Tire Pressure sensors - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 04-12-2015, 08:03 AM   #1
scurfie's Avatar
I'm new to this so maybe someone can help me out. I check my tire pressure via the Mustang guage, and the tires are reading 40lbs each!
I look at the recommended tire pressure, and set them to 32 via my digital tire pressure gauge.
Now I look at the Mustang guage and it has 33 at one tire and 34 at the rest!
Is that normal to be that far off?
scurfie is offline   Reply With Quote
Old 04-12-2015, 10:19 AM   #2
Waylap1's Avatar
Region: New Hampshire
Yes, they are small and cheap and probably so is your digital gauge.
Or,.... You used metric air by mistake.
Switch to Canadian, it's cleaner and cooler.
Waylap1 is offline   Reply With Quote
Old 04-12-2015, 11:19 AM   #3
scurfie's Avatar
Thanks
Ha ha I checked my "cheap" digital gauge with my professional analog gauge. Both gave me the same readings.
My gauge is pounds only.
I need to try your Canadian air suggestion!
Old 04-12-2015, 03:43 PM   #4
SilverS550's Avatar
Make sure the you've rolled the tires before you check them. From what I gather the sensor only register when they sense motion in the tires to conserve battery life. If the car has been sitting, they'll show the last recorded pressure.
I'm not 100% positive on that, so don't quote me but if it's what I think it is, just go up and down the driveway and it should give you the correct reading on the dash.
'15 GT, SCT, JLT, Magnaflow, Steeda, 20x10's w/ 275/35/20 Nitto 555's
SilverS550 is offline   Reply With Quote
Old 04-12-2015, 03:51 PM   #5
scurfie's Avatar
Thanks. I noticed today the pressure readings from the Mustang are still 2 pounds off. Not a big deal I guess. The car is still new less than 500 miles. I need to calm down.
Old 04-12-2015, 03:58 PM   #6
SilverS550's Avatar
Mine show 2 psi lower than my gauge does. I have the front at 34 and the back and 33. In the car it shows as 32 and 31.
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
New Wheels.... Tire Pressure Sensors? TedG Mustang Wheels & Tires 9 08-16-2014 08:32 AM
2012 tire sensors Yankee5.0 2011-2014 Mustang GT 3 06-10-2014 08:42 AM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
Cars Hacked through wireless tire Sensors rickf73 General Car Discussion 15 09-09-2010 02:16 PM
12:43 PM
