2013 HID headlights using custom harness to connect to 2011-2012 nonHID - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 01-15-2016, 07:40 PM   #1
I want to thank LEXiiON, ebalderas and 5.0verkill.
Below are my findings in my quest to build a harness. So I hope this helps others make there own harnesses. all parts were purchased on eBay. except for wrap solder shrink wrap harbor freight.
Pin 1 Low beam
Pin 3 DRL Power Full
Pin 5 DRL Power Dim
Pin 8 Ballast Ground
Pin 10 Power Ballast
Pin 12 Power High beam
Pin 14 Ground
Using Motocraft WPT 1357
I wired pins 1 and 10 together for power and pin 8 for ground to connect to the morimoto harness ballast plug using a male 9006 pigtail
I wired pins 3 power DRl 9006 pigtail to connect to Diodedynamics DS1 switchback driver
Did not use pin 5 drl power dim
Connected pin 12 power high beam and pin 14 ground to male 9006 pigtail. To connect to morimoto harness high beam plug.
For the turn signal I used a 7444 pigtail and connected to a 9006 male pigtail to connect to Diodedynamics DS1 switchback driver(Output used ground and yellow for turn signal and the white alone since headlight uses common ground for DRL). I first connected 7444 to 3157 to figure which two wires made turn signal flash since you do not use the other wire(used yellow and ground input).
I connected the 3157 directly to the switchback since this will connect to old turn signal bulb. Remember if it does not work rotate plug.
I ran a power wire from fuse 39 using a fuseblade to power switchbacks which in turn powered DRL
harness diagram
Materials needed
8 WIRE PIGTAIL MALE 9006 HB4 ONE HARNESS CERAMIC HEADLIGHT REPLACEMENT PLUG SOCKET
1 Small ACS-J Add A Circuit Piggy Back Pluggable Standard Blade Tap Fuse Holder
1 Morimoto MotoControl Bixenon: H13 9008 Harness TRS
2 Motorcraft WPT1357 Headlamp Connector
2 Diodedynamics DS1 switchback driver
2 Pre Wired Heavy Duty T20 Sockets Plugs Connectors Wiring Harness 7443 7444 992A
2 WIRE HALOGEN MINIATURE PIGTAIL MALE 3157 3457 TWO HARNESS REPLACE CABLE LAMP
Misc
Heat shrink
Split tube wire wrap 3/8
Solder
Below are my finished products
turn signal with morimoto switchback drivers(old photo use Diodedynamics DS1 switchback driver wired )
turn signal bulb harness
pigtail harness
9006 connectors connect to switchback and morimoto harness
16 pin connector
vartech is offline   Reply With Quote
Making my own 2013 HID harness have parts need guidance vartech Mustang 101 - Tech Basics | Ask an Expert 0 12-01-2015 09:15 AM
For Sale: 2011-2012 OEM HID Headlights Stang8psi Mustang Parts for Sale and Wanted 10 07-02-2013 10:51 AM
Facebook Connect Brent ME Site Help & Announcements 12 05-28-2009 12:00 PM
How to Connect two amps together? HELP! stangfreak12243 Mustang Audio & Video 2 11-26-2006 01:22 PM
Ultra X-Connect 500watt Power supply unit (for computer) SpectorV Mustang Parts for Sale and Wanted 1 04-21-2005 12:29 PM
09:41 AM
