Overfilling 8.8 Differential - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 05-02-2015, 07:41 AM   #1
Region: New Mexico
Recently I had a GT500 differential cover installed on my 2007 GT. After arriving home and looking at the invoice, I noticed that the shop put 3.5 quarts of fluid and another one of friction modifier. In scouting the forums, the GT500 cover would only require 4.6 pints. I'm thinking that I need pull the filler plug and let whatever overfilled fluid drain out. Comments??
rogcat1 is offline   Reply With Quote
Old 05-02-2015, 08:06 PM   #2
Unless the differential was filled with the rear end not level, the most that they could have filled it is up to the bottom of the refill plug.
Old 05-03-2015, 07:00 AM   #3
Region: New Mexico
The GT500 differential cover has a drain plug at the bottom, and a fill plug at the top. My guess is that the tech. filled it to the edge of the top plug, and not the regular fill hole.
Old 05-03-2015, 08:04 AM   #4
Scott2's Avatar
I agree with this observation. With your car level on four jack stands I would open the fill plug on the differential housing and let any excess fluid drain from there. Best done out of the garage because gear lube has been known to stink.
The friction modifier comes in a much smaller container than 1 quart. It is possible the GT500 cover adds a little volume as well over the OEM cover.
Old 05-03-2015, 09:46 AM   #5
Region: New Mexico
Unfortunately, I'll have to drain it in the garage, as my driveway slopes away from the house.
Old 05-03-2015, 09:54 AM   #6
Region: New Mexico
Scott2:
I looked at your photos. Not much left that's stock. Also, I've been considering the TCI ratchet shifter for my GT. What is your opinion on the shifter. By the way, very nice car.
Old 05-03-2015, 11:20 AM   #7
Scott2's Avatar
Scott2:
The TCI shifter is pretty cool, but I must admit I let the computer shift for me.
Thanks for the compliment on my car, I have been modding it for six years now and clearly I am addicted!
If you are draining gear lube in your garage I would put any paper towels you use to clean the diff housing in a couple layers of plastic bags and tie them closed. I maybe to sensitive but I hate the smell of gear lube especially any that has gone a few K miles.
Old 05-03-2015, 02:52 PM   #8
Region: New Mexico
My wife sees her car as a means of getting from point A to B, and nothing more, so mods on my car are something she doesn't understand. I grew up in Los Angeles when lowered customs and hot rods were king. When George Barris customs were awesome. Really like the looks of the TCI shifter, and may get it just for that reason. I appreciate your input about the differential fluid. My main concern was as to whether or not driving it with that amount of fluid in the diff. would damage anything. By the way, I'm 77 years young, and lovin modding my GT.
Old 05-03-2015, 04:28 PM   #9
Scott2's Avatar
OK, I am 63 years young and have had one arthritic hip replaced already. Still have arthritis in both knees and the killer....lower back. Modding my car is a slow process these days!
Old 05-03-2015, 07:09 PM   #10
Region: New Mexico
Getting old ain't for sissies. What I'm doing is reliving my youth. Had a 1951 Ford Victoria, that we chopped the top 3.5 inches, put on a carson top. Mercury grille, corners rounded on hood corners, with louvers, shaved door handles, trunk, frenched headlights, and taillight. Installed a 1956 Thunderbird engine. Oldsmobile spinners on the wheels. Obviously, lowered front and rear, couldn't pass over a pack of cigarettes without knocking them over. Ah, the good old days.
Old 05-03-2015, 10:03 PM   #11
Scott2's Avatar
The Victoria sounds really cool, don't get me going on the good old days, this is me a little over 40 years ago in a Boss 302 powered 1965 Comet.
Old 05-04-2015, 05:26 PM   #12
Region: New Mexico
Dealer agreed that they overfilled the diff. and will siphon off a quart.
Old 05-05-2015, 11:47 AM   #13
Region: New Mexico
Raced the 51 Vic at a deserted airstrip in Kansas City when I was in the military. Was very hard on clutches.
Old 05-06-2015, 06:26 PM   #14
tym_v6's Avatar
Make sure they check to make sure the pinion seal is still holding...they've been known to spring a leak.
Old 05-07-2015, 09:10 AM   #15
Region: New Mexico
Good idea. Also since they; overfilled the differential, I would think that the friction modifier would be diluted.
Old 06-08-2015, 06:47 PM   #16
Jon3.7's Avatar
Not if they put a quart in there lol.
You only need 4oz of friction modifier
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-09-2015, 04:13 PM   #17
WJBertrand's Avatar
Yup. Those ports on the GT500 cover are intended for an oil cooler so the upper one at least is not calibrated as a fill port, rather it's a return port for the cooler. The lower one does make a handy drain and may be reason enough to install one of those covers.
Surprised you weren't blowing lube out the breather cap all over the place!
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
redline differential oil question Horse Pre-2005 V6 Mustang 0 03-13-2007 09:16 PM
3.27 Rear gears with open differential for 7.5 SpectorV Mustang Parts for Sale and Wanted 0 11-19-2004 08:51 AM
Auburn Gear ECTED Differential 1995GT306CI 1979-1995 Mustang GT 1 09-24-2004 12:43 PM
how much differential fluid does a mustang hold? Horse Pre-2005 V6 Mustang 5 12-26-2003 02:45 PM
broke my differential, btw long time since i've been back Testicleez The Bar 0 11-05-2003 09:24 AM
05:29 PM
