13 GT clutch install - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 02-10-2015, 09:48 PM   #1
Sloasslx's Avatar
does anyone have a write up of how to do this? I'm going to tackle this job this weekend, but can't find a manual. Any help appreciated!
Sloasslx is offline   Reply With Quote
Old 02-28-2015, 07:19 PM   #2
Sloasslx's Avatar
Anyone?
Old 02-28-2015, 08:10 PM   #3
DetroitMuscle99's Avatar
Go old school and get a Hayes or shilton manual for your car lol. If they are even around for newer models not sure. It's not that difficult what would you be hung up on? I don't OWN a 2013 but I can still guide you through if need be. Pretty sure the 2013 is a self bleeding clutch also.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 02-28-2015, 08:41 PM   #4
Sloasslx's Avatar
Ya they don't have a manual yet. I swore I saw someone say there was a manual that was posted online. Oh well it will get figured out when I he back to my baby. Stuck in Nashville working
Old 03-01-2015, 02:01 PM   #5
thebeerbaron83's Avatar
I just did the clutch in my 2012 GT this weekend. It's pretty straight forward. Just takes a lot of time unless you have a lift. I did mine by myself on stands and it took a total of about 12 hours. Here are a couple notes from my install.
Drop the H pipe and one of the catalytic converters (I only had to drop one to get the bell housing to clear). They are attached to the manifold by two 15mm nuts.
Pull the sub frame connector just bellow the bell housing (four 15mm nuts).
There are several sensors connected to the trans, make sure you get them all disconnected.
Disconnect the clutch line. I used a vacuum cap to plug the line so I didn't loose all of my fluid. be sure to disconnect it where it connects to the slave cylinder, leaving the 90deg elbow attached to the line. Use a small flat head screw driver to pull the retaining clip and be careful not to loose it.
Disconnect the shifter (from either the trans or the body of the car. I have an MGW race spec, so it was easier to leave the shifter on the trans).
Remove your drive shaft (12pt 12mm bolts on the trans, 10mm 6pt on the diff and two 13mm bolts holding the center to the body). Be sure to mark both ends of the drive shaft so you line it up correctly when it goes back in. This is important so you don't end with vibrations. Chalk works great.
Remove the top two 13mm bellhousing bolts from the top of the car. The only this that worked for me was a long wrench with an angle on he box end. I had to put a breaker bar on it, because there isn't enough room to get good leverage on the wrench. These ones are hard to get form the bottom.
Support the back of the trans and remove the four 18mm bolts for the rear trans support.
Lower the back of the trans with a jack (to pivot the engine) and remove the starter (three 10mm bolts. The top one is hard to get to and I had to use a swivel and several extensions to get to it from above the control arm). The power and trigger wires are held on with 10mm and 13mm nuts.
Support the trans with a trans jack and remove the remaining bell housing bolts, leaving the two lower bolts in, but loose. Try pulling the trans loose from the engine. This gave me the most trouble as one of the pins used to line the trans and engine up was rusted to the dust shield. I had to gently pry that one side away from the engine.
once you have the trans far enough back so the input shaft clears the clutch, slowly lower the trans. Change out the clutch and flywheel (or have yours resurfaced). Be sure to follow the directions that came with your clutch for proper install. I always replace my pressure plate and flywheel bolts with ARP bolts, but that is just me. I don't know if the stock bolts are re-usable or not.
Change or inspect your throwout bearing/slave cylinder. Be sure to measure for free play and preload, so your clutch operates properly and has room to wear. Ram Clutch has a good tutorial about this on their website. Different clutches might require different preloads so be sure to check. Ram also sells slave cylinder spacers. It's good to have some just in case you end up needing them.
Get the trans up and back in place. Make sure the angle of the trans is the same as the engine as you get the trans slid into place. Don't force it, just gently align the trans until you feel the input shaft slide into the clutch disc. Once I thought it was in the splines, I put my trans in gear and tried to twist the output shaft the be sure (if it spins your not in). Don't forget the put the dust shield on between the trans and engine. I was able to get the trans about a half inch from the engine block and slide the shield behind the flywheel.
Everything else from here is just re-installing the remaining wiring and parts you removed. Be sure to check that you haven't pinched anything in the trans tunnel after the trans is back up.
I hope this helps and keep in mind this is just from my experience doing the job. I am by no means a professional or mechanic. Just a DIYer, so do this at your own risk.
Ok, I guess that was more than just a couple notes.
2012 GT Premium, Bama tuned, BBK cai, MGW Race Spec Shifter, Corsa axleback with X-Pipe.
thebeerbaron83 is offline   Reply With Quote
Old 03-01-2015, 02:05 PM   #6
BTW, not sure what clutch your putting in, but I installed a McLeod RST twin disc and I love it. The pedal effort is about half that of the stock clutch. It is also a very street friendly clutch that is not and "on off switch" you'd expect from a performance clutch.
Old 03-01-2015, 02:06 PM   #7
Sloasslx's Avatar
That was absolutely awesome and exactly what I was looking for. Maybe sticky this for others to use. Thank you
Old 03-01-2015, 02:07 PM   #8
Sloasslx's Avatar
I'm using the spec aluminum flywheel and exedy stage 3
Old 03-01-2015, 02:27 PM   #9
I have heard really good things about the exedy. That is what I was going to use until I read the pedal effort was so low on the mcleod.
Old 03-01-2015, 04:30 PM   #10
I will copy and past this into it's own thread so it's easily searchable.
Old 03-03-2015, 07:31 PM   #11
2010rs1mike's Avatar
Clutch already needing replaced?
2010rs1mike is offline   Reply With Quote
Old 03-03-2015, 07:35 PM   #12
No. I have been having the typical mt82 issues and I have read upgrading the clutch has helped. So far so good.
Old 04-21-2015, 09:56 PM   #13
Sloasslx's Avatar
So finally finished this project this weekend! The write up above is perfect from what I experienced. The only thing I can add is the drivers side cat is the one I took off and to remove the the shifter from the body instead of the tranny.
Old 04-22-2015, 04:19 AM   #14
Just wanted to add a little experience with the break in. Up until about 450 mile, I experienced a little bit of clutch hanging from a stop. It was a bit harder to get into first or reverse after the clutch was first released. I have read a lot of other people experienced this with this clutch. I think the issue is with the clutch discs sticking to the input shaft. After I push the clutch in, I felt resistance going into gear. If I kept the clutch in, I could go in and out of each gear no problem. After letting the clutch out the problem reset.
This problem has gone away, but if I could do it over, I would have added a bit of lube to the splines.
Old 04-22-2015, 04:37 AM   #15
Famine's Avatar
Region: South Dakota
I wonder if the bell housing would clear longtube headers...
Famine is offline   Reply With Quote
Old 04-22-2015, 08:06 AM   #16
I don't know for sure, but I would think so. The cat was what was in the way.
how hard to install o/r x pipe? how much to get x pipe install? MustangForEver 2011-2014 Mustang GT 9 02-05-2013 07:01 PM
Install clutch and fix ignition Kotty4643 1996-2004 Mustang GT 2 07-02-2012 08:43 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Clutch install prices? mcvicar04 1996-2004 Mustang GT 21 05-23-2012 06:16 PM
Clutch install~ ColeJohnson 1996-2004 Mustang GT 27 01-19-2012 07:43 PM
10:58 AM
