Squeaky noise coming from fan/ac - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 10-03-2016, 02:24 PM   #1
turnuptheluv's Avatar
I have a '14 gt manual trans, and for the last week or so I've had a squeaking noise whenever I turn my fan on as well as the ac, the higher the setting for fan the higher the squeaking I'm not sure if it's a belt or the ac compressor or maybe clutch? Im assuming it is something minor that could be making this noise??
turnuptheluv is offline   Reply With Quote
Old 10-04-2016, 10:26 AM   #2
Strange Mud's Avatar
a 2-3' length of hose works well as a mechanics stethoscope (BE CAREFUL!!) but if it's under wtty bring it in. If the sound changes with fan speed it's prob the fan.
Old 07-17-2017, 10:15 AM   #3
redbeast0712's Avatar
Region: Nevada
Is it kinda like a chirping sound?
Sent from my SM-G930T using Mustang Evolution mobile app
redbeast0712 is offline   Reply With Quote
Old 07-17-2017, 11:20 AM   #4
Region: Nevada
This sounds like your blower motor, and speed control card. It's located under your dash on the passenger side. To make sure it still good, check the connection from the pig tail to the fan speed card. If you see one of the connection burnt out then it will need to be replaced. If no warranty on your card search for the part online they will be cheaper then paying ford to do it. I had this done on my 2012 ford fusion. ford quoted me 900$ I did it myself with parts i found for little over 100$. This is only if you hear the squeaking or chirping coming from inside the cabin. If it sounds like it coming from the engine bay then it's the a.c. components and/or just the belt.
Squeaky noise 96smoke 1996-2004 Mustang GT 8 12-03-2013 03:34 PM
Squeaky noise? Mflores14 1996-2004 Mustang GT 14 01-28-2013 08:14 PM
Clutch pedal makes squeaky noise galindojr24 2005-2010 Mustang GT 6 10-30-2012 12:37 PM
Squeaky spring noise :( Mandy4 General Car Discussion 24 07-20-2012 01:09 PM
same squeaky noise. Butch SVT Mustang 9 04-10-2012 01:21 PM
02:53 AM
