Steeda S550 Billet Rear Sway Bar Mounts (GT, V6, EcoBoost) - Now Available! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 03-03-2015, 06:07 PM   #1
tj@steeda's Avatar
And yet another upgrade rolls off the assembly line here at Steeda! Our Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) are in stock and readily available!
These S550 integral/vertical links are made from 6061, aircraft grade aluminum. They feature CNC machined delrin bushings, and billet steel bushing sleeves and spacers, providing less deflection than the rubber bushings in the stock vertical links, yet does not add any NVH!
Our Steeda vertical end links will not flex under load like the OE links, and will give a better feel of the rear suspension, which helps the rest of the suspension assembly perform as it should. The install is simple and comes with all necessary hardware!
Key Product Benefits:
- Provides better handling characteristics
- Installs easily, with basic hand tools
- Will not flex under load
- No increase in NVH
- Made in the United States with high grade materials
Product Photos (the second to last one compares ours to OE):
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 03-04-2015, 07:16 AM   #2
str8edgect's Avatar
Adding these to "The List"...can't wait to grab a pair!
str8edgect is offline   Reply With Quote
Old 03-04-2015, 08:08 AM   #3
tj@steeda's Avatar
The list, for the 2015 ... keeps getting longer!
TJ
Steeda Autosports
www.steeda.com
Steeda S550 Billet Rear Sway Bar Mounts (GT, V6, EcoBoost) - Now Available! tj@steeda 2015 Mustang GT 0 03-03-2015 05:56 PM
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 12:38 PM
Steeda Extreme G-Trac Brace Now Available for the 2015 S550 john@steeda 2015 Mustang GT 0 01-08-2015 03:07 PM
Steeda Autosports S550 Autocrossing with Steeda Suspension Upgrades Seth@Steeda Pictures and Videos 0 11-21-2014 12:26 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
10:32 AM
