Map Lights auto entry/exit shutoff - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 02-18-2015, 01:00 PM   #1
mats96744's Avatar
is there anyway to shut off the map lights from coming on when you unlock/enter/exit or turn the car off?
mats96744 is offline   Reply With Quote
Old 02-20-2015, 02:26 AM   #2
Gravydog316's Avatar
here's from the manual:
Perimeter lamps illuminated entry
With the Integrated Keyhead Transmitter system, the following items will illuminate when the Lock control on the transmitter is pressed:
• Headlamps
• Park lamps
• Tail lamps
The lamps will automatically turn off:
• if the ignition switch is turned to the on position,
• the Integrated Keyhead Transmitter lock control is pressed, or
• after 25 seconds of illumination.
Note: On some vehicles, the perimeter lamps illuminated entry feature will not activate in daylight conditions.
Deactivating/activating perimeter lamps illuminated entry
You may enable/disable this feature by having your vehicle serviced by your authorized dealer.
You may also perform the following power door lock sequence to enable/disable the perimeter lamps feature. Note: Before starting, ensure the ignition is in the off position and all vehicle doors are closed. You must complete Steps 1–5 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, wait a minimum of 30 seconds before beginning again.
1. Place the key in the ignition and turn the ignition to the on position.
2. Press the power door control on the door panel three times.
3. Turn the ignition from the on position to the off position.
4. Press the power door control on the door panel three times.
5. Turn the ignition back to the on position. The horn will chirp one time to confirm programming mode has been entered and is active.
6. Press the power door control twice within five seconds. Note: The horn will chirp once to indicate the perimeter lighting feature has been deactivated. The horn will chirp once and honk once (one short and one long) to indicate the perimeter lighting feature has been activated.
7. Turn the ignition to the off position to exit the procedure.
Note: The horn will chirp once to confirm the procedure is complete.
Illuminated exit
• When all vehicle doors are closed and the key is removed from the ignition, the interior dome lamp will illuminate.
The lights will turn off if all the doors remain closed and
• 25 seconds elapse, or
• the key is inserted in the ignition.
of course, it depends which year you have;
checking the owner's manual will be the best way
otherwise: long story short: no.
Old 02-20-2015, 02:47 AM   #3
bucko's Avatar
Nice to see that the owners manual is checked for these types of questions. Good stuff is contained in those books.
Old 02-20-2015, 09:18 AM   #4
mats96744's Avatar
• Headlamps
• Park lamps
• Tail lamps
Illuminated exit
thanks for your help! i really appreciate the effort! unfortunately i think it cannot be turned off. maybe the dealership can do something but there is no info about turning it off in the 15 manual.
---------- Post added at 04:18 PM ---------- Previous post was at 04:18 PM ----------
thanks for your 2cents but ive already checked the manual you monkey! lol.
Old 02-23-2015, 02:32 AM   #5
Yeah, most are automatic; but some vehicles you can shut it off
2014 gas filler shutoff issue. dacm99 2011-2014 V6 Mustang 4 05-26-2014 08:58 PM
Help!!! No start 1988 5.0 after shutoff UDLOOZ 1979-1995 Mustang GT 12 04-06-2014 06:51 PM
fuel pump shutoff switch Horseplay 1996-2004 Mustang GT 14 01-03-2013 12:13 PM
Rear exit sxhaust or side exit exhaust? BLUE02GT 1996-2004 Mustang GT 21 06-08-2011 05:05 AM
Interior map lights Greywolf Mustang Audio & Video 2 01-31-2008 10:02 AM
01:20 AM
