Which color is hot wire? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 10-03-2015, 12:29 PM   #1
Waylap1's Avatar
Region: New Hampshire
Installing a 3rd brake light flasher on 2014 GT. There's a solid black and a black with yellow stripe..anybody know for sure, which is which?
Waylap1 is offline   Reply With Quote
Old 10-03-2015, 12:38 PM   #2
Rosariors3's Avatar
Anytime there is a solid black I c that as being the ground
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 10-12-2015, 03:48 PM   #3
Diehard's Avatar
Can't you test it with a multi-tester?
Old 10-12-2015, 03:55 PM   #4
Originally Posted by diehard View Post
can't you test it with a multi-tester?
or test light!
But it's b/y
ALLYDRIVER1 is offline   Reply With Quote
Old 10-12-2015, 03:56 PM   #5
Rosariors3's Avatar
I'm sure he figured it out by now
Old 10-12-2015, 04:28 PM   #6
Diehard's Avatar
Forgot to look at the date.
LOL
Old 10-12-2015, 04:32 PM   #7
Rosariors3's Avatar
LOL
It happens...guy prob feels no love cause nobody responded
Old 10-13-2015, 08:30 AM   #8
Panther140's Avatar
Thread could still help somebody.
The wire with the stripe is usually positive. But, there are exceptions because cars are sometimes tampered with or partially designed by imbeciles.
Panther140 is offline   Reply With Quote
Old 10-13-2015, 09:55 AM   #9
Waylap1's Avatar
It was the black with yellow stripe= positive. Figured all black most always means ground. By the way, the 3rd brake light flasher works great. It's from 3rdbrakeflasher dot com. About a dime sized circuit board you splice in and has lots of different flash patterns, delays, etc. I've got mine set for four quick flashes and then stays solid on. You can even set the on/off brightness so it can be "modulating" from dim to bright instead of off /on completely.
Old 01-12-2016, 09:24 AM   #10
Soosliknj's Avatar
Waylap, could you give a little more info on the product. It sounds good. The site has 3 different flashers. Which model did you purchase and could you give some pointers on installation please
Soosliknj is offline   Reply With Quote
Wire Color kprier Pre-2005 V6 Mustang 4 07-17-2014 12:37 AM
Need to connect red wire to gray wire. clflorida Pre-2005 V6 Mustang 4 08-06-2013 06:46 PM
Hot wire buck3405 Classic Mustangs 4 11-09-2012 07:43 AM
Help! Remote wire color BuddyLee Mustang Audio & Video 18 03-12-2005 07:48 AM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
03:51 AM
