Decoding data on the CAN buses (2014 GT) - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 05-31-2015, 06:34 PM   #1
Lightbulb Decoding data on the CAN buses (2014 GT)
Shortly after I bought my 2014 Mustang GT, I really wanted to start data logging, decoding, and commanding the various modules on the medium speed (MS-CAN) and high speed (HS-CAN) buses. I thought it'd be fun to reverse engineer some of the communication and build my own devices that could intercept data and command actions.
Has anyone else looked into this much on the 2011-2014 Mustangs? If there's anything you'd like help reverse engineering, let me know. I'll update this post with replies as I start to decode CAN messages that interest me (time data, location data, ambient lighting, etc.).
Decoded Messages:
MyColor Ambient Lighting
UnsightlyGuy is offline   Reply With Quote
Old 05-31-2015, 07:42 PM   #2
Changing the MyColor Ambient Lighting
Ambient lighting colors are changed via the MS-CAN bus. It might be interesting (read: gimmicky) to programmatically change the color based on speed or RPM. There's a dim high/low setting that I haven't reflected in the decoding, but I'll do that later.
Header:
Code:
3AC
Message (Hexadecimal):
Code:
[Byte1] [Byte2] [Byte3]
Byte 1:
01 - Disable ambient lighting
11 - Ice Blue
21 - White
31 - Green
41 - Purple
51 - Blue
61 - Orange
71 - Red
15 - Custom Color (MyColor 1, etc.)
Byte 2:
If byte 1 specifies a custom color (0x15), the upper 4 bits specify the red component of the color (0 - 5) and the lower four bits specify the green component of the color (0 - 5). E.g.: RG
Otherwise, the byte is 00.
Byte 3:
If byte 1 specifies a custom color (0x15), the upper 4 bits specify the blue component of the color (0 - 5) and the lower four bits are zero. E.g.: B0
Examples:
11 00 00 - Change ambient lighting to ice blue.
71 00 00 - Change ambient lighting to red.
15 13 50 - Change ambient lighting to RGB color 1, 3, 5 (blue-greenish).
15 51 30 - Change ambient lighting to RGB color 5, 1, 3 (purplish).
Old 06-11-2015, 08:35 PM   #3
HVAC Temperatures
Receiving HVAC Temperatures
Temperatures related to HVAC are broadcast on the MS-CAN bus. This message could be used when developing an
alternative navigation unit or whatever.
Header:
Code:
3C8
Code:
[Byte1] [Byte2] [Byte3] [Byte4] [Byte5] [Byte6] [Byte7] [Byte8]
Bytes 1 and 2 - Driver Side Set Temperature:
XXXXUUUU XXXXLLLL
XXXX = 0x3
UUUU = Temperature (Tens)
LLLL = Temperature (Ones)
The temperature can be set to 60, from 65 to 85, or 90 (degrees F).
Example #1: 00 00 - Off
Example #2: 37 34 - 74 degrees F
Bytes 3 and 4 - Passenger Side Set Temperature:
XXXXUUUU XXXXLLLL
Same as driver side set temperature.
Bytes 5 and 6 - External Temperature:
XXXXUUUU LLLLYYYY
XXXX = Unknown - Observed to be 0xC, but I haven't tested this extensively.
YYYY = Unknown - Observed to be 0x0, but I haven't tested this extensively.
Example: C8 40 - 84 degrees F
Byte 7 - Fan Speed:
0x20 - Off
0x21 - Auto
0x23 - Lowest Setting
0x25 - Second Setting
0x27 - Third Setting
0x29 - Fourth Setting
0x2B - Fifth Setting
0x2D - Sixth Setting
0x2F - Highest Setting
Byte 8 - Settings:
0x54 - Dual-zone disabled. Passenger side temperature set to 00 00.
0xD4 - Dual-zone enabled.
0x14 - Off? Both drivers side and passenger side temperatures set to 00 00.
Example:
37 30 00 00 C8 40 21 54
Driver side temperature set to 70 degrees F.
External temperature is 84 degrees F.
Fan setting set to auto.
Dual-zone disabled.
Old 06-15-2015, 05:11 AM   #4
Holy CRAP!
bodon is offline   Reply With Quote
Old 06-15-2015, 07:30 PM   #5
Originally Posted by bodon View Post
Holy CRAP!
Haha, I'm just getting started. I'll work on figuring out as much as I can on the MS-CAN bus (Audio Control, GPS, Front Controls, Front Display, Body Control, HVAC, Smart Junction Box, Instrument Panel, and APIM) and then transition to decoding HS-CAN messages.
If anyone wants to part off the various modules in their car (e.g.: parking assist), I'll buy them.
Some freeze frame data that popped up today when my CEL can on Sketchificus Pre-2005 V6 Mustang 1 07-21-2014 09:51 PM
engine decoding help! 1980rustang General Mustang Discussion 9 11-10-2009 12:05 PM
Decoding v6 transmission and axle falconplayer79 Pre-2005 V6 Mustang 17 09-11-2008 10:04 AM
decoding a 1964-1970 mustang oaktonarcher Classic Mustangs 1 11-16-2005 08:03 PM
GT dynograph data chart Justang 1996-2004 Mustang GT 0 05-21-2004 08:38 PM
01:09 PM
