94 3.8 Head Gasket - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 07-14-2015, 01:19 PM   #1
94 3.8 Head Gasket
Hello All,
This might be posted on here elsewhere but I couldnt seem to find the thread...
Last week my 94 3.8L massively overheated, blew the freeze out plug on the drivers side. Car stalled and wouldn't restart until it cooled down..had to drive the car home..about 15 miles 3 miles at a clip over the course of 3 hours letting it cool and refilling with water along the journey..
Replaced the freeze out with one of those rubber expandables, changed the oil, and found that there's water breaking through..
Removed the cylinder heads and found the break in the drivers side gasket..Also found that the cylinder closest to the firewall on the drivers side looks a little rust-ish, the wall of the cylinder is not as smooth as the others but nothing too bad..
I'm installing all new gaskets and having both heads milled..
My questions are:
What else could have been damaged by this overheating episode that I'm not thinking of?
What else should I replace while I'm in there?
Any insight would be greatly appreciated!
--Rob
Eth0 is offline   Reply With Quote
Old 07-15-2015, 07:06 AM   #2
Project Pony's Avatar
94 3.8 Head Gasket
I like to replace the radiator, hoses, pump and t stat. Might as well while its apart for cooling piece of mind. It also helps clear out in crud that may have been circulating in the system. At the very least give the system a good flush.
Ford realized they had an issue with head gaskets on the 94-95. I believe it was remedied for the 96-98 engines by increasing the torque specs on the head bolts. I don't have the exact numbers off the top of my head.
[SIGPIC][/SIGPIC]
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
12:06 PM
