Frantz Oil Bypass - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 06-16-2016, 07:40 AM   #1
Revvv's Avatar
Frantz Oil Bypass
Out of pure boredom, driven by insomnia, I decided to research Frantz. I have seen a few advertisements, and the company has been around for half a century.
I am always looking for innovative products that actually work. If a product on the market with the ability to truly filter motor oil to perfection exists I want to know about it. In my mind I want to believe that if such a product existed auto manufacturers would be using it, and promotions would be everywhere. This is definitely not the case.
The more I learned, the more amused I became. The Frantz system is nothing more than a can stuffed with toilet paper. I know some of you guys already know this, but many have never heard of Frantz before.
The first shock came when I saw that the system does not come with all of the parts required for an install. You still need to purchase additional items before you can use the system.
Then I noticed the price for the incomplete kit is more than $200.
I'm my disbelief I kept reading and researching. I wanted to believe that there was an actual filter element not intended to degrade in water. Are they really using single ply toilet paper? After all, this is a 40 plus year old system. Certainly by now the company has improved upon the design, right?
For more than $200 you get an incomplete bypass system that is essentially a sealed metal toilet paper roll container. The company is using the same design it began with.
I have to admit, I am amused. I had to share this with you guys. I could be wrong on every aspect, but I am not seeing the value of modifying my engine oil filtration system (you still use a standard filter with the bypass from my understanding) to install a roll of toilet paper.
Old 06-30-2016, 07:21 PM   #2
Up until the early 50's there were quite a few vehicles that did not come equipped with an oil filter. Hence, filtering devices like you describe.
I remember that my dad had a Chevy truck with one installed.
Are you considering purchasing a toilet paper oil filter for your car Revvv?
Old 06-30-2016, 10:18 PM   #3
Revvv's Avatar
Not a chance. I kept seeing the bypasses promoted and decided to see if the design had changed. Apparently everything is the same.
I will keep relying on my Wix filters.
Old 06-30-2016, 10:25 PM   #4
They actually worked better than... well... Nothing!
Old 06-30-2016, 10:28 PM   #5
Revvv's Avatar
I will agree with that.
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 12:37 PM
Water Pump Bypass Tube Rainman64 1979-1995 Mustang GT 1 07-19-2009 10:52 PM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 03:57 PM
Free new modification for 05's!!!! "Coolent bypass trick" ricklmesa Pre-2005 V6 Mustang 10 10-29-2006 12:41 AM
A/C bypass pulley chadderkdawg 1979-1995 Mustang GT 2 08-01-2006 09:22 AM
03:22 PM
