14 GT high beam wire - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 08-17-2015, 01:34 AM   #1
Waylap1's Avatar
Region: New Hampshire
Does anyone know which wire and color I can tap into near the headlight housing for adding a relay triggered by high beams?
I think I'm going to install a pair of Rigid LED floods behind my lower grill mesh where they're hardly noticeable when they're off. I previously had these wired on a front brush guard on an Expedition. I wired them to a relay that's triggered when I turn on my high beams. Of course, they're not legal wired that way but ... I live in a very rural area that has frequent deer and moose hazards especially at night. The Rigid LEDs are jumbo jet bright and help me spot the critters. It's usually easy to tell if another vehicle is coming in plenty of time to turn off the high beams and Rigids so they're not blinded. *Also..if I simply wired them to my fog light wires, it would actually take longer to dim them off as compared to the high beam /low beam action. Before state inspection I just unplug them.
To get an idea, I drove about 15 miles to my part time / on call / supposedly I'm retired job tonight around midnight. I think I saw two other cars the whole time. It's two lane mountain roads 40-50 mph limit. VERY moose infested area.
I previously wired it to the high beams using the cut and splice trial and error method but I'd rather not cut unnecessary stuff this time.
Waylap1 is offline   Reply With Quote
Old 08-17-2015, 02:49 AM   #2
Waylap1's Avatar
Here they were on my Expedition. Could see the deer in plenty of time to crush them.
Old 08-26-2015, 09:59 AM   #3
20prima10's Avatar
Well u don't have to cut and splice. U can grab a simple pair of wire strippers.
Here's the method
Use the correct gauge selection and cut into the wire insulation without cutting the wire. With it still on the wire just slid down the insulation a little bit and expose some bare wire. Wrap your new wire on and presto. You have a spliced in connecting with out cutting factory wires. If you've got the wrong wire simply undo the connection and tape it back up so its properly insulated and you'll never cut a factory wire again
Hope that helps
2013 pp mca 3.7 glass roof
2.5% dl tinted windows
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
More coming visually for now.
20prima10 is offline   Reply With Quote
Hi! 99-01 SVT cobra high beam problems (Australia) ozcobra New Member Introductions & Greetings 3 08-31-2014 11:21 PM
Drivers side high beam doesn't turn on 1997mustanggt 1996-2004 Mustang GT 8 10-25-2013 09:21 PM
HID High Beam issue zinc_yellow 1996-2004 Mustang GT 6 03-19-2013 12:06 PM
FS High beam fog light kit! SerbStang Mustang Parts for Sale and Wanted 13 10-13-2011 03:05 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
11:30 PM
