3.8 engine swap to 4.6 - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > Mustang DIY and Technical
Old 12-28-2017, 09:56 AM   #1
Rocdahitman's Avatar
I've got a 1998 mustang with a 3.8 in it and I want to know if I can swap that out for a 4.6 out of a 2000 gt?
Sent from my XT1080 using Mustang Evolution mobile app
Rocdahitman is offline   Reply With Quote
Old 12-28-2017, 10:23 AM   #2
The short answer is yes.
There are those who will ask why you would want to do something like that though. When you could just purchase a 98 Mustang GT, or a 2000, for that matter, which Ford has already kindly installed a 4.6 in at their factory...
Old 12-28-2017, 11:48 AM   #3
Will be cheaper to sell your car and buy a GT. Not making that up. Its not as simple as just dropping in the 4.6L and hooking a few things up. You'll basically need an entire donor car for wiring, ECU/cluster, suspension, rear, trans, brakes etc... If you want to do it right anyway.
So sell your car and buy a nice cheap 96-98 V8 and PI swap it.
Old 12-28-2017, 12:02 PM   #4
That's the thing I've already got a 2000 GT that's been recked so I have everything I need just wanted to know if it was possible. The 98 3.8 through a rod so instead of rebuilding I wanted to use the 4.6 I got. Thanks for the information
Old 12-28-2017, 01:29 PM   #5
If you have a donor car already then gut the V6, remove wiring and fuel and then swap EVERYTHING from the 00 into it.
Old 12-28-2017, 02:30 PM   #6
Ok thanks alot
Old 12-28-2017, 04:47 PM   #7
Yep. Or you can sell the V6 and part out the 00GT and then just buy a runner depending on how much work you wanna do.
You may need to buy a Stiffler's crossmember to get that transmission in there tho, the stock setup for the t5 might not work.
Engine swap elijah.m.b 2005-2010 Mustang GT 27 01-18-2014 11:27 AM
Engine Swap: Manual Engine, Automatic Car? field 1979-1995 Mustang GT 1 12-18-2011 07:13 AM
Engine swap, here we go Mustanglife General Mustang Discussion 65 07-05-2011 09:07 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 03:01 PM
07:23 PM
