Brake lever 😡 - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 10-16-2015, 07:19 PM   #1
StangGT04's Avatar
Brake lever 😡
As anyone had the brake break when you pull it up to set the brakes? Check out the pic. 😡😡😡😡
StangGT04 is offline   Reply With Quote
Old 10-16-2015, 07:34 PM   #2
StangGT04's Avatar
Originally Posted by StangGT04 View Post
As anyone had the brake lever break when you pull it up to set the brakes? Check out the pic. dde21dde21dde21dde21
Old 10-16-2015, 07:36 PM   #3
natestang07's Avatar
Sounds like you need to stay away from the gym for awhile
Old 10-16-2015, 07:56 PM   #4
StangGT04's Avatar
Wish that was the case it was my son how is 16 that pulled it and he is a tooth pick.....
Old 10-16-2015, 08:50 PM   #5
Originally Posted by stanggt04 View Post
wish that was the case it was my son how is 16 that pulled it and he is a tooth pick.....
must have been doing those bootlegger turns
ALLYDRIVER1 is offline   Reply With Quote
Old 10-17-2015, 09:38 PM   #6
Mean14's Avatar
Same thing happened when I had my 2000. It's an easy fix, but its kinda hard to explain..
Take off the nut and thread (yellow circle)
Once it is off, get a couple washers that are significantly bigger than the hole (red circle) but make sure the thread is able to go through the washers.
You will have to go under the car to do this and will need an extra hand.
Put the washers in-between the body of the car, and above the broken off part (black circle)
Have someone from above thread that nut on.
From below, hold the broken off threaded piece with a pair of pliers.
Have the other person in the car tighten the nut down until it is snug.
The idea is to wedge the washers between the body and the broken piece so it does not pull out when you lift up on the brake.
This beats having to weld it back in place.
Let me know if you have any questions.
Hope this helps.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 10-20-2015, 06:16 PM   #7
StangGT04's Avatar
Thanks for the help that is the exactly what I did and it is rocksolid.
Water lever sensor Super 2005-2010 V6 Mustang 5 04-05-2013 11:15 PM
Kickdown lever BA68 mustang Classic Mustangs 2 09-11-2012 04:31 AM
turn signal lever assembly 96NYCGT 1996-2004 Mustang GT 0 06-05-2012 02:36 PM
Rear seat lever JBillone 2005-2010 V6 Mustang 3 05-23-2012 03:10 PM
clutch lever boot SOCK 1979-1995 Mustang GT 17 12-14-2008 02:56 PM
02:00 AM
