #3
bucko's Avatar
No unusual smoke coming from the tailpipe, indicationg that the coolant is entering a cylinder (A.K.A. head gasket failure)?
Check around each hose connection carefully for any small leak; coolent returns to the overflow tank, as long as there are no leaks, as coolant will take the path of least resistance. Coolant will leak there, as well as air will be drawn from this leak, rather than the overflow tank.
I had a Ranger pickup that had a low radiator, and was adding to it once a week; the overflow tank was at the proper level, yet the radiator never drew from it. I finally located the leak; one of the automatic transmission lines that connect to the radiator was loose, and I could see the tiny mist of coolant spewing from it when I let the engine idle for several minutes.
Old 01-07-2015, 05:36 PM   #4
Finding coolant collecting behind the harmonic balancer. The inside water pump pulley lip was wet.
I hear slushing or liquid going through the cooling system after the car sits a day or two.
I have the CPO 7 year / 100k power train warranty- ??
I'll follow up.
Old 01-07-2015, 06:11 PM   #5
Water pump.
Old 01-07-2015, 09:49 PM   #6
OK good ! Thanks.
Might be MIA for a short time sonicpony03 The Bar 18 02-26-2010 10:34 PM
Mia N00b nexuslair New Member Introductions & Greetings 9 10-06-2008 08:17 AM
POW/MIA internet blackout WhiteStang99 ME Site Help & Announcements 12 01-27-2005 12:06 PM
MIA Mods... 03redfire cobra The Bar 15 05-20-2004 09:18 PM
??????????? MIA Danger Dude Pre-2005 V6 Mustang 5 07-23-2003 04:27 PM
01:34 PM
