Tall 6'3 + 2015 Mustang owners (HELP) - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 05-17-2015, 02:48 AM   #1
1800CoolGuy's Avatar
I am considering upgrading my 2014 v6 mustang to 2015 GT premium.
I am 6'4 210 pounds and have no problem fitting into my 2014 V6 Mustang ....i am actually surprised at how comfertable it is for me. When my dealer got 2015 Mustangs in i tried to sit in one and my head was literally touching the interior roof of the car. My friend was laughing at me saying only bottom half of my head could be seen through side window from outside.
No matter how i tried to adjust the seat it was like that so is the new Mustang smaller or was i doing something wrong when trying to adjust the seats.
1800CoolGuy is offline   Reply With Quote
Old 05-17-2015, 04:11 AM   #2
Waylap1's Avatar
Region: New Hampshire
Lean that seat way back and use the all new telescoping steering wheel. Plus, you will look cooler.
Waylap1 is offline   Reply With Quote
Old 05-17-2015, 05:28 PM   #3
I'm 6'2 and I have plenty of room. I have recaros though. Some cars aren't meant for tall people though.
Mikeyt03 is offline   Reply With Quote
Old 05-17-2015, 05:29 PM   #4
^ here are two examples.
Name:	ImageUploadedByMustang Evolution1431905378.062353.jpg
Adventure till you drop
Old 05-17-2015, 05:30 PM   #5
As mentioned before, you might have to rock the gangsta lean and telescope the wheel to your reach.
Old 05-18-2015, 11:58 AM   #6
Region: Arkansas
I'm 6'4" and 220 lbs. My 2015 GT has the Ricaro seats that can be manually jacked up or down, as well as the old-style front to rear slide. I have no problem with either head room or leg room, and the seat is not lowered to its lowest position. The seat back is not raked back to gangsta mode.
respolt52 is offline   Reply With Quote
Old 05-18-2015, 12:00 PM   #7
Maybe his torso is super long and his legs are short.
Old 05-18-2015, 01:17 PM   #8
RBK
I'm 6' 3 &1/2' and test drove the 15 and had no problem whatsoever. It is going to depend on how you body is proportioned, if you have a long trunk and shorter legs your head might hit the roof but as I remember there was plenty of room. Look up the specks for the two cars and compare the headroom heights.
RBK is offline   Reply With Quote
Old 05-18-2015, 10:41 PM   #9
tezz's Avatar
What he said.
No problems with my '13 -I'm 6'5" and I can even wear my helmet at the track ( that's a bit tight though).
I test drove a premium 15 (no helmet!) and had no problem fitting.
tezz is offline   Reply With Quote
Old 05-19-2015, 08:09 AM   #10
b2673ad's Avatar
Hello
6'5" 290
You need to get a car with the power drivers seat so you can rock back and adjust.
Now worries about someone sitting behind you.
Kevin C.
2015 Roush RS1 Premium w PP
Roush Performance upgrade-- Tinted Windows
JLT Catch Can--Ford Racing Strut Brace
Flowmaster scavenger "Y" pipe resonator delete
b2673ad is offline   Reply With Quote
Old 05-19-2015, 08:13 AM   #11
With our size I don't think anyone could sit behind us, in a mustang. Well besides a child, and that's still pushing it.
Old 05-22-2015, 02:32 PM   #12
Just got a 2015 GT Premium with Performance Package!
Old 05-25-2015, 09:08 PM   #13
The one with the short ceiling?
Old 05-26-2015, 02:38 PM   #14
James892's Avatar
I am 6'4, 228 and have no problem sitting in either the GT coupes or verts. The battery might not be fully charged so the power seating might not work 100%.
I ordered a vert which comes with slightly more headroom. More so when the tops down (sarcasm that isn't funny). I fit into it perfectly fine and comfortably with enough space. You should try sitting in the model you want and take one for a test drive to get used to the driving position you would be sitting in as this can make a big difference (slouching, leaned back, stiff).
Hope it works out for you.
James892 is offline   Reply With Quote
Old 05-26-2015, 03:18 PM   #15
Commercial Member
au01st's Avatar
6'4" 280lbs here. I have no issues in my '13 and when I sat in a '15 at my dealer I had no issues either.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 02-28-2016, 11:32 PM   #16
Question
Originally Posted by b2673ad View Post
Hello
6'5" 290
Does that mean you fit good in it?
tarikhasan645 is offline   Reply With Quote
Old 02-29-2016, 12:25 AM   #17
NewMtang's Avatar
Big Head Coming Thru....
No one else is having a problem with the adjustment for driving the 2015. Sorry but if your the only one having problems, YOU GOT A FAT HEAD.
You could have a glass roof installed so you can drive with your head in the open top.
Old 02-29-2016, 05:19 AM   #18
b2673ad's Avatar
Yes I do fit.
I rented a 2016 EcoBoost and fit fine it that car.
Power seats is the key.
Kevin C.
Old 02-29-2016, 08:11 AM   #19
Thanks!
Thank you wohoooo!!!
Old 02-29-2016, 08:36 AM   #20
PonyBoyV6's Avatar
I'm 6'4, and the only trouble I have is with the my head whacking the top of the roof when i'm trying to get in or out. Otherwise, no problems sitting regularly.
PonyBoyV6 is offline   Reply With Quote
2015 mustang
Is 2015 Mustang lower then 2014 (tall people problems?) 1800CoolGuy 2011-2014 Mustang GT 6 05-19-2015 04:21 PM
How tall of a tire? Luna1994 Mustang Wheels & Tires 12 02-23-2014 10:40 AM
Gear Options with MT82, Boss IM and Tall Tires Napoleon85 2011-2014 Mustang GT 2 04-22-2012 06:44 PM
How tall of a tire should i use for 3.73's 20115oh 2011-2014 Mustang GT 3 04-09-2012 10:22 PM
Any good Sports car for big & tall drivers? eder General Mustang Discussion 4 04-04-2010 07:34 AM
02:36 AM
