Data logging - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 01-31-2015, 12:28 AM   #1
Terminator's Avatar
Data logging
Trying to get my mustang data logged only thing I am missing is the interfacing with the wide band, installed the plx device from AM but not sure how to interface to my laptop CS tells me to read the instructions but all it says is to connect output ( 20 gauge wire) to 3rd party data logging system or aftermarket ECU ?
Terminator is offline   Reply With Quote
Old 01-31-2015, 06:50 AM   #2
jande063's Avatar
I have used the AEM 30-2310 to translate the signal from the wideband sensor into a single lambda value (voltage). Once you have a simple capture device capturing voltage over time, you can determine the AFR at any point in time. I have used that particular inline controller on several completely unique race cars before, and have been pleased with the simplicity. What customer service is telling you is that your laptop is not out of the box capable of taking that particular input method, that you need to use an external data trap, such as the AEM AQ-1 (I have always done this through the ECU, but I doubt that you want to drop several thousand dollars on that), then download the data from that unit to the laptop.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Data logging help Tpost08 2011-2014 Mustang GT 15 10-28-2013 09:06 AM
Does Data Logging Measure HP? OzzyLiriano 2011-2014 Mustang GT 17 07-13-2013 05:32 PM
How does the SCT data logging and monitoring work rebeltx 2011-2014 V6 Mustang 3 01-30-2013 08:29 AM
Some data logging feedback from my Steeda 93 octane tune mmike87 2011-2014 Mustang GT 6 08-20-2012 04:39 AM
BAMA Data logging ForsakenProto AmericanMuscle 1 07-18-2012 09:03 AM
08:17 PM
