Remote wire - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 02-17-2015, 12:00 PM   #1
tgalien201's Avatar
Remote wire
installed aftermarket subs to the stock head Unit. Question, which fuse should I tap the remote wire to? Or should I run it some other way?
Sent from my SM-G900P using Mustang Evolution mobile app
tgalien201 is offline   Reply With Quote
Old 02-25-2015, 12:30 PM   #2
yo your remote wire doesnt need a fuse. the remote wire is only there to tell your amp if the system is on or off, so your amp doesnt stay on when your car is off.
vavala01 is offline   Reply With Quote
Old 02-25-2015, 02:53 PM   #3
tgalien201's Avatar
Yea but with the stock head unit I don't have a remote wire lead from it. So if I can find a non constant 12v source It should new fine. Where would you suggest?
Old 03-01-2015, 02:28 AM   #4
I've installed a 10inch kicker With a built in amp. And wired the remote wire to the blue wire connected to the antenna. Click image for larger version
Name:	ImageUploadedByMustang Evolution1425202121.758925.jpg
hoggiemk is offline   Reply With Quote
Old 03-01-2015, 09:19 AM   #5
tgalien201's Avatar
That's a good idea. I'll check it out thanks.
Old 03-01-2015, 02:13 PM   #6
I'll take some pics and showed you how'd I do it
Old 03-01-2015, 03:58 PM   #7
tgalien201's Avatar
This is what I'm working with now... lol. I want warmer weather.
Old 03-01-2015, 05:58 PM   #8
croach412's Avatar
just wire your own wire straight to the battery with a switch on it..i put my switch in the glove box, easiest way on there cus the fuses are so small you could bend one of the inside tiny metal parts so the fuse becomes loose
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
croach412 is offline   Reply With Quote
Old 03-01-2015, 05:59 PM   #9
croach412's Avatar
i like his antenna idea but i just wired mine to battery, most sure way to do it, could even put a remote switch if you wanted but i just did a toggle switch
Old 03-01-2015, 08:46 PM   #10
Ay I'm sorry bout this but I gave u bad information. I got a 14 and our antennas are different. I just seen ur car.
Old 03-01-2015, 11:45 PM   #11
tgalien201's Avatar
Ahh good to know before I go and try to find it haha.
Amp Remote Wire Socal Stangman Mustang Audio & Video 10 05-19-2014 04:06 PM
Need to connect red wire to gray wire. clflorida Pre-2005 V6 Mustang 4 08-06-2013 06:46 PM
2011 GT Remote Wire Issues Untamed5.0 Mustang Audio & Video 4 04-18-2012 09:08 AM
Help! Remote wire color BuddyLee Mustang Audio & Video 18 03-12-2005 07:48 AM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
09:16 AM
