Pro-Tip: Ditch the PB Blaster and get some of this. - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 03-03-2015, 04:50 PM   #1
DutchManDann's Avatar
So I've been wrenching and knuckle busting for around 5 years now and have always been using PB Blaster to help lubricate and break bolts loose.
Its never seemed to work that well at least in my opinion. The past couple years, I've been using something else that works PHENOMENALLY better.
Its called "Kano Kroil", this one being a non-spraying can. Aero Kroil is the aerosol one that sprays. The only downsides are how hard to find, and how expensive it is.
But this stuff is seriously ridiculous. Supposedly this is what most professional shops use. Leave this on a stuck bolt for 15 minutes and its like you never tightened it down in the first place. I've used it for exhaust manifold bolts, engine mounts, O2 sensors...it really works. I'd definitely recommend trying it out.
The big puddle under the diff is Kroil lol. Not a single bolt gave me trouble when I was pulling the diff.
Anyone else ever heard of or used it?
Thanks and happy wrenching,
DutchManDann
Sent from my XT1095 using Mustang Evolution mobile app
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 03-03-2015, 07:18 PM   #2
I like PB blaster though...
I haven't been in too much of hurry lately so all of my difficult nuts and bolts have been getting plenty of soak time.
I've used better products in the past, but they were also difficult to find and slightly more expensive.
Where do you find Kroil?
Old 03-03-2015, 07:24 PM   #3
Region: Iowa
I sell that where I work. Best stuff ever. The only bad thing is the lingering smell that it leaves. I used it when I put headers on and could smell that stuff for over a month every time I got in the car.
grabberblue12 is offline   Reply With Quote
Old 03-03-2015, 08:39 PM   #4
Lol I don't really mind the smell but it definitely lingers. You can order it direct from them or you can get it on Amazon surprisingly. It's really hard to find locally.
In my opinion its worth it though. I'd rather smell that for a month than break my exhaust manifold bolts lol
Old 03-04-2015, 06:05 PM   #5
thebeerbaron83's Avatar
Never tried that stuff, but WD40 makes a newer product that works pretty well. Better than PB Blaster IMHO.
2012 GT Premium, Bama tuned, BBK cai, MGW Race Spec Shifter, Corsa axleback with X-Pipe.
thebeerbaron83 is offline   Reply With Quote
Old 03-06-2015, 11:18 PM   #6
tym_v6's Avatar
My dad swears by Kroil and has been using it for years. I think it's great, and definitely more effective than WD-40. Kano also makes a SiliKroil, that leaves behind a silicone lubricant, so parts aren't left "dry" like when using AeroKroil (which is just a penetrating oil).
I've demoted WD-40 to degreasing my tools...LOL.
Old 03-07-2015, 08:38 PM   #7
My dad swears by it as well. Applied it to my exhaust manifold bolts that hadn't been removed for probably the life of the car, and after 15 minutes it was like they were never tightened...I'll have to try the silicone kind sounds like a good idea
Old 03-21-2015, 08:58 PM   #8
Famine's Avatar
Region: South Dakota
Thanks man. I'll have to try it.
Famine is offline   Reply With Quote
Old 03-21-2015, 09:08 PM   #9
dave73's Avatar
Aerokroil does work really good. I would use WD40 over PB Blaster though. PB Blaster hasn't impressed
dave73 is offline   Reply With Quote
Old 04-01-2015, 01:18 AM   #10
Labrat's Avatar
When I was working, now retired, i used to tell the little lady, that's the smell of money!! If I didn't smell like that there wasn't a check coming in....lol!!
Labrat is offline   Reply With Quote
Old 04-01-2015, 03:48 PM   #11
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I've always used amixture of Acetone and ATF. Might have to try some of this though
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 04-02-2015, 09:48 PM   #12
Itcouldbebobby's Avatar
Funny to see all the posts about Dad's using Kroll.
My Dad was a Hydraulics Technician and Aircraft Maintenance Supervisor in the Air Force, and he swore by the stuff.
It's all we ever used working on cars and other projects together growing up, and what I use now too.
Really does work great
2014 GT MT TrackPack w Brembos, 3.73 gears
Came home with me 4/23/14
Ingot Silver with matte black wheels and emblems, SR Performance lowering springs, J&M adj panhard bar, BMR LCA's
Dubbed "Lucinda" by my 5 year old daughter and co-pilot
Itcouldbebobby is offline   Reply With Quote
Old 04-03-2015, 03:28 AM   #13
dave73's Avatar
If people are looking for Aerokeoil the HVAC suppliers in most areas carry it or smaller hardware stores such as your local ACE hardware or Tru-Valu
Old 04-09-2015, 10:46 PM   #14
Slater2111's Avatar
Yup I use it all the time. But make sure you use it in a well ventilated area. It's bad to breathe.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 05-06-2015, 01:23 AM   #15
I'll have to give it a try
2013 Roush Stage 3, Tuned by Jon Lund, Driveshaft Shop aluminum driveshaft, driveshaft loop, MGW short throw shifter
Kyle4749 is offline   Reply With Quote
Should Ford Ditch Shelby in 2014? Brent Shelby Mustang 228 04-02-2016 09:00 PM
Blaster coil for 94 Neville J Pre-2005 V6 Mustang 0 05-05-2013 09:25 AM
slammed into a ditch... NeedSomeMods 1979-1995 Mustang GT 15 07-21-2012 09:13 AM
Probably going to ditch Cable TV; Suggestions? Brent The Bar 19 04-11-2011 10:24 PM
To Tip or not to Tip.... Ibanezplayer272 Pre-2005 V6 Mustang 15 04-28-2005 09:29 PM
05:45 AM
