GT Stock Exhaust - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 04-03-2015, 10:19 AM   #1
scurfie's Avatar
GT Stock Exhaust
I took out the resonator, replaced it with the Ford Racing X pipe. I was looking at the stock mufflers and I noticed that they were straight through. My question, has any one dyno tested a GT with the X pipe and standard mufflers, and then with Ford racing or another brand of mufflers? The reason I'm asking is, the straight through standard exhaust should have very little back pressure, or am I wrong about that?
scurfie is offline   Reply With Quote
Old 04-03-2015, 12:49 PM   #2
SilverS550's Avatar
It's not just about being a straight through design. You have to take into consideration the sound pulses as part of it. Sound is simply energy that you can hear. You can pass it along, you can try to cancel it, you can absorb it.....anything other that just letting it pass freely will cause a disturbance in the system.
If you try to absorb it, you generally slow the flow. (Most glass packed mufflers)
If you try to cancel it, you have use something that has an off setting frequency against it and this disturbs the pulse. (Flowmaster type mufflers)
The magnitude of the disturbance will cause some pressure against the exhaust flow. Also, pipe diameter, length of bends, radius of bends, etc., all play a part.
SilverS550 is offline   Reply With Quote
Old 04-03-2015, 03:33 PM   #3
scurfie's Avatar
Thank you. That makes sense.
exhaust
Stock exhaust/ stock intake iaintacop 2011-2014 V6 Mustang 6 09-06-2014 12:50 PM
08 Mustang GT stock exhaust w/polished tips and stock springs Pete08GT Mustang Parts for Sale and Wanted 2 09-24-2011 08:19 PM
Wanted: Stock coil springs and stock mufflers for '96 GT inaba116 Mustang Parts for Sale and Wanted 6 02-15-2006 09:19 PM
Stock 03/04 Cobra vs Stock LS1 PureVenom The Bar 46 05-08-2005 05:41 PM
Installing a stock V8 on my stock V6 EXHAUST mrshoss97V6 Pre-2005 V6 Mustang 3 06-30-2004 12:43 PM
09:51 AM
