DIY - Personalized Emblem (plasti dip) - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 10-22-2015, 12:46 PM   #1
Seatown Stang's Avatar
If your looking to add some uniqueness to the ride or just wan to see what it'll look like before you purchase a pair of blacked out emblems.
Video: https://www.youtube.com/channel/UCZz...T0tJF-xBWOEOeA
Tools needed:
Paper
painters tape
scissors
razor
Plasti Dip
Step 1:
cut a rectangle in the paper a little larger than the emblem size and tape it to the car
Step 2:
place tape over the "Point", press it into the corners and use a razor or shape knife to cut.
Step 3:
Paint. 1st coat get a 50/50 coverage and the 2-3 more wet coats after that. allow about 2-3 mins between coats.
Step 4:
Remove tape from "Point" immediately after last coat is laid. This will allow for a nice straight cut around the point without having to worry about pulling up the plasti dip around the area.
Step 5: (if you have a vinyl overlay for the point)
place overlay in point and you are done...almost
Step 6: clean up
Clean up any over spray by rubbing it with a micro fiber towel.
2015 Mustang GT Premium
Mods: Lund Tuned, AWE Switchpath Catback, AirRaid CAI, Eibach Pro-kit Springs, 3.55 gears, Ferrada FR2 20x9 and 20x10.5, APR Splitter, RTR front Grill, Steeda subframe braces, Steeda differential bushings, Steeda IRS bushing support, BMR Vertical Links, BMR Lower Control Arm Bearing kit (BK055), BMR Front subframe brace.
Seatown Stang is offline   Reply With Quote
Old 10-22-2015, 01:21 PM   #2
oxford5pointoh's Avatar
Great little write up, however tons of heartache could be avoided by using a much larger piece of newspaper for the masking. This would avoid the overspray al over the fender and door that will be thin little patchy blobs of dip that someone will have to clean off. On a black car especially, this clean up could cause scratching or swirls.
Just thought I'd throw that out there in case someone uses this as their bible when attempting this.
Old 10-23-2015, 10:30 AM   #3
kapcan2k's Avatar
Great write up. I did the same thing on my car. I was my first time plasti -dipping anything and I was amazed how easy it was to do. It actually feels good peeling it off and watching how it breaks away at the edges so neatly.
kapcan2k is offline   Reply With Quote
Old 10-23-2015, 10:33 AM   #4
DiESeven's Avatar
Don't be lazy with preparation. It makes clean up 100% easier and faster.
Old 10-23-2015, 10:46 AM   #5
kapcan2k's Avatar
This was my setup
Plasti-Dip Rear Emblem Letters StormTrooperV6 Mustang Paint, Appearance & Detailing 5 11-07-2013 06:31 PM
Plasti-Dip Rear Emblem Letters StormTrooperV6 Mustang Paint, Appearance & Detailing 0 10-30-2013 02:26 PM
to plasti dip or not plasti dip ebgonzalez1 2011-2014 V6 Mustang 17 09-15-2012 03:52 PM
Personalized Plates Dragon_Lady The Bar 44 07-11-2008 11:36 AM
Personalized tag ideas lowflyn The Bar 50 10-13-2005 12:11 AM
10:19 PM
