Shifting in 2015 Mustang GT with performance package - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 02-12-2015, 12:32 PM   #1
I have a 2015 mustang GT with the performance package 3.73 slip differential. I think the car is kinda jerky for the first 2 gear. This is a mustang that I have ever owned and it there any tricks and advice driving with this clutch? I have driven VW GTI and the clutch is very easy to use and I don't have problem driving it smoothly at all. Is there anything I need to pay attention when I'm driving a manual in the mustang in general?
jackiegnat is offline   Reply With Quote
Old 02-12-2015, 02:54 PM   #2
lion0432's Avatar
Have exactly the same question here!
lion0432 is offline   Reply With Quote
Old 02-12-2015, 02:56 PM   #3
lion0432's Avatar
Originally Posted by jackiegnat View Post
I have a 2015 mustang GT with the performance package 3.71 slip differential. I think the car is kinda jerky for the first 2 gear. This is a mustang that I have ever owned and it there any tricks and advice driving with this clutch? I have driven VW GTI and the clutch is very easy to use and I don't have problem driving it smoothly at all. Is there anything I need to pay attention when I'm driving a manual in the mustang in general?
I also have the Same problem . The way I am dealing with it is that I wait for a second to release the clutch when I go into 2nd gear
Old 02-12-2015, 05:54 PM   #4
WJBertrand's Avatar
Practice, practice, practice....
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 02-12-2015, 06:43 PM   #5
What RPM do you normally shift at?
Old 02-12-2015, 06:46 PM   #6
Another thing to consider is that on mustangs the shifter is bolted to the transmission where as on the VW the transmission is in the front of the car and it is linked to the transmission by a cable. Due to that its going to have a lot different feel to the way it shifts.
StarzTA17 is offline   Reply With Quote
Old 02-12-2015, 08:30 PM   #7
lion0432's Avatar
2500-3000 how about u?
Old 02-12-2015, 08:53 PM   #8
I think that's a good RPM because at that range it is smoother. If I shift at lower RPM, I have to let go the clutch even slower.
Old 02-13-2015, 06:42 AM   #9
lion0432's Avatar
Well, it still get jerky from 1st to 2nd sometimes. Just have to practice i guess?
Old 02-13-2015, 10:46 AM   #10
Byock's Avatar
Region: Utah
On the 2014, it get notchy. I'm actually surprised they didn't fix that in the 2015.
Byock is offline   Reply With Quote
Old 02-13-2015, 11:52 AM   #11
lion0432's Avatar
Would changing to a short shifter help?
Old 02-13-2015, 12:21 PM   #12
Site Sponsor
Sponsor
AMWill's Avatar
Hey Jackie,
As everyone has stated, this is a pretty normal occurrence for the MT-82 and stock shifter.
I have seen the Whiteline Transmission Mount Bushing help some people out with this issue and for the price you can't beat it!
I would definitely give it a shot!
Hope this helps and let me know if you have any questions!
-Will
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-13-2015, 12:27 PM   #13
Lorraine's driver
ab_mach1's Avatar
I think you just need to get used to this clutch, shifter, and the position you are sitting in compared to your other ride. When I test drove a '15, I about put the clutch pedal through the floor because it was so much more lighter than mine. The shifter sits up real high compared to mine as well. It would take me some time to get used to it if it was me anyways.
Instagram: @ab_mach1
Old 02-13-2015, 12:32 PM   #14
mustang8918's Avatar
I do this trick every few weeks in my '14 and it helps me.
Turn the key to ON and wait til all the normal lights in the dash go out, then slowly press the gas pedal until it is floored and release. Turn key off, wait about 6 seconds and then start your car.
It may not help you but it helped me, after a few weeks it's really bad and sometimes will even stall but after I do this little reset, it's as smooth as butter. Just give it a try, if it doesn't work then no harm no foul.
2014 GT Manual, American Muscle.
mustang8918 is offline   Reply With Quote
Old 02-13-2015, 01:49 PM   #15
Byock's Avatar
Region: Utah
AMWill, would that help with the 1-2 lockout? or should I look at the Barton shifter for that?
Old 02-13-2015, 03:21 PM   #16
I would say any after market shifter is better then stock. MGW best I have shifted no lock out or missing 3rd. MUST adjust it on install to ones own feel.
Teak 14 is offline   Reply With Quote
Old 02-13-2015, 03:37 PM   #17
This trick worked for my '14. It came from someone else on this site.
"Turn the key to ON and wait til all the normal lights in the dash go out, then slowly press the gas pedal until it is floored and release. Turn key off, wait about 6 seconds and then start your car."
If it works then cool and if it doesn't you've lost nothing.
