Rear end troubles. - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 02-19-2016, 01:41 PM   #1
Region: Alaska
Rear end troubles.
Ok so, my cars been out of commission for 6 months now. And I haven't really found a strong solution, I've gotten a lot of suggestions but no real answers. Basically there are a few reasons as to how or why this happened, but I am focused on how to fix it preferably diy. The sheet metal mount for the rear control arms has sheared under the bump stop and all the weds have broken around the edge of the mount on the right side, and as of now the right rear wheel moves in any direction it wants limited by the spring and struts. And I am interested in what is the best viable way to fix this mount or replace the sheet metal, while keeping the rear axel in-line. I have brought it to a shop here in my small town and he said there are kits available online but they are not cheap. But I've gotten ideas from welding the sheet metal back in place, thought I don't want to burn through or warp the unibody, and it won't be as solid of a fix, to getting aircraft rivets cutting from under the rear seat and riveting the newly section right mount and then same to the attached left side to reinforce it. Or I could cut the whole mount out and replace it with steel yet I don't exactly know how I would do that other than maybe putting bolts through with another steel plate on the back side so as to now ruin or tear through the sheet metal. So any suggestions or thoughts would be greatly appreciated.
Sandyford is offline   Reply With Quote
Old 02-19-2016, 01:46 PM   #2
Region: Alaska
Name:	ImageUploadedByMustang Evolution1455911025.707691.jpg
ID:	197226Click image for larger version
Name:	ImageUploadedByMustang Evolution1455911061.962146.jpg
ID:	197227Click image for larger version
Name:	ImageUploadedByMustang Evolution1455911152.943521.jpg
Here are a few pictures to help visualize what I am talking about.
Old 02-19-2016, 06:04 PM   #3
The kits to weld over the existing mounts is about $80. Not too expensive. Find a shop that is decent with metal and they can rebuild the mounts. Reinforce all of them.
Sent from my XT1045 using Tapatalk
Old 02-25-2016, 04:32 PM   #4
Region: Alaska
Well where would I find this kit at 80 dollars?And I'm in Alaska on a small island to my options are limited.
Old 02-25-2016, 06:45 PM   #5
Google mustang battle box. That's the trade name for them. Find someone that will ship to you and you'll be good.
ST Suspension Rear Sway Bar Install Troubles ViperMKII 2011-2014 V6 Mustang 26 01-22-2016 06:42 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 04:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 07:56 PM
Headlight Troubles xtremestang Mustang Audio & Video 14 11-06-2004 07:08 AM
Relationship troubles. MusclesFromBrussels The Bar 3 07-19-2003 03:42 PM
12:10 PM
