2008 Long Tube Header Install HELP! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 01-05-2015, 02:38 PM   #1
Shadow322's Avatar
TL;DR: Entire header install stopped because of 2 studs. Help.
Tried installing LT headers this past weekend. I've never done an upgrade like this myself but figured it would be a great learning experience for my dad and I. If anyone has ever done a LT header install you know how big of a pain it can be. Well I need your help!
After getting everything removed, engine lifted, old exhaust manifold removed and the new LT's ready to put on everything came to a hault because of 2 freaking studs. Majority of the studs came out of the block that held the exhaust manifold on by just removing the nuts, but 2 on the drivers side REFUSE to come out.
We tried the double nut method, a stud extractor (thats adjustable, it just striped the 5mm stud worse) and everything else we could think of. It really pissed me off because of those little studs everything had to be put back together stock.
I really don't want to pay $600+ for a header install when the only problem I have is 2 freaking studs. So if any of you have done this same install and had the same problem what did you do? I'm desperate after all the money i've spent and just want to get this project over with. Thanks in advance!
Shadow322 is offline   Reply With Quote
Old 01-05-2015, 05:39 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Douse those suckers in some Liquid Wrench/PB Blaster/etc. and let them sit for a bit. That may help loosen them up. I sprayed mine down the night prior and then a lil more just before doing my headers. All came out with no issues.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 01-08-2015, 03:03 PM   #3
Shadow322's Avatar
Yea I think that's what I'm going to do the only problem is how to grab onto them since the 5mm head is stripped. Going to just get a tack welder from harbor freight and weld a damn nut onto the stud to turn it lol
Old 04-21-2015, 01:42 PM   #4
Crank two nuts together midway down stud. Wrench em out
2010 GT Done: FR Intake Manifold-FRPP Hot Rod Cams-Granatelli 62mm TB-BBK Ceramic Longtubes-BBK Catted X-pipe To do:-One piece aluminum driveshaft-Gears-Staggered wheels when my tires are done
theonekyle is offline   Reply With Quote
Old 04-21-2015, 01:43 PM   #5
Oop just saw you tried that...how did it not work???
long tube header install. michaelsneal 1996-2004 Mustang GT 5 07-19-2014 12:15 PM
Long tube header install help!? Chasafire888 1996-2004 Mustang GT 5 03-15-2014 11:44 AM
Long tube header install CodyNelson 1996-2004 Mustang GT 12 08-22-2011 05:04 PM
Long tube header vs. short tube USMCSS 1996-2004 Mustang GT 5 12-24-2006 05:06 PM
Some pics of my long tube header install... Junior2561 The Bar 8 02-23-2004 03:29 PM
11:50 PM