Old 02-13-2015, 04:54 PM   #18
str8edgect's Avatar
Try this tip from stangtv.com. I really like the feel of my pedal after removal. The stock shift does take some time...practice makes perfect.
http://www.stangtv.com/project-5-lit...n-two-minutes/
2015 Mustang GT - Competition Orange
str8edgect is offline   Reply With Quote
Old 02-13-2015, 05:41 PM   #19
Lorraine's driver
ab_mach1's Avatar
Nice! Very helpful.
IG: @azurebluemach
Old 02-15-2015, 03:34 AM   #20
The 4th gear in my 2015 GT manual was defective/damaged/shifting incorrectly by 244 miles on the odometer. It's ready for a rebuild. At least you're doing better than me!
15mustang is offline   Reply With Quote
Old 02-15-2015, 06:25 AM   #21
lion0432's Avatar
Wow! Why? Is the warranty cover it?
Old 02-17-2015, 11:36 AM   #22
Did you push your car too hard before 1000 mile break in period?
I stalled my car so many times when I first start driving it and I hope my car it's fine too
Old 02-17-2015, 11:54 AM   #23
Byock's Avatar
Region: Utah
I like the feel of the stock clutch. Does removing the spring make it much harder to press in?
Old 02-17-2015, 01:31 PM   #24
lion0432's Avatar
How is driving hard? I went up to 3500-4000 a few times, would it hurt the engine?
Old 02-17-2015, 07:37 PM   #25
Brand New 2015 Mustang with Bad Manual Transmission
Nope, actually I made the mistake of leaving my 2015 Mustang GT with a local dealership for paint repair, Bozard Ford, and when they returned it to me the transmission wouldn't shift correctly. Somehow the shift quality became very poor and the transmission got damaged when I left the keys with them.
Moral of the story, don't leave your car keys without a dash-cam in your car!!
Please support mustang owners by reading my story here:
Old 02-17-2015, 09:23 PM   #26
str8edgect's Avatar
What kind of bootleg dealership are they...my 6 year old nephew could do a better job
Old 02-18-2015, 07:34 PM   #27
mchsmith3's Avatar
I felt the same thing with my 2015 GT, I got the Bama tune from American Muscle and it smoothed the shifting out perfectly!! Hope this helps,
http://www.americanmuscle.com/x4-cus...er-2015gt.html
mchsmith3 is offline   Reply With Quote
Old 02-18-2015, 09:45 PM   #28
mats96744's Avatar
manual or automatic transmission?
mats96744 is offline   Reply With Quote
Old 02-19-2015, 02:36 AM   #29
mchsmith3's Avatar
I have a manual transmission, the tune cleaned up the shifting from first into second. I had the exact same issue everyone is referring to and the tune took care of the issue. I have put on about 200+ miles since the Bama performance tune was installed, and It cleaned it up 100%
Old 02-19-2015, 06:36 AM   #30
lion0432's Avatar
Do you need to install CAI or exahst first?
Old 04-09-2015, 08:35 PM   #31
The car is designed to hit early gears hard. If you notice, each ascending gear is smoother and smoother off the clutch. I typically shift in 2 at 3200. That seems about as smooth as I can get it, but I drive it pretty hard most of the time... only averaging 16 mpg from my leadfoot. Lol. Going from a VW to a pony car is gonna take some time to get used to. Youll get it.
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
Black_Sunshyne is offline   Reply With Quote
Old 10-27-2017, 06:42 AM   #32
Skip it?
Honestly, unless I am trying to jump off the line, I have started just going from first to third for normal around the town driving. Second jumps hard and is almost impossible to get a smooth transition unless you are flooring it or giving it all of your concentration to go slow.
Gstang is offline   Reply With Quote
Old 10-27-2017, 10:31 AM   #33
c_rizzle's Avatar
Get the Steeda 35 lb clutch spring. It helps you feel the engagement point a little better.
It's less vague of a feeling in the middle.
I've driven manuals forever, and the PP Mustang was a bit harder to do well b/c of that slushiness in the middle... until I swapped springs.
c_rizzle is offline   Reply With Quote
2015 mustang
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
Ruby :: 2015 Ford GT Premium 5.0 w/50th anniversary package Beau B Member Garages 10 02-27-2015 07:11 PM
2015 Performance Package MarkH 2015 Mustang GT 18 01-30-2015 12:45 PM
Looking for a New or Used 13' V6 Premium w/ Performance Package & Comfort Package tgmeyer 2011-2014 V6 Mustang 2 10-24-2014 07:21 PM
Ford Mustang V6 Performance package :: 2014 Ford Mustang Rexex Member Garages 0 12-01-2013 04:05 PM
07:56 AM
