no idle! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 07-04-2015, 08:32 AM   #1
no idle!
I have installed gt40p heads on my 302, has 30 over pistons with a mild cam flat top lifters. It will start run a few minutes n die, try to raise engine rpm , just dies! Desperate in Texas for help!
sam66 is offline   Reply With Quote
Old 07-04-2015, 08:46 AM   #2
johnathan2225's Avatar
Region: West Virgina
Tuned?
Sponsored at;
http://www.carsponsors.com/dap/a/?a=86212
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 07-04-2015, 08:51 AM   #3
no idle.
Yes , correct timing.
Old 07-04-2015, 08:52 AM   #4
Running smooth before it shuts off?
Sponsored at;
Old 07-11-2015, 07:00 PM   #5
jeno's Avatar
Did you check fuel pressure
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 07-13-2015, 10:34 AM   #6
Will check today hopefully it'll work,thanks bro,.
Old 07-13-2015, 06:28 PM   #7
jeno's Avatar
Let us know if that's the issue
Old 07-13-2015, 08:45 PM   #8
no idle
I will let you know , thanx !
Damn idle. IAC/TPS problems? Idle screw? Help! v8pony 1996-2004 Mustang GT 3 05-22-2015 01:39 PM
Set Idle Screw / Idle problem v8pony 1996-2004 Mustang GT 8 05-15-2015 10:07 PM
MIL P1414, rough idle BlueDonkey Pre-2005 V6 Mustang 7 11-13-2003 11:27 PM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
CAI installed... low idle problems... RedStang830 Pre-2005 V6 Mustang 16 08-03-2003 08:33 PM
06:52 AM
