Whiteline Trans mount fix - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 02-26-2015, 08:16 PM   #1
SmokinZX14R's Avatar
Got my Whiteline trans mod in today from American Muscle .. It took longer to jack the car up than it did to install the mod .. I did as some said to do and drilled a 7/16 hole in the large flat part of the mount .. I have zero vibration or noise from the mod ..In fact it seems to be a little less noise ..Shifting is much better and a more solid feel .. You can even feel it click into the next gear .. If you have not done this mod I say do it !!
Also installed a K&N filter in the stock air box , seemed to have a bit more power on tap..
Now I moving on to fix the wheel hop problem ...
2015 GT
2012 Kawasaki ZX14R . Fastest stock motored pump gas record 8.42 at 163.96
SmokinZX14R is offline   Reply With Quote
Old 02-28-2015, 05:19 PM   #2
str8edgect's Avatar
Check out the new Steeda bushings...they may help with that whee hop
str8edgect is offline   Reply With Quote
Old 02-28-2015, 06:38 PM   #3
I have the bushing , just need to install them.
2015 GT
MGW STS, Whiteline Mount, Spring Delete Laquisha 2011-2014 Mustang GT 7 10-25-2014 06:02 PM
just installed Whiteline transmission mount insert on my 2014 GT/CS (pics inside) Devil 2011-2014 Mustang GT 7 10-12-2014 03:05 PM
Whiteline Transmission Mount Bushing insert???? 2014GT 2011-2014 Mustang GT 16 05-30-2014 04:37 AM
Whiteline trans mount gtstyles2 2011-2014 Mustang GT 16 03-27-2014 12:18 PM
whiteline trans mount GypsyChris 2011-2014 Mustang GT 12 12-15-2013 09:06 AM
11:43 PM
