Clutch fluid line - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 12-12-2015, 10:56 PM   #1
Clutch fluid line
Replaced clutch fluid line. Everything seemed to go well. Bled it as directed (pumped pedal 100x plus), drove fine, then pedal dropped a bit after about an hour. Bled again as directed. Was fine then dropped a bit again. Any idea what's up here? This is a self bleeding system on a 2015 GT.
COYOTE6 is offline   Reply With Quote
Old 12-13-2015, 03:50 PM   #2
Self clutch bleed didn't work. This procedure in the linked video did work except had to use different size stopper, had to repeat process about ten times and then I tried lifting the pedal to check for upward play and it popped up. Yay. Did a few more cycles. Seems perfect.
Mustang clutch bleeding procedure:
http://youtu.be/HkmFh7hxico
That all said replacing the factory clutch fluid line with Steeda stainless steel was a success. Dealer replaced clutch at 3000, and was still experiencing difficulties clutching into gear, particularly into first without either going to fast or too slow on release. Car is nearing perfection.
Old 12-15-2015, 08:08 AM   #3
Strange Mud's Avatar
on my 2012 I had to re-bleed it the next day (easier than day 1). I'll toss out my hint of tying a piece of string to the clips BEFORE you remove them as they are hard to find if they go flying.
Old 12-15-2015, 02:49 PM   #4
Clutch fluid line
On my 2015, the clips were secured... They only slid out far enough to allow removal and installation of line then popped back in. I wouldn't count on this nice feature in future but it was a small relief.
Fluid coming from back right tire along gas line Flyrocket Pre-2005 V6 Mustang 0 06-24-2014 02:42 PM
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
Clutch fluid line?? muscledom 2005-2010 Mustang GT 2 12-19-2012 12:09 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
11:35 PM
