2015 Mustang Gt Fluid changes - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 06-06-2015, 07:55 AM   #1
Just got a brand new 2015 6 Speed GT. At 1500 miles I plan on changing the oill, diff and manual transmission fluid. Anyone have a write up on the diff and manual fluid changes? Is there anything special I need to know? Thanks in advance!
Tennis_pro is offline   Reply With Quote
Old 06-06-2015, 04:04 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Engine oil I can understand, but why change the diff and trans fluids so early?
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 06-06-2015, 04:07 PM   #3
natestang07's Avatar
Maybe worried about metal flakes from stuff getting broken in? Who knos
Old 06-06-2015, 06:59 PM   #4
You guys don't think changing the transmission and diff fluid is a good idea early on?
Old 06-06-2015, 07:01 PM   #5
I'd check it to see how it looks, but isn't really necessary to change them this early. Unless you want to, if that's the case upgrade to better fluids.
Adventure till you drop
Old 06-06-2015, 07:10 PM   #6
Rapinator126's Avatar
Transmission fluid is a must. 1 thing in helping the mt82 problems. I did mine the day after I bought the car.
Old 06-06-2015, 07:15 PM   #7
Does the trans and diff fluid have a fill and drain plug or do you have to take the housing off?
Old 06-08-2015, 06:41 PM   #8
Jon3.7's Avatar
Diff fluid in a ford it suppose to be for life, according to motorcraft. But i change diff fluids around 50k.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-08-2015, 11:01 PM   #9
Are you racing the car at a track? Then all the standard replacement intervals don't apply. Most people I know will change all fluids after a long race day. Never hurts other than your wallet. Of course you need to add new brake pads and tires too.
v8shep is offline   Reply With Quote
Old 06-09-2015, 02:52 AM   #10
bucko's Avatar
The stock differential cover has a drain bolt, but not a fill bolt, or at least on the 2011 to 2014's it was this way. Might be a good time to install a Ford Racing differential cover, as it does have a fill (and drain) bolt.
Not sure on the new split axles where the fill is for the differential if the cover does not have one. On the earlier solid axles, the fill plug was on the drivers side axle near the differential.
Old 06-09-2015, 02:53 AM   #11
bucko's Avatar
To the original poster: apologies for some of the rude answers. They were removed.
Old 06-09-2015, 06:46 PM   #12
Jon3.7's Avatar
It doesn't have a full plug on the snout like previously?
I did not know this.
Old 10-31-2015, 06:18 AM   #13
So for my 2015 GT, also considering switching out the fluids on the MT82 and the lim slip diff (Royal Purple). Did you ever go through with this? Any issues?
COYOTE6 is offline   Reply With Quote
2015 mustang
2015 Mustang GT PP vs 2015 Camaro 1LE Ish416 2015 Mustang GT 111 06-12-2015 04:52 PM
2015 3.7 Vs 2015 2.3 ecoboost 2011 Kona Blue 2015+ Mustang Ecoboost (and V6) 114 01-05-2015 05:16 AM
What changes do I need to make on a 2004 Mustang GT to install factory Saleen supercharger? eljin 1996-2004 Mustang GT 4 12-21-2011 06:09 AM
2009 Ford Mustang Changes: What Would You Like To See? Dark02Pony 2011-2014 Mustang GT 109 07-13-2008 02:15 PM
**Changes made and changes to be made in the future ** Brent The Bar 12 10-24-2004 05:48 AM
05:48 PM
