Please someone help me with this issue!!! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 06-25-2015, 07:18 PM   #1
johnathan2225's Avatar
Region: West Virgina
I have a 94 mustang gt/99 mustang gt conversion.. (94 body and rear end, 99 everything else) it has a 4.6l 2v in it, followed by a 5 speed tranny, my problem is in the noise that the engine acquired, sounds to me more like it's top end, at around the 8th cylinder, thought that maybe flywheel issue, nope, clutch, nope, so I pulled the engine, and I pulled valve pans, and didn't see anything to be an issue, nothing loose, nothing stuck, seems smooth, so I pulled the oil pan, again I seen nothing out of the ordinary except for a tiny piece of metal about the size of a pencil eraser, and it was stuck to the bottom of the oil pick up tube, on the screen, however I didn't see any metal to metal rubbing or wear, and while rotation the engine manually, I seen no play in any rod, or wrist pin, and I'm stumped.. Any ideas??!?? Click image for larger version
Name:	ImageUploadedByMustang Evolution1435281499.709714.jpg
Woooot!!!!!
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 06-28-2015, 10:20 AM   #2
http://youtu.be/phPqVFHtwbA
Woooot!!!!!
Old 06-28-2015, 05:22 PM   #3
Jon3.7's Avatar
That's a rod knock, you need another motor..........
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-28-2015, 05:23 PM   #4
Na just rebuild this one.. Lol
Sponsored at;
http://www.carsponsors.com/dap/a/?a=86212
Old 06-28-2015, 05:26 PM   #5
Jon3.7's Avatar
well,better get started
Old 06-28-2015, 05:37 PM   #6
Done did, it's pulled.. Lol
Sponsored at;
Old 07-03-2015, 08:48 AM   #7
D a m n !!! Lol found more of the issueClick image for larger version
Name:	ImageUploadedByMustang Evolution1435934888.292010.jpg
Sponsored at;
Old 07-11-2015, 07:01 PM   #8
jeno's Avatar
Rod bearing?
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 07-12-2015, 06:15 AM   #9
Spun bearing
Sponsored at;
Old 07-12-2015, 02:24 PM   #10
jeno's Avatar
That's what I meant it looks like a rod bearing on the crank journal had spun I told you early on from your video it sounded like the rods in this case rod bearings so each the same lol
Did someone get someone get some parts I sold by mistake? Vintage Iron Mustang Parts for Sale and Wanted 3 05-11-2014 08:58 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 08:46 AM
someone please help me upton7 1996-2004 Mustang GT 2 01-14-2010 06:28 PM
Someone help me please!!! 01stang Pre-2005 V6 Mustang 7 05-10-2006 07:36 AM
08:47 PM
