Springs - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 12-06-2015, 10:33 AM   #1
Blue_5slow's Avatar
Springs
Just bought SR performance lowering springs do I immediately need new strut mounts? Or can I use stock?
Blue_5slow is offline   Reply With Quote
Old 12-06-2015, 03:14 PM   #2
The_Chech's Avatar
How old are the stock struts/shocks? You can run the stock ones for awhile but isn't recommend by any means.
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 12-06-2015, 04:28 PM   #3
Blue_5slow's Avatar
It's a 2013 mustang so only 2 years
Old 12-06-2015, 05:22 PM   #4
Cooolbreeez's Avatar
I was under the impression that with the drop the SR springs give you, you would be ok running stock shocks and struts until they wore out. I heard they will wear out quicker but that was all. Maybe the gt is different than the v6 when it comes to lowering springs?
Cooolbreeez is offline   Reply With Quote
Old 12-06-2015, 05:40 PM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It's not just the drop. It's the spring rate (stiffness) of aftermarket springs that wear out the factory struts and shocks. Looks like the SR springs are approx. 70 lb./in. stiffer than factory specs which make them one of the stiffer sets of springs. In this case, I would advise getting aftermarket shocks/struts to pair with the SR springs.
2012 Kona Blue 3.7L V6:
Old 12-06-2015, 08:35 PM   #6
Blue_5slow's Avatar
Thanks guys I just picked them up because I had issues with the stock springs and a friend had the SRs nearby and it says on AM about a different strut mount needed I just need it to work for a Week until those come in.
Old 12-06-2015, 08:57 PM   #7
I put my SR springs on with the factory strut mount, no issues.
Old 12-06-2015, 09:41 PM   #8
Blue_5slow's Avatar
Awesome thanks man!
Old 12-07-2015, 12:50 PM   #9
Blue_5slow's Avatar
Got the springs on and everything came out perfect thanks guy!
Old 12-07-2015, 04:22 PM   #10
Throw up a pic so we can see the outcome.
Old 12-07-2015, 05:01 PM   #11
Blue_5slow's Avatar
Name:	ImageUploadedByMustang Evolution1449532839.571793.jpg
ID:	194519thats the best I could get while being at work
Old 12-07-2015, 05:11 PM   #12
Looks good! The front looks lower on mine as well.
Old 12-07-2015, 05:31 PM   #13
Blue_5slow's Avatar
Yeah I'm hoping it will settle a little better
Cut springs to H&R Springs Slow4V 1996-2004 Mustang GT 4 10-16-2014 02:03 PM
BMR springs vs Ford K Springs Rolltide 2011-2014 Mustang GT 5 08-01-2012 09:57 PM
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 08:42 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
11:14 PM
